BK8000L Bluetooth Module: Changing Receiver Name for Custom Wireless Speaker Project
12795 10
Can I change the Bluetooth receiver name shown by a BK8000L module for a custom wireless speaker project?
Yes—you can change the displayed name by dumping the module’s SPI flash, finding the string "BK8000L", replacing it with your own text, and writing the flash back [#16789524] The flash is a standard 25Qxx part, specifically mentioned as 25Q40, so it can be programmed with an Arduino-based flash programmer or an EZP2010 programmer [#16789524][#19007038] The chip is powered from 3.3 V, so a 5 V Arduino needs voltage dividers on the data lines [#19005662] In some cases the SPI flash had to be desoldered to read it properly with a programmer [#17240437]
  • #1 16281872
  • #2 16282920
  • #3 16543934
    uboot571
    Hello, have you found the right module and tested it yet?
  • #4 16544723
  • #5 16545382
    uboot571
    You saw his catalog notes under the link - link . The only thing I noticed was the ability to read his name. Anyway, the PIN can only be read, not changed.
    I wanted to use this module to recognize the owner's phone, but one user made me aware that the module after the loss of bluetooth connection is broadcast for other devices. The subject is here: link
    Can you describe your listening experience, sound quality? Have you used any RC filter on the audio output?
    I also searched similar audio modules and the description of AT commands is repeated. Such cheap modules cannot be fully configured. The only one I've found is a bit more expensive but offering much more from Kamammi
    ESP-WROOM-32 module from the ESP32 family - Wi-Fi / Bluetooth BLE
  • BK8000L name changed by editing flash dump
    #6 16789524
    kuba2k2
    Rate: 14
    With a little practice and light SMD soldering skills you can easily change the name, for example I changed to "Bluetooth Audio". Just make a memory dump, look for BK8000L in it, then change it to anything, and upload the software back. This is a standard 25qXX flash, it can be easily connected to Arduino and program there. If you are interested I can send the program to Arduino which will allow you to easily change the name.
  • #7 17240437
    gradek83
    Help: 930
    Rate: 2104
    SPI FLASH system can be ripped with a programmer but I do not know what it depends on me to rip I had to desolder the chip, otherwise he did not want to rip. I send two dunks. I wonder why UART TX RX communication does not work on this module.
    • BK8000L.flash.bin (512 KB) You must be logged in to download this attachment.
    • dump BK8000L.bin (512 KB) You must be logged in to download this attachment.
  • #8 19005662
  • #9 19006695
  • #10 19007038
    gradek83
    Help: 930
    Rate: 2104
    Select all HEX, copy and paste to HxD program and save as bin. I recommend the EZP2010 programmer
  • #11 19007342
The discussion revolves around the BK8000L Bluetooth module, specifically regarding the possibility of changing its default name displayed on connected devices. Users share their experiences with the module, noting its affordability and functionality, with a range of up to 10 meters. Some participants confirm that it is indeed possible to change the module's name by performing a memory dump and modifying the firmware using an Arduino setup. However, there are challenges related to UART communication and the need for specific programming tools. Recommendations for programmers and methods to extract and modify the module's memory are provided, along with inquiries about volume settings stored in memory.
