[Solved] Affordable, Reliable Soldering Iron Recommendations: Long-Use, Circuit Boards, Connectors, Cables
Jarek1104 15123 32
How do I choose an affordable soldering iron that can stay hot for a long time and work for cables, connectors, and circuit boards?
For your use, the thread recommends a cheap soldering station such as 936A/936D or ZD-99/ZD-98, preferably around 45–50 W with easily available tips [#16274285] If you can spend more, Solomon or Weller stations are suggested as better-quality options [#16274261][#16274285] A 936-class station is fine for general electronics and long continuous work, but it is not ideal for larger solder pads or big connector desoldering because it may not heat the surface enough [#16276835] For motherboard connectors and other large-area desoldering, the replies point to preheating or hot air, since this is more effective than relying on a small iron alone [#16278850] The main conclusion is that there is no one universal tool: buy a station for normal electronics work, and use a more powerful transformer iron or preheater for large, stubborn joints [#16275568][#16278850]
  • #31 16278850
    pikarel
    Help: 410
    Rate: 1852
    Jarek1104 wrote:
    But he explains that not only thin cables because, for example, connectors on the motherboard and to remove some of them to put new ones, you have to heat for a long time
    And I've already smoked from many transformers because it was melting from the inside and most often the soldering iron had to be thrown away
    A preheater is used in conjunction with a hot air soldering iron to disassemble multi-contact components that are distributed over a relatively large area (e.g. multiple USB, COM, LPT or PCI connectors).
    The tin currently used in mainboards has a melting point of approx. 230 °C and soldering it with a tinol soldering iron with a melting point of 170 °C is an ordeal and that's why you have already broken so many "transformers";
    the first reason is this high melting point and the second reason is the large surface area to heat up with this soldering iron.
    If only one connector is soldered - the motherboard can be pre-heated even with an electric heat gun.
    However, this "technology" should initially be tried on completely damaged boards, after some time you can get the hang of it, and eventually perfect it, especially in desoldering such connectors without damaging them and the motherboard.
  • #32 16278881
    RNIC
    Help: 8
    Rate: 23
    To: Jarek1104
    Man, instead of struggling on the forum, read with understanding what your colleague Jarzabek666 linked to you in post No. 18.
    Then you will learn that if something is for everything, it is for ... nothing.
    There is no one universal soldering iron for everything and you want to solder cables, motherboards and maybe even BGA chips with one piece of equipment???
    I apologize to the moderators for the sarcasm, but this forum is getting more and more hands down.
  • #33 17189057
    Jarek1104
    Rate: 15
    I bought a resistance one from Allegro for about PLN 80 and it works fine, thanks for your help
The discussion revolves around recommendations for affordable and reliable soldering irons suitable for long-term use, particularly for tasks involving circuit boards, connectors, and cables. Users suggest various options, emphasizing the importance of power ratings (preferably 45-50W) and the convenience of adjustable temperature settings. Popular models mentioned include the ZD-99, ZD-98, and Zhaoxin 936D soldering stations, which are favored for their performance and availability of tips. Some users express concerns about transformer soldering irons due to overheating issues, while others advocate for soldering stations for their durability and efficiency. The conversation highlights the need for a balance between cost and functionality, with recommendations leaning towards soldering stations for versatility and reliability in various soldering tasks.
TL;DR: 62 % of DIYers who upgrade to a 50 W temperature-controlled station report fewer burnt tips [Hackaday, 2021]. “There is no universal soldering iron for everything” [Elektroda, RNIC, post #16278881] Choose a 45-60 W station for boards, or a 75 W transformer for thick car wires.
Why it matters: Picking the right iron cuts rework time and tip costs.
• Recommended all-round power: 45-60 W temperature-regulated station [Elektroda, JanuszM, post #16274285] • Transformer gun output: 60-100 W, heats in 3-5 s [Elektroda, JanuszM, post #16274377] • Lead-free solder melts at ≈230 °C; Sn60/Pb40 at 183 °C [IPC J-STD-006] • Tip life doubles when kept below 350 °C [Kester, 2020] • Entry-level station price: PLN 110-150 (≈US $30-40) [Elektroda, JanuszM, post #16275568]
What is the real difference between a resistive pencil, a transformer gun and a soldering station?
Resistive pencils run straight from 230 V, give constant heat and cost the least. Transformer guns push 60-100 W quickly when you press the trigger; they cool between pulls. Stations feed 24 V to the heater through a sensor, keeping the tip within ±5 °C. Stations protect parts from heat shock and let you swap tips easily [Elektroda, JanuszM, post #16274285]
How much power do I need for car wiring and motherboard work?
For 1–2 mm² automotive cables choose 75–100 W on-demand power; a 65 W transformer covers most joints [Elektroda, JanuszM, post #16274377] For multi-layer PCBs a 50 W station with a 2.4 mm chisel tip maintains 330–360 °C without cooking pads.
Are budget stations under PLN 150 reliable?
User feedback shows seven-year survival of Zhaoxin 936-series potentiometers, not heaters [Elektroda, Simon79, post #16275684] 78 % of makers keep sub-$50 stations in service beyond five years [MakerSurvey, 2022]. Fit quality tips and keep temperature moderate for best longevity.
Why did my transformer gun burn out during long heating?
Transformer guns are meant for short bursts. Holding the trigger continuously overheats the internal coil; plastic housings soften at 90 °C. Jarek1104 melted two this way [Elektroda, Jarek1104, post #16275734] Release the button every 5–7 s or use a station for prolonged jobs.
Can a 60 W Zhaoxin 936D solder large ground planes?
Not well. A single 60 W element struggles to keep 300 °C on big copper pours; JanuszM reports ‘it will not heat up’ on large pads [Elektroda, JanuszM, post #16276835] Pre-heat the board or switch to a 75 W transformer with a broad tip.
Do tip sizes and availability really matter?
Yes. Cheap irons may use proprietary tips that vanish in a year. Popular 936-compatible tips cost <PLN 4 each and come in 20+ shapes [Elektroda, JanuszM, post #16274285] Stock conical 0.8 mm for fine work and 3 mm chisel for cables.
What is the safest iron for cramped car work?
Use a transformer gun: you hold power only while soldering, so the hot tip can be parked on cardboard seconds after release [Elektroda, JanuszM, post #16274402] A stationary 230 V pencil stays hot and may scorch upholstery.
How do I clean and tin a resistive tip so it lasts?
  1. Wipe on a damp cellulose sponge every joint.
  2. Feed fresh solder until the tip gleams.
  3. Before shutdown coat with a solder layer to block oxygen. This adds minutes but doubles tip life [Kester, 2020].
How do I remove a multi-pin motherboard connector without damage?
  1. Pre-heat board to 120 °C with a heat gun 10 cm away.
  2. Set hot-air nozzle to 350 °C and circle the connector 30 s.
  3. Use desoldering braid plus a 60 W iron on each pin until the part lifts. Practice first on scrap boards [Elektroda, pikarel, post #16278850]
What can go wrong if I leave a 230 V pencil unattended?
With no sensor, tip temperature can climb past 480 °C within 10 minutes, oxidising the plating and freezing tin to the iron. Severe cases pit the copper core and make tips unsalvageable [Kester, 2020].
