Samsung Galaxy S4 Mini: Continuous Power Cycling with Different Batteries - Possible Causes?
mister9933 4473 9
Why does a Samsung Galaxy S4 Mini keep restarting and only show the logo/model after battery changes, and what could be causing it?
The phone is not necessarily dead: it can enter Download Mode, which means you can try restoring the correct firmware with Odin [#16279750] Use the exact GT-I9195 repair firmware, and make sure the binary/bootloader revision is not lower than the phone’s fused version, because the log showed `SW REV CHECK FAIL: Fused 2 > Binary 1` and `FAIL! (Auth)` when an older package was flashed [#16312701] After flashing a different I9195 repair firmware successfully, the phone still kept rebooting at the logo, so the problem was not solved by firmware alone [#16314880] That points to either a deeper software corruption that the repair flash did not fix or a hardware fault rather than just the battery [#16279750][#16314880]
  • #1 16279688
    mister9933
    I already wrote down my phone for losses, thinking that the motherboard failed - similarly stated the service technician. After inserting the original battery, the phone did not respond at all. After inserting a non-original battery, pressing and holding the power button, the phone began to turn on and off. Periodically. But nothing else - it didn't respond to any pressure. After replacing the battery with the original one, the phone would not turn on at all. After replacing the battery again, pressing and holding the button, the phone turns on / off - the model name is displayed, but nothing else. After connecting the phone to charge, the charging picture shows - but only if it is turned off.
    What could be the reason for this behavior of the phone?
    Best regards,
    Michael
    marcin7904
    Help: 138
    Rate: 257
    See if the phone goes in DOWNLOAD MODE - this is the mode that we start with a combination of buttons VOL- + HOME + POWER
    if it enters and won't restart, there is a chance to upload the recovery ROM via Odin.
    I understand that the model is GT-I9195 so you have a repair rom here: Link if a different model, then write and not play with a stick.
    Instructions for uploading 4 files: Link
  • #3 16280057
    mister9933
    Hey, thanks for the answer :-) It looks like you are right because the message popped up: "A custom OS can cause critical problems in phone and installed applications. If you want to download a custom OS, press the volume up key. Otherwise, press the volume down key to cancel . "
    Yes, the phone model is GT-I9195. Thanks for the links and best regards,
    Michael
  • Clarifying Odin options and data impact before flashing repair firmware
    #4 16306094
    gasior
    Help: 112
    Rate: 56
    Hello, I will step on the topic, I have the same situation on my wife's phone.
    What exactly will happen to the phone after uploading this software? What about data and applications?
    Edit: I downloaded the repair file, unpacked it, but instead of the mentioned 4 AP BL CP CSC files I see the list as in the pasted picture. Which options should be marked / unchecked in the ODIN program? I have never flashed my phone before, I don't want to "beat it", so I would like a pathological explanation ...
    Thanks in advance
  • #5 16308779
    marcin7904
    Help: 138
    Rate: 257
    Tag files AP , BL , CP , CSC you put them in the appropriate places in the Odin program.
    You do the same with the file PIT
  • #6 16309141
    beo
    Level 37  
    Help: 298
    Rate: 238
    Colleague @gasior, as you can see, these files are not typically marked. So in BL you load the BOOTLOADER file, in AP the file with the largest size, i.e. CODE, in CP the MODEM file and, CSC probably ;) Additionally, the PIT file, and in Odin's options you select re-partition.
    The most important thing, however, is to be sure that this rom is for your phone model.
  • #7 16309176
    gasior
    Help: 112
    Rate: 56
    And that's what this information was about! Model I9195 so I assume it's ok.
    Thanks and regards.
  • SW REV CHECK indicates a bootloader downgrade mismatch
    #8 16312701
    gasior
    Help: 112
    Rate: 56
    Czy po tym logu jest kto w stanie stwierdzić czy wina leży po stronie nieodpowiednich plików czy telefonu? Z góry dzięki
    Added!!
    Enter CS for MD5..
    Check MD5.. Do not unplug the cable..
    Please wait..
    BOOTLOADER_I9195XXUBMJ7_1901606_REV01_user_low_ship_MULTI_CERT.tar.md5 is valid.
