Peugeot 407 1.6HDI 2005 - White Smoke Issues in 2nd Gear and 5,000 RPM; No Error Codes
Cj123 7635 4
  • #1 16173142
    Cj123
    Rate: 34
    I have a Peugeot 407 1.6HDI 2005.
    Recently, I noticed that the car is wearing white
    especially when I hit the second gear and the gas pedal up to 5,000 revolutions (temperature
    outside 0, -1).
    I notice it when the car heats up and I start, for example, from the lights in
    in the rear view mirror you can see most of the amount of white smoke.
    The strange thing is that the computer shows no errors, the engine
    the car runs evenly for such an engine, it is cool, there is no lack of coolant or oil. What could be causing this ???
  • #2 16173197
    qwertexx
    Help: 11
    Rate: 44
    every car smokes white in the cold. it's not smoke, it's steam
  • #3 16174648
    jamszoł
    Help: 15
    Rate: 39
    I am of this opinion too
    It's cold - temperature change causes condensation of water in the exhaust system (water / ice)
    And when you start the engine, the water starts to evaporate
    Check if it evaporates like this when you drive a longer route
    This should fade away with longer rides
  • #4 16181589
  • #5 16181698
    omnibus111
    Help: 11
    Rate: 46
    As I remember correctly, there will be no white smoke from VW Beetles and Fiat 126. Firstly, air-cooled (hot engine), secondly, the exhaust system is very short, so that water (water vapor) does not condense in the exhaust pipe.
