Angle grinder or eccentric - what to choose to remove paint from wood
gorti1 11004 12
What is the best tool for removing old peeling oil paint from wooden boards: an angle grinder, an eccentric sander, or something else?
A belt sander is the best choice here; an angle grinder can make grooves in the wood, and an eccentric sander is safer but much slower [#16260851][#16262378] Use coarse 60-grit paper first, then finish with about 150-grit [#16262378] If the paint layer is thick, one option is to soften it first with a heat gun and scrape it off with a spatula [#16260013] Another alternative is a paint-remover gel such as Bondex universal remover, let it swell the paint and then scrape it off [#16262457] After scraping, one user finished the surface with a wire brush on a flex and said it was clean enough for impregnation [#16263192]
  • #1 16259917
    gorti1
    Hello all
    I place this post because I have no experience in this topic and I do not know which solution will be better.
    Last year, I purchased a plot with a wooden gazebo whose walls are covered with boards such as paneling. Everything would be ok if the previous owner did not paint them with oil paint that is already beginning to peel and looks poor. Therefore, in the spring I want to sand it all (preferably to clean wood) and paint it with some wood preservative. My question is what is the best way to remove this old paint with an angle grinder (speed-controlled flexo) with an abrasive paper disc or an eccentric sander. I do not know what will be better because I have flex and eccentric I would have to buy. I have an ordinary orbital sander but it grinds wood very slowly and at this rate it will go down to the second winter.
    I am asking for advice
    Thank you
    Gorti
  • #2 16260013
    krzysztofh
    Help: 101
    Rate: 937
    If there is a thick layer of this paint, it is best to burn this paint with a heat gun and then sand with a grinder, otherwise it will last for a long time. Sunbathing is done by heating the paint until soft and removing it with a spatula.
  • #3 16260261
  • #4 16260618
    gorti1
    but I have a grinding wheel for sticking Velcro (you can also put it on a drill). And as for the shield you gave, I don't know if it will scratch the wood.
  • #5 16260712
    kefir66
    Rate: 10
    Use a belt sander.
  • #6 16260766
    gorti1
    I saw a belt grinder in operation and it grinds nicely and quickly but it is large and heavy (at least I had to do it) and if I have to sand the entire walls and ceiling on the terrace, I think my hands will fall off. That's why I thought about the abovementioned grinders, but I don't know which would be better. I sanded wooden beams with rotten wood and cleaned it nicely, but I don't know how it will do with paint and work with it is not very precise. I do not know how the case is with the eccentric because I have never seen her work live and the movies on the net show differently and I would have to buy it and my flex is in stock. If someone did eccentric and can recommend it for such work, please let me know.
    Gorti
  • #7 16260851
    0__0
    Help: 115
    Rate: 101
    Flexem you will make grooves, the eccentric is better but slow - with the same 60 pnematic orbital sander 150mm collects with 3 times slower than a decent belt.
  • #8 16260877
    gorti1
    OK thanks for the information. I guess I'll have to consider this belt sander. I thought that eccentric because it turns like flex (only a little slower) it will also do well (and it is small and probably light) but if you say that it is also slow it is ok
  • #9 16260985
    Rezystor240
    Help: 689
    Rate: 1655
    I advise against the eccentric sander, its service life is really short.
    You won't do half the work and it will fall apart, at least mine did.
  • #10 16262378
    Freddy
    Help: 1394
    Rate: 2822
    gorti1 wrote:
    My question is how best to remove this old paint
    Belt sander, first about 60 paper, then about 150 - simple, safe and fast.
  • #11 16262457
    mietek440
    Level 19  
    Help: 15
    Rate: 200
    I recommend Bondex universal remover. It is a can of gel about 0.8 l. You wait some time and scrape with a scraper. It goes down very easily to the wood itself. The paint swells under the influence of the gel. A can costs about PLN 50.
  • #12 16262767
    Freddy
    Help: 1394
    Rate: 2822
    Yes, sure, but then it's hard to paint something :)
  • #13 16263192
    mietek440
    Level 19  
    Help: 15
    Rate: 200
    After scraping, I sanded with a wire brush on the flex. The surface is perfectly clean, it can be impregnated.
The discussion revolves around the best method for removing old oil paint from wooden panels in a gazebo. Users suggest various tools and techniques, including using a heat gun to soften the paint before sanding, employing paint grinding wheels, and considering a belt sander for efficiency. While some recommend the eccentric sander for its precision, others caution about its durability and slower performance compared to a belt sander. The use of chemical paint removers, such as Bondex universal remover, is also mentioned as an effective alternative. Overall, the consensus leans towards using a belt sander for faster and more effective paint removal, followed by finer sanding for a smooth finish.
