Lenovo Z51-70: Damaged Radeon R9 M375 Graphics Card Replacement - DIY or Specialist?
5382 9
Can a damaged Radeon R9 M375 GPU in a Lenovo Z51-70 be replaced at home, or does it require specialist BGA equipment?
A home replacement is not realistic; the graphics chip is soldered to the motherboard with BGA and requires specialized equipment [#16278119] The chip should be identified by the marking on its core, not by the laptop model, with one example given as 216-0866000 [#16278632] One reply estimated the replacement cost at about PLN 400-450 [#16279105] Another reply said the job itself costs PLN 150-200 plus the price of the replacement part/system [#16278119]
  • #1 16278117
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    INTERCEPTOR74 wrote:
    Does such a replacement at home probably require specialized equipment?
    Exactly. You can't do it alone. The cost of replacement is PLN 150 - 200 + the cost of the new system.
  • #3 16278358
  • #4 16278410
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    Enter the chip designation.
  • #5 16278626
  • #6 16278632
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    It's about marking the graphics chip, burned on the core.
  • #7 16278636
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Such an inscription is on the core 216-0866000?
  • #8 16278974
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    I just want to know more or less how much it can cost.
    400-450.
  • #10 16288181
The discussion revolves around the replacement of a damaged Radeon R9 M375 graphics card in a Lenovo Z51-70 laptop. The user reports persistent BSoDs when attempting to enable the driver, despite reinstalling drivers and formatting the system. Responses indicate that replacing the card is not feasible for a DIY approach due to the BGA soldering method required. The estimated cost for professional replacement ranges from PLN 150 to 450, depending on the specific graphics chip designation, which is crucial for sourcing a replacement part.
