Best Sander for Stripping Paneling & Sanding Plaster: Orbital, Eccentric, or Oscillating?
davidstar 15615 12
What type of sander should I buy to strip varnished wall paneling and also use on gypsum plaster: orbital, eccentric (forced or unforced), or oscillating?
For this job, the thread says not to rely on orbital/eccentric/oscillating sanders as a universal solution: an orbital sander with 40-grit paper failed on old painted paneling, while an angle grinder with a concrete grinding head was the tool that actually removed the coating efficiently, though it creates a lot of dust and needs strong protection and ventilation [#17182066] For paneling, a heat gun can also help loosen paint in corners and hard-to-reach places, but it was described as less effective than the angle-grinder method [#17236386] For gypsum plaster, Bosch explicitly advises against grinding machines, saying eccentric and oscillating grinders are not recommended and can break quickly; instead, use a spatula or a multitool with scraper-type attachments [#17236386] So the practical choice is: angle grinder with a suitable grinding head for the paneling, and a multitool/scraper for the plaster, rather than one sander for everything [#17182066] [#17236386]
  • #1 17178005
    davidstar
    Rate: 20
    Hello you
    I am taking care of my house renovation. I have half an old communist paneling on the wall. It is a slippery surface on one side (painted with varnish) and rough.
    I wonder what to do with it, because it's definitely not a spatula. :) I see that on the Internet they write about orbital and eccentric grinders. A friend advised me oscillating, but on the net from what I see it is more suitable for wood. Nobody heard about the eccentric. They write about eccentric grinders that there are two types:
    - Eccentric grinders with unforced movement (speed depends on pressure).
    - Eccentric sanders with forced movement (pressure force does not affect speed).
    Help me choose something to strip the paneling. Something for personal use. And that it would also be universal, that if I want to reach gypsum plaster it will also be as found.
  • #2 17178207
    DriverMSG
    Help: 3984
    Rate: 4880
    Paneling is surely painted with oil paint, so any high-speed sander will stick sandpaper. Other slow speeds will require a lot of time to sand the walls.
    Personally, I treat this type of wall with an angle grinder with a wire brush, and put a smooth coat or other light plasters.
  • #3 17179008
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1007
    Where have I heard this? Kitchen - oil paint, bathroom and toilet the same. And now to work. I used an angle grinder with a concrete grinding head mounted on its mandrel. I assure colleagues, nothing is better. However, the cover must be removed from the angle. The head is a disk with a threaded hole on which are grooves for discharging spoil and the remaining surface is sprayed with very hard material. Well, the walls were already taken care of, but the door frames still need to be removed, and this is a huge slab. I didn't use the hammer but only applied my brother's patent. In the middle of the door frame on both sides in the concrete adjacent to the door frame, I drilled two holes and then I put two hooks of the chain hoist in these holes and pulled both parts of the door frame with the hoist without using an angle grinder.
  • #4 17181235
    fotzsyzrk
    Rate: 46
    Oil can be tan, the fact smells a bit, but you can deal with it, grinding without extraction is also harmful dust. Personally, the electric heat gun was too inefficient for me, I used a roofing felt burner plus this unwanted spatula ;) quickly and efficiently ;)
  • #6 17182066
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1007
    Yes. This is the head presented by a colleague above. I carried out a test with a heat gun. I will say sneeze. Also, an orbital sander with 40 grit sandpaper did not pass the test. Only the angle grinder with this head took care of the subject. On the head a mask in the form of a grinding helmet, not glasses. Of course, as you grind, a relatively large amount of dust is released, you can put a mask on the beak. Opened windows along the entire width during grinding. It can not be hidden that grinding according to my method is relatively time-efficient with a slight uniform pressure of the disk on the wall comes out a relatively smooth wall surface. In two days, with breaks, I dealt with the topic of sanding walls with oil paint that has been there for 30 years. I also demolished partitions. Repair specialists for the works I did in apartment M5 valued my work at around 6,000 zlotys. Of course Kasiora was in my pocket.
  • #7 17198139
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    Instead of making a "Saigon" with an angle, sometimes it is worth reaching for simple tools such as:
    https://www.leroymerlin.pl/narzedzia-reczne/p...gclsrc=aw.ds&dclid=CPHLicSg5doCFQKbGAod3-gP-A
    And a regular hammer ... This combination allows you to remove paneling, marmolite and acrylic plaster relatively easily. It does not mean that you do not have to make money ...
