Motherboard for Intel i5 7500 within 300-350 PLN Budget, 8GB HyperX DDR4 2133MHz vs 2400MHz RAM
kendziorixx 5781 11
What motherboard should I buy for an Intel Core i5-7500 in a 300–350 PLN budget, and is 8 GB DDR4 2133 MHz or 2400 MHz RAM better for gaming?
Take a B250 motherboard for the i5-7500, because B250 boards are made for Kaby Lake and do not require a BIOS update [#16312469] Within this budget, the Gigabyte B250M DS3H was suggested around 329 PLN, with the GA-B250-HD3P also proposed as an ATX alternative [#16308411][#16308541][#16312948] For RAM, 2400 MHz is the better choice because the i5-7500 supports it, so there is no point in buying slower memory [#16308477] If the CL is the same, the difference between 2133 MHz and 2400 MHz is small and usually not noticeable, and memory timings have only a marginal effect in daily use [#16308411][#16308440]
  • #1 16308253
    kendziorixx
    Hello, I am planning to exchange for Intel and the question is what best to buy a motherboard for I5 7500 in the budget I think 300-350 PLN?
    I have a second question regarding RAM RAM, whether it pays 2133 or 2400 MHZ MHz DDR4, I'm thinking of 8GB HyperX. I care about games, mainly CS: GO.
  • #2 16308411
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    kendziorixx wrote:
    whether 2133 or 2400 MHZ pays off
    If cl is the same then the difference between 2133MHz and 2400MHz is small enough that you won't notice it.
    https://www.morele.net/plyta-glowna-gigabyte-...250m-ds3h-b250-ddr4-hdmi-dvi-vga-matx-976046/
    https://www.morele.net/pamiec-goodram-play-dd...gb-2400mhz-cl15-gyr2400d464l15s-8gdc-1060397/
  • #3 16308440
    Kasek21
    Help: 4981
    Rate: 3547
    cxzcxz123 wrote:
    If cl the same
    Delays still have a marginal effect on performance in daily use.
  • #4 16308477
    rzymo
    Help: 206
    Rate: 322
    2400 - such a processor supports it, so there is no point in taking slower.
    Disc - ATX, MATX? Any other requirements other than that it should work (e.g. m.2 socket)?
  • #5 16308496
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    rzymo wrote:
    Disc - ATX, MATX?
    And you will find an ATX board in this budget?
  • #6 16308541
    rzymo
    Help: 206
    Rate: 322
    H110+ (329,-), PC Mate (365,-), Gaming M3 (369,-), Gaming Pro (369,-)
  • #7 16310577
    kendziorixx
    I would like a model in which you do not need to update the bios, a specific link
  • #8 16310980
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    rzymo wrote:
    H110 + (329, -), PC Mate (365, -), Gaming M3 (369, -), Gaming Pro (369, -)
    It doesn't pay + you would have to update the BIOS.
    I've already given.
  • #9 16312435
    kendziorixx
    You do not need to her bios Update the BIOS to 7500? I wanted to make sure because spptkalem I met with such an opinion on apricots.
  • #10 16312469
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    Boards with the B250 chipset are made for Kaby Lake and you don't need to update the BIOS.
The discussion revolves around selecting a motherboard for the Intel i5 7500 within a budget of 300-350 PLN and the choice between 8GB HyperX DDR4 RAM at 2133MHz versus 2400MHz. Participants noted that the performance difference between the two RAM speeds is minimal, especially for gaming purposes like CS: GO. Recommendations for motherboards included models with the B250 chipset, which do not require a BIOS update for the i5 7500. Suggested models included the Gigabyte GA-B250M-DS3H and GA-B250-HD3P, with some users inquiring about ATX form factors and specific features like M.2 sockets.
