VORDON 7 HD: White Screen After Road Maps Installation - Identify Device & Solutions
RobRa 6522 3
  • #1 16435460
    RobRa
    Rate: 11
    After installation without indicating the device, only a white screen appears.
    Does anyone know what device to indicate during installation to make it work?
    Or maybe the reason lies elsewhere?
  • #2 16435628
    koala106
    Help: 471
    Rate: 1240
    The choice of device during installation does not matter for running on devices with path indication - you only specify to which device the program autostart add-on should be. The reason lies elsewhere - on some firmware versions this is how AM behaves - you must either change the firmware or script to disable system processes that collide with AM.
  • #3 16435666
    RobRa
    Rate: 11
    Does this mean that this software cannot be installed on my device? Maybe some hints?
  • #4 16436359
    jajacekpl
    Help: 65
    Rate: 268
    Copy Automapa to the device, leave the folder with the map on the SD
    AM sometimes so, it does not work with the card