  • #8 17198215
    Ryszard49
    Help: 312
    Rate: 1006
    andrzej lukaszewicz , I suspect you didn't use this tool, I definitely don't recommend it.
  • #9 17198216
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1007
    With the equipment you offer, you can spread the renovation over two years.
  • #10 17198557
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    I used, and more than once, a dozen m2 of marmolite scratched from a G / K board in 1 day and no angles with shields were suitable, because they destroyed the paper layer on the board. And with virtually no dust. A buddy removed with similar tools acrylic plaster from masonry fence posts. Of course, this requires a lot of work, but it is very precise in hard to reach places and does not degrade the ground. If you can dust in the room, probably the angle and the pot shield will be the most efficient, but I was doing renovation of 2 rooms in a inhabited house and I could not afford the armageddon with the angle, despite the protection from foil, etc.
  • #11 17199921
    davidstar
    Rate: 20
    That's it, gentlemen, the angular will make a spring roll, I will have dust even in the butt. This scraper is an interesting topic, it is not expensive and you can test it. It will definitely be useful because there are places where the machine will not enter. But with such large surfaces, who knows if I will not eat ... I have found something like this https://www.youtube.com/watch?v=E1O06SwYASo only the cost of this miracle with a vacuum cleaner is about PLN 1250-2 thousand: / (different prices from what I see)
  • #12 17202058
    andrzej lukaszewicz
    Help: 626
    Rate: 2120
    Chemicals can be used, but the stench will also be present throughout the home.
    https://ezakupy.tesco.pl/groceries/pl-PL/prod...MIgP3V-crq2gIVFpSyCh3IWQNeEAQYBCABEgJL7vD_BwE
    https://www.castorama.pl/produkty/wykonczenie...k-do-usuwania-farby-olejnej-diall-0-75-l.html
    But on vertical surfaces it will not be easy to apply and wait ...
  • #13 17236386
    Narzędzia Bosch
    Rate: 32
    Unfortunately, we recommend against grinding machines (whether eccentric or oscillating). What's more, none of these grinders is recommended to grind gypsum - they can break quite quickly, and the warranty will not apply. So the spatula or its more automated version remains - a multifunction device also called a multitool, e.g. GOP 40-30. For this you can buy attachments resembling a spatula and it will greatly facilitate the work. The paneling can also be heated with a heat gun - especially in the nooks and crannies it will facilitate peeling off the paint.
    Best regards, Bosch expert.
The discussion revolves around the best tools for stripping varnished paneling and sanding plaster. Users suggest that high-speed sanders may struggle with oil paint, while angle grinders with specific attachments (like concrete grinding heads) are recommended for effective removal. Some participants mention using heat guns and scrapers as alternatives, emphasizing the importance of dust management. Eccentric and oscillating sanders are generally discouraged for this task, particularly for gypsum plaster, as they may break easily. A multifunction tool, such as the Bosch GOP 40-30, is suggested for its versatility. Chemical solutions are also mentioned, though they come with odor concerns.
TL;DR: Two days to strip 30‑year oil paint; "Only the angle grinder with this head took care of the subject." For DIYers removing old paneling and plaster, this FAQ guides tool choice and dust control. [Elektroda, kierbedz4, post #17182066] Why it matters: Using the right method prevents clogged abrasives, protects gypsum, and cuts cleanup time.
What’s the best tool to strip old oil-painted wall paneling fast?
Use an angle grinder with a diamond concrete grinding head. It “took care of the subject” where 40‑grit orbital failed. Apply light, uniform pressure to keep surfaces even. Expect heavy dust; ventilate and wear a grinding helmet and respirator. One report finished 30‑year oil paint in two days with breaks. Open windows wide during grinding. This approach is time‑efficient for large areas. [Elektroda, kierbedz4, post #17182066]
Orbital vs eccentric vs oscillating: which sander works on varnished or oil-painted paneling?
High‑speed sanders clog immediately on oil paint. Slower passes take too long. For paint removal, an angle grinder with a wire brush works better. Then apply a skim coat or light plaster to finish. Random‑orbit or orbital choices matter less than the coating’s behavior. Prioritize tools that don’t rely on abrasive sheets for thick oil paint. [Elektroda, DriverMSG, post #17178207]
Can I sand gypsum plaster with an orbital or random‑orbit sander?
