Samsung ue40d6100SK TV: Horizontal Lines on Screen, BN44-00482B Powerboard Jumper Solution
rushiamit 7236 2
  • #1 16260777
    rushiamit
    I've had Samsung ue40d6100SK TV for around 4 years. It had been working fine till last evening when all of a sudden it started showing horizontal lines on the top half of the screen. I also came across a few posts which state that cutting a jumper on the powerboard resolves the issue. However, I don't have that jumper on my board. This TV has Bn44-00482b powerboard.
    Please help.
  • #2 16263978
    januszk3
    Check your power supply. Probably electrolytic capacitors must be replaced. It is a typical defect. Best regards. Janusz.
  • #3 16267361
    rushiamit
    januszk3 wrote:
    Check your power supply. Probably electrolytic capacitors must be replaced. It is typical defect. Best regards. Janusz.
    Many thanks :) I have noticed a weird behavior. This TV has 3D functionality. So when I tried a 3D movie, it worked perfectly with no flickering. So I wonder if the problem is with the powerboard or something else.
