Peugeot 508 1.6 THP 156 HP: Engine Malfunction Message, Fan Activation, Gray Exhaust Smoke
kalin123456 12636 4
  • #1 16263364
    kalin123456
    Engine problem.
    Peugeot 508 1.6 THP 156km.
    After starting the car, the message with the engine malfunction activates, the engine indicator lights up and the fan turns on (when the engine is cold), which goes out only after disconnecting the battery.
    Radiator fluid and oil are.
    There was also gray smoke from the exhaust pipe.
    Some gasket in the engine, turbine (practically new 10,000 km)?
    Maybe someone had similar problems?
    Thanks for the info.
  • #2 16263581
    MobilTruck
    Help: 139
    Rate: 965
    Diagnostics only and not necessarily in ASO. Hardly anyone will be able to help on the forum without reading errors and parameters.
  • #3 16266047
    kalin123456
    This morning when I got in the car I was pleasantly surprised, after starting the engine everything was ok.
    I also went to the mechanic for diagnostics on my own wheels.
    Unfortunately, by disconnecting the battery, I also deleted the error history, so I have to wait for the next such action to find out what's going on.
  • #4 16266341
    milejow
    Help: 1563
    Rate: 5149
    kalin123456 wrote:
    Unfortunately, by disconnecting the battery, I also deleted error histories
    You didn't delete anything, it's not old 405.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #5 16550357
    kalin123456
    The problem no longer occurs (after clearing the error on the computer).
    Best regards and thanks for the hints.
