D-Link DWR-116: Connectivity Issues on Lumia 625, Laptop, and WPS Option Unavailable
amadeusz575 11646 7
  • #1 16260981
    amadeusz575
    I have a problem with connecting to the wifi network in my phone and on my laptop. On the phones of 2 other people living with me, the wifi works amazingly, brother said something about the WPS option, and I can not find one in my phone and in the laptop too. On the second computer at home (the stationer) the internet works without a problem (it is connected to the router with a LAN cable).
    When I try to connect to the wifi on my phone (Lumia 625 model), the message "The phone can not connect to the DWR-116 Wi-Fi network ..."
    The computer is similar. When I try to connect, I have the message: "Windows could not connect to the network ...". I tried to fix it using the troubleshooter but there I just found the advice to reset the router (screen in the attachment), which of course did not help. The fault lies with the router - its exact model is D-Link DWR-116.
    I am counting on your help and thanks in advance!
    Moderated By jimasek:
    I merged the thread
  • #2 16261065
    Lukalago
    Help: 30
    Rate: 73
    The problem is probably with encryption (unless you enter a wrong password)
    Set encryption on WPA2-PSK or WPA-PSK
    Turn off the automatic functions, set the parameters rigidly.
    Try to set up a wifi 801 bg connection on a rigid basis (without "N")
  • #3 16261314
    kindlar
    Help: 919
    Rate: 1624
    What is set on the router you do not know. Perhaps the router allows devices with specific MAC addresses. Give screenshots from router settings.
  • #4 16261537
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Do you have access to the configuration panel of this router?
  • #5 16263854
    actin
    Help: 187
    Rate: 800
    Check the signal transmission mode in the router.
    WPS is a button on the router. Press it and try to connect 6
  • Recommended WPA2-PSK and fixed 802.11b/g settings
    #6 16266536
    amadeusz575
    I certainly write the password well, before everything worked without a problem, for a few days it began. How can I set this encryption on WPA2-PSK? There are only WPA (2) -Personal and WPA (2) -Enterprise options. And where can I set these parameters? D-Link DWR-116: Connectivity Issues on Lumia 625, Laptop, and WPS Option Unavailable
    How to enter the router settings?
  • #7 16266722
    actin
    Help: 187
    Rate: 800
    Open a Web browser and go to the address
    http://192.168.2.1. In the username and password field, enter admin.
  • #8 16278973
    amadeusz575
    Everything is working. It was enough to reset the router by sticking a pin into this hole ... Thanks for your help :D
The user experienced connectivity issues with their D-Link DWR-116 router on a Lumia 625 phone and a laptop, while other devices connected without problems. Suggestions included checking the router's encryption settings, specifically setting it to WPA2-PSK, and ensuring the router allows connections from specific MAC addresses. The user was guided to access the router's configuration panel via a web browser. Ultimately, the issue was resolved by resetting the router, which restored connectivity.
