[Solved] Samsung Galaxy A3 2016 WIFI Connection Issue: Internet Unavailable with WL-5460AP V2 Airlive Router
blagi99 4830 8
  • #1 16278889
    blagi99
    Rate: 9
    When I try to connect to WIFI, it connects for a while, but then the Internet Unavailable message pops up.
    Everything flashes on the transfer.
    I will add that the router is WL-5460AP V2 (airlive)
    I checked on another phone, WIFI works normally.
    I don't know what to do, help!
    KamGr
    Help: 77
    Rate: 203
    Start by restoring the factory settings on your phone (all data will be deleted).
  • #3 16281034
    blagi99
    Rate: 9
    Thanks crazy for the answer but did not help: /
    KamGr
    Help: 77
    Rate: 203
    And you tried Android upload maybe again?
  • #5 16281259
    blagi99
    Rate: 9
    I haven't tried it, I don't even know how to do it, and does it have anything to do with it? :D
  • #7 16281326
    blagi99
    Rate: 9
    You know what ? I am quite green in these matters, so I prefer not to do anything on my own.
    I did not try to connect to another router.
    Do you think it could be the router's fault?
  • #8 16281329
    KamGr
    Help: 77
    Rate: 203
    I'm not sure but it's always worth a try it may turn out that it is.
  • #9 19125110
    blagi99
    Rate: 9
    A system update helped
The discussion revolves around a Samsung Galaxy A3 2016 experiencing connectivity issues with an Airlive WL-5460AP V2 router, where the device connects to Wi-Fi but displays an "Internet Unavailable" message. Initial suggestions include restoring factory settings on the phone, but this did not resolve the issue. Further advice was given to consider reinstalling the Android firmware using Odin, although the user expressed hesitation due to lack of experience. The possibility of the router being the source of the problem was also raised, with a recommendation to test the phone with a different router.