No. “None of these grinders is recommended to grind gypsum” and damage can void warranty. Use a spatula or a multifunction oscillating tool with scraper blades instead. A Bosch GOP‑class multitool is designed for this task. It reduces risk to soft gypsum surfaces. This approach also gives better control in corners and edges. [Elektroda, Narzędzia Bosch, post #17236386]
Is a heat gun effective for stripping oil paint from paneling?
Results vary. One user found an electric heat gun too weak. A roofing felt burner plus a metal spatula worked “quickly and efficiently.” Heat softens old oil paint for scraping, but manage fumes and ventilation. This method reduces grinding dust but requires flame caution. Test a small area first to gauge bond strength. [Elektroda, fotzsyzrk, post #17181235]
I need a low-dust method in an occupied home. What should I use?
Use manual scraping tools and a hammer for leverage. A user removed a dozen m² of marmolite from plasterboard in one day with “virtually no dust.” This avoids damaging the paper face that grinders can tear. It also excels in detailed or tight areas. Plan for effort, but cleanup is minimal compared with grinding. [Elektroda, andrzej lukaszewicz, post #17198557]
How do I use a diamond grinding cup to strip walls safely?
Mount a diamond concrete grinding head on your angle grinder. Use light, uniform pressure to avoid gouges and yield smooth results. Ventilate well; wear a grinding helmet and a respirator because dust output is high.
  1. Fit the diamond cup and check rotation.
  2. Work in passes with steady pressure.
  3. Ventilate; use helmet and mask. [Elektroda, kierbedz4, post #17182066]
What disc size and style works for wall stripping?
A 115 mm diamond concrete grinding disc works on compact grinders and handles wall coatings effectively. Users confirm good removal performance on painted masonry surfaces. Choose segmented or turbo diamond patterns intended for concrete grinding. Keep passes controlled to limit swirl marks. Replace discs when segments glaze. [Elektroda, beam_beer, post #17181418]
Should I use a wire brush on an angle grinder instead of sanding?
Yes, for oil‑painted paneling a wire brush avoids sandpaper clogging. Brush the coating off, then apply a smooth coat or light plaster. This method trades dust for swarf, so still protect eyes and lungs. It also handles uneven textures better than flat pads. Work methodically to avoid gouging soft substrates. [Elektroda, DriverMSG, post #17178207]
Are chemical paint strippers worth using on vertical walls?
They can work, but expect strong odor throughout the home. Vertical application is inconvenient because products sag while you wait. Plan for multiple applications and careful containment. Ventilation and protective gloves are essential. For occupied spaces, scraping or localized heating may be easier. Test compatibility with underlying plaster before full removal. [Elektroda, andrzej lukaszewicz, post #17202058]
What does pro removal cost versus DIY grinding?
One renovation was quoted around 6,000 PLN for apartment wall work. The user completed stripping and demolition themselves and saved that cost. Time reported was two days with breaks using a diamond cup. DIY requires PPE and cleanup planning. Professionals reduce effort but increase budget. Consider both schedule and health protections. [Elektroda, kierbedz4, post #17182066]
Is a dust-extracted wall sander with vacuum a good buy?
For large areas, a drywall/wall sander with vacuum reduces airborne dust significantly. Expect a package cost of roughly 1250–2000 PLN. This can be worthwhile if you prioritize cleanliness. It also shortens cleanup in occupied homes. For small jobs, manual scraping may be more economical. Try rental before buying to assess value. [Elektroda, davidstar, post #17199921]
How do I handle corners and edges cleanly?
Use a multifunction oscillating tool with scraper blades. It excels where round pads or cups cannot reach. “The paneling can also be heated with a heat gun” to help lift paint in nooks. Choose a pro‑grade tool like Bosch GOP 40‑30 for durability. Keep strokes controlled to protect substrates. [Elektroda, Narzędzia Bosch, post #17236386]
Forced-rotation vs free-spinning random-orbit: does it matter for painted paneling?
Both struggle on oil paint. High‑speed sanding clogs; slow sanding drags and wastes time. Movement type will not overcome gumming. Switching to non‑abrasive removal is more effective. Use a wire brush on an angle grinder or manual scraping. Finish with a skim coat rather than chasing perfection by sanding. [Elektroda, DriverMSG, post #17178207]
Do I need to remove the grinder guard for a concrete grinding head?
One user reported removing the guard to fit a concrete grinding head. Guard removal increases exposure to debris and dust. If you proceed, wear full face protection and a respirator. Consider tools and guard systems designed for cup wheels. Balance safety with productivity on your site. [Elektroda, kierbedz4, post #17179008]
