[Solved] Ariston LFF8M121C Dishwasher: Error F03, NTC Resistance Value 950K at 17°C - New or Damaged?
bubu64 8310 3
  • #1 16259963
    bubu64
    Help: 57
    Rate: 283
    Hello, I have a question as in the subject, the dishwasher shows error F03 and therefore I took NTC for measurement. The resistance value is 950K at 17 ° C. Is it new or damaged with such resistance?
    mrhari
    Help: 835
    Rate: 3239
    bubu64 wrote:
    error f03
    This is the time that water has been poured out.
  • #3 16260383
    bubu64
    Help: 57
    Rate: 283
    Bajzel with this Ariston, in my error codes F03 is an NTC error or heater.
    I found something like this for dishwashers with display:
    A03 - Short circuit on thermistor or Time-out drain. Check out the problem persists.
  • #4 16261815
    bubu64
    Help: 57
    Rate: 283
    It is true that the drain pump was working and the water was pumped out, but there was a toothpick in the pump chamber that interfered with the pump. Problem solved, thanks for paying attention to the problem of proper pump operation :)
