Peugeot 307 1.6 HDi 2006: Glow Plug Heating Failure and Uneven Idle Speed
automar91 13989 4
  • #1 16263911
    automar91
    Rate: 153
    Hello. The car is a Peugeot 307 1.6 HDi 110KM from 2006. Well, the problem is that the cold engine is hard to start. That's why I started by checking the candles, but they are operational and here I came to the point that the candles are not under tension. I also noticed that the candle light on the board does not light up. This happens on a cold and warm engine. When I disconnect the liquid temperature sensor, the light on the board lights up and the candles are heated and then firing is much better. I put a new sensor on, but no changes. Additionally, when the engine is warm, it has an uneven speed (sways) at idle. There are no errors on the computer. I will be grateful for your help.
    Greetings.
  • #2 16264183
    Levis82
    Rate: 42
    And is the resistance of the new one the same as that of the old one? From what I know at 20 degrees. should be ok 2Kohm, maybe this new one is also damaged?
  • Glow plug relay fault suspected from coolant sensor test
    #3 17084479
    spec307
    Greetings.
    and what the problem was solved because I am curious from this morning glory that it is the same for me, apart from the waving
  • #4 17476872
    19marcin22
    I would also ask for an answer because I have the same problem
  • #5 17551343
    macho1111
    Rate: 28
    It disarms me when someone starts a topic, and doesn't enter a solution later. I have the same problem in 1.6 hdi. After starting up after a night standstill, the car works unevenly for 5-10 seconds and stains white / gray. After a while everything is ok. When I detach the cube from the liquid temperature sensor, the candles heat up and fire normally. Komp crashed 2 fixed bugs. Some short to ground in the heater circuit and no power to the glow plug relay. I suppose the candles are good, since the heating indicator lights up after the sensor shade and the car fires normally, unless I'm wrong.