    Checking MD5 finished Sucessfully..
    Leave CS..
    Enter CS for MD5..
    Please wait..
    CODE_I9195XXUBMJ7_1901606_REV01_user_low_ship_MULTI_CERT_.tar.md5 is valid.
    Leave CS..
    Enter CS for MD5..
    Please wait..
    MODEM_I9195XXUBMJ7_1901606_REV01_user_low_ship_MULTI_CERT.tar.md5 is valid.
    Leave CS..
    Enter CS for MD5..
    Please wait..
    CSC_OXA_I9195OXABMJ7_1901606_REV01_user_low_ship_MULTI_CERT_.tar.md5 is valid.
    Leave CS..
    Odin v.3 engine (ID:6)..
    File analysis..
    SetupConnection..
    Initialzation..
    Set PIT file..
    DO NOT TURN OFF TARGET!!
    Get PIT for mapping..
    Firmware update start..
    SingleDownload.
    sbl1.mbn
    NAND Write Start!!
    sbl2.mbn
    sbl3.mbn
    aboot.mbn
    FAIL! (Auth)
    Complete(Write) operation failed.
    All threads completed. (succeed 0 / failed 1)
    Na telefonie ostatnia linijka komunikatu na czerwono:
  • #9 16314880
    gasior
    Help: 112
    Rate: 56
    Ok, znalazłem inny repair firmware I9195XXUCNJ6_YERCNJ3_v4.4.2_Repair_Firmware który zainstalowałem zgodnie z instrukcjami 4-plikowca i wszystko przeszło poprawnie:
    Enter CS for MD5..
    Please wait..
    BL_I9195XXUCNJ6_CL3093013_QB2749460_REV01_user_low_ship_MULTI_CERT.tar.md5 is valid.
    Leave CS..
    Enter CS for MD5..
    Please wait..
    AP_I9195XXUCNJ6_CL3093013_QB2749460_REV01_user_low_ship_MULTI_CERT_.tar.md5 is valid.
    Leave CS..
    Enter CS for MD5..
    Please wait..
    CP_I9195XXUCNJ6_CL3093013_QB2749460_REV01_user_low_ship_MULTI_CERT.tar.md5 is valid.
    Leave CS..
    Enter CS for MD5..
    Please wait..
    CSC_YER_I9195YERCNJ3_CL3081440_QB2781319_REV01_user_low_ship_MULTI_CERT_.tar.md5 is valid.
    Leave CS..
    Added!!
    File analysis..
    SetupConnection..
    Initialzation..
    Set PIT file..
    SingleDownload.
    aboot.mbn
    NAND Write Start!!
    sbl1.mbn
    sbl2.mbn
    sbl3.mbn
    rpm.mbn
    tz.mbn
    boot.img
    persdata.img.ext4
    persist.img.ext4
    recovery.img
    system.img.ext4
    NON-HLOS.bin
    Transmission Complete..
    Now Writing.. Please wait about 2 minutes
    Receive Response from boot-loader
    cache.img.ext4
    hidden.img.ext4
    RQT_CLOSE !!
    RES OK !!
    Removed!!
    Remain Port .... 0
    All threads completed. (succeed 1 / failed 0)
    Natomiast telefon nadal zachowuje się jak wczesniej - próbuje się uruchomić, wywietla logo i model telefonu, restart itd..
    Czy to już cegła?
    Pozdrawiam
  • #10 18210549
    gasior
    Help: 112
    Rate: 56
    I bought a new one ..
    You comment on a post from more than 2.5 years ago ;)
The discussion revolves around a Samsung Galaxy S4 Mini (model GT-I9195) experiencing continuous power cycling issues, where the device fails to boot properly with both original and non-original batteries. Users suggest checking if the phone can enter Download Mode using a button combination (VOL- + HOME + POWER) and recommend flashing a recovery ROM via Odin if successful. Concerns about data loss during the flashing process are raised, along with inquiries about the correct files to use in Odin. Several users share their experiences with flashing firmware and confirm successful installations of repair firmware, addressing the importance of using the correct files for the specific model.
