Expres siemens TK 52001/01 - Laying the gearbox after replacing the drain valve
magiaoka 11427 11
How do I set the clutch/gear position so the brewing unit can be inserted again after replacing the drain valve in a Siemens TK 52001/01 espresso machine?
Set the brewing-unit drive on the other side of the mechanism to its initial position, then fit the clutch as shown in the first photo; the clutch position in the first photo is already correct and it should then work [#16279127] If the machine still does not dispense coffee normally, check that the check valve, pressure pipes, brewing unit, and spout are not blocked [#16289562] The thread also notes that the drain valve itself is a single part and there is no separate assembly diagram for it [#16398995]
  • #1 16278475
    magiaoka
    Rate: 21
    As in the topic, I am writing for help, because in this topic I have no experience, and maybe someone from forum users had such problems. The problem is that after replacing the transmission drain valve and folding, it turned out that the brewing unit cannot be inserted. The clutch in the housing has changed and the flap. Can it be adjusted somehow? I took a photo of what it looks like now and how it should be arranged. If anyone had any experience in this type of fault, I would ask for guidance in operation and resuscitation of the express.
    Expres siemens TK 52001/01 - Laying the gearbox after replacing the drain valve Expres siemens TK 52001/01 - Laying the gearbox after replacing the drain valve
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    The clutch in the first picture is correctly set.
    The initial position of the brewing unit on the other side of the drive should be set as follows:
    Set in this position, put on the clutch as in the first picture and it should work ;)
    Kawa i Naprawa - Serwis AGD
  • #3 16279520
    magiaoka
    Rate: 21
    And super folded. I dismantled and I put together a hula. By the way, the whole mechanism is greased. By the way to a colleague who helped you would not have such a rubber for the clutch as in the photo a little already destroyed and I'd love to replace it. I have already asked in different places but they do not have. Many thanks for your help. Expres siemens TK 52001/01 - Laying the gearbox after replacing the drain valve
  • Coffee flows only after moving the frothing selector
    #4 16288562
    magiaoka
    Rate: 21
    However, I need to drill down the thread. A couple of coffees made and sneezing further. It is true that the water no longer leaks after replacing the drain valve but something else is defective. in which the problem is, after turning on the machine is the normal preparation of the machine for work, but the water does not pour out of the coffee nozzles when I move the switch from the foaming nozzle, the water begins to leak. Then grinds the coffee and the same coffee does not fly until I move the switch from the frothing nozzle, coffee from the nozzles and light water from the frother begins to flow, the switch returns to O and the same coffee stops flying as if something choked the express. Anyone had such problems? Could this be a faulty valve? I would be grateful for any suggestions regarding the correct operation of the express?
    BRum
    Help: 42
    Rate: 388
    The coffee system is not clogged, check from the check valve, pressure pipelines, brewing unit and spout are not blocked.
  • #6 16397325
    boleq1981
    Rate: 18
    Do you have an assembly drawing of this coffee machine? I need it because the valve broke in my hands and I don't know how to fold it.
  • #7 16398246
    BRum
    Help: 42
    Rate: 388
    The new type of valve cannot be folded together, what is your problem with
    inserting into the gear housing?
  • #8 16398995
    nioop
    Help: 503
    Rate: 3337
    After all, the photo here is made ... :|
    There is no such thing as a drain valve diagram. This is one part and does not have a so-called serwisówki ..
    There is also no option for incorrect assembly, unless someone is very "capable"
  • #9 16399137
    magiaoka
    Rate: 21
    As a colleague wrote it is a whole.
    The entire way the valve and spring are arranged is in the first pictures of this topic.
  • #10 17264728
    krysi
    Hello, help please, I disassembled the Siemens coffee machine 52001 and a steel ball came out where it should be very tiny tel 664768422
  • #11 17266227
    nioop
    Help: 503
    Rate: 3337
    The brewing block drive motor is mounted on two small balls in two sides of the rotor. Maybe it's these? ;)
  • #12 17606085
    jpuzik
    it seems like i have the same problem. Could you describe a bit more lopologically how to check it? Do I have to remove and unclog all hoses?
    For me it looks like that
    - once everything goes to the drawer,
    - once it drips a little into the cup, the rest into the drawer
    - and sometimes he'll make coffee normally.
    In a situation where everything goes to the drawer - they normally had coffee, throws everything in the brewing device, something buzzing and finally as if the safety valve released everything and returns to standby. The same in cleaning mode.
    The machine is cleaned and descaled. The brew unit is new.
    In another thread I read that this could also be a problem with the drain valve (https://www.elektroda.pl/rtvforum/topic3114270.html#15142155)
    here too (but for me coffee thrown into the container is not dry - it looks normal as brewed):
    https://www.elektroda.pl/rtvforum/topic3297577.html
The discussion revolves around issues faced after replacing the drain valve in a Siemens TK 52001/01 coffee machine. The main problem reported is the inability to insert the brewing unit after the gearbox was reassembled. Users provided guidance on the correct positioning of the clutch and brewing unit, suggesting adjustments to ensure proper functionality. Additional concerns were raised about water flow issues during coffee preparation, with suggestions to check for blockages in the coffee system and verify the condition of the check valve and pressure pipelines. Some users also inquired about assembly diagrams and the presence of small components like steel balls that may have been dislodged during disassembly.
