Samsung Galaxy J5 Camera Issue: Loss of Focus, Distance Limitations, & Window Replacement Options
Emmpo 8436 5
  • #1 16262440
    Emmpo
    Hello, I have a Samsung Galaxy J5 phone and I have a problem with the camera. Namely, I do not have a quick camera because I got beaten, but it normally caught sharpness, and now I noticed that it stopped, at most from a distance as I take a photo it is ok. I need to replace this window and it will be okay?
  • #2 16262456
    qwerty97m
    Try to restore to factory settings. It costs nothing and can work :) if it does not help then then play with the fast.
  • #3 16262621
    KamGr
    Help: 77
    Rate: 203
    Or replacement, in your case, the assembly of a new quick if you have broken the old one or replacement of the camera.
  • #4 16263880
    AK_Service
    Rate: 34
    I do not catch sharpness because the mechanism in the optics jammed through the dirt that got to him
  • Replace the camera lens cover by heating and cleaning adhesive
    #5 16264155
    raptowny13
    Help: 22
    Rate: 50
    The fast works as a lens / lens as it is called a bill. Without it, the camera will not catch focus. It is located on the body. It remains to replace the body or the slide itself. The glass is gently heated with a dryer or whatever you have in the vicinity, undermine it, then clean the glue residue (at the same time wipe the device gently with the ear stick) and put on new ones. When attaching a new one, pay attention to get rid of protective foils from the slide.
    ASPOL
    Świątniki 61, Pabianice, 95-200
  • #6 16265288
    Erka09
    In my opinion, restoring factory settings will not help in this case. Only quick exchange.
