LPG Car Installation: Identify Tank Manufacturer, Serial Number, Construction Date & Capacity
Awes0meApple01 7194 8
  • Identifying LPG tank markings and approval number
    #1 16275818
    Awes0meApple01
    Hello, for several days I have been the owner of a car with an LPG installation, however, it is not embedded in the registration certificate and I do not have any documents on it and I have to make a duplicate, I wrote down all the numbers from the cylinder, but I do not know what is what and I need to provide it, so please help
    GZWM SA GRODKOWO
    D 600 H 200 41.5L
    LPG PH 30 BAR KJ7
    NO.13224 MAX VOL 80%
    E20 67R-010410 CLASSA 1
    10/08 20/08
    And which of these numbers are
    1. Tank manufacturer
    2. Serial number
    3. Year and month of construction
    4. Capacity
    5. Approval mark and number
    Thank you in advance for your help
  • #2 16275947
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    I guess ..
    GZWM SA GRODKOWO
    D 600 H 200 41.5L - length, height, capacity
    LPG PH 30 BAR KJ7 - it's probably what gas, pressure ...
    NO. 13224 MAX VOL 80% - maximum filling 80%
    10/08 20/08
  • Interpreting GZWM tank markings, serial number, date, and capacity
    #3 16275969
    Awes0meApple01
    wojtek1234321 wrote:
    I guess ..
    GZWM SA GRODKOWO
    10/08 20/08
    I mean match these numbers to these 5 points which I gave :)
    Added after 9 [minutes]:
    I think it should look like this (please correct me)
    1. Producer of the GZWM SA GRODKOWO tank
    2. Production Number NR 13224
    3. Year and month of construction 10/08
    4. Capacity 41.5L
    5. E20 67R-010410 approval mark and number
  • Missing LPG installation paperwork blocks registration certification
    #4 16275999
    psooya
    Help: 376
    Rate: 575
    You are in a mega deep D ****
    There is not the slightest chance of inserting LPG into the proof without FV for assembly, approval for installation and the review of paper for the cylinder.
    Of course, someone somewhere someday will do you a trick for a few PLN but looking at it in God's car you can not move and the car itself is not enough that it was sold unfairly, it should not have a review yet.
    janek1815
    Help: 372
    Rate: 1062
    2. Serial number NR 13224
    3. Year and month of construction 2010/08
    4. Capacity 41.5
  • Interpreting LPG tank markings and approval numbers
    #6 16276006
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    I'm not sure, but according to the manufacturer you can see
    http://gzwm.com.pl/7/strona-glowna.html
    Next are the cylinder sizes, the approval number will probably be - E20 67R-010410 CLASSA 1. Perhaps the last one is the date of production / issue of approval 2010.08, and 20/08 may be validity of approval 2020.08.
    these are just guesses but probably right.
  • #7 16276022
    janek1815
    Help: 372
    Rate: 1062
    It may not but certainly is the expiry date of legalization until August 2020
  • #8 16279243
    M. S.
    Help: 259
    Rate: 680
    Psooja is right. Go to the gas company and ask how to deal with the problem at the lowest cost. In order for the authority to make annotation about LPG, you must provide an invoice and approval. TDT decision on review. No features on the tank will help.
  • #9 16279363
    janek1815
    Help: 372
    Rate: 1062
    This is obvious. A few years ago, such a thing cost PLN 240 and that was on the invoice, which was the basis for the entry in the registration certificate of the LPG installation together with the approval document.
The discussion revolves around identifying key details from an LPG tank installation for a vehicle, which is not documented in the registration certificate. The user provided various numbers from the cylinder and sought assistance in categorizing them into the tank manufacturer, serial number, construction date, capacity, and approval mark. Responses clarified that the tank manufacturer is GZWM SA GRODKOWO, the serial number is NR 13224, the construction date is August 2010, the capacity is 41.5L, and the approval mark is E20 67R-010410. Additionally, participants emphasized the necessity of having proper documentation, including an invoice and approval for the LPG installation, to register the vehicle correctly.
