BK8000L Bluetooth Audio Module: Incorrect Button Functions - VOL+, VOL-, NEXT, PREV, PP/CALL, MUTE
matti0010 9801 18
Why do the dedicated control pins on my BK8000L Bluetooth audio module trigger the wrong functions, and what are the actual button mappings on this board?
Your module is a different BK8000L board variant, so the button pins are not mapped the way you expected; on this version the buttons have dual functions depending on how long you press them [#16440844][#16377647] VOL+ works as NEXT on a short press and as VOL- on a long press, VOL- works as PREV on a short press and as VOL+ on a long press, and NEXT works as PLAY/PAUSE on a short press and disconnects Bluetooth on a long press [#16440844] PREV, PP/CALL, and MUTE may simply not be implemented on this particular module version, and the exact behavior can depend on the software loaded into the chip [#16377994]
  • #1 16375588
    matti0010
    Help: 8
    Rate: 25
    I just started testing the BK8000L system. Pairing, turning on music etc. works beautifully. The problem is when I want to use the possibilities of dedicated pins for buttons. These are the places marked in red:
    I checked 100 times if I was wrong, but unfortunately it still came out that I plugged in well. The problem is quite strange, namely:
    VOL + - works like NEXT
    VOL- - works like PREV
    NEXT - works like MUTE
    PREV - not working
    PP / CALL - not working
    MUTE - not working
    I have no idea why this is happening, anyone has any idea? Here is more about the BK8000L:
    link
  • #2 16377647
    krzbor
    Help: 42
    Rate: 1072
    I don't know this module, but Chinese ones are sometimes made differently. See: link there are two "red" connection pictures. One is PREV / VOL- and NEXT / VOL +. The "BK8000L" you mentioned is a chip, but the module can be made differently.
  • #3 16377713
    matti0010
    Help: 8
    Rate: 25
    The latter of PREV / VOL- and NEXT / VOL + applies to BK8200, but in fact Chinese systems can be weirdly made. Only now, when I was pushing everything down, it did nothing (I thought that I would burn the module at most). Nevertheless, it would agree with what I have (VOL exchanged with NEXT and PREV). Only how to get there, because I care about VOL the most :(
    Anyone got any idea?
  • #4 16377994
    krzbor
    Help: 42
    Rate: 1072
    Check the chip catalog list and whether the corresponding feet of the integrated circuit are connected to the appropriate pins of the module. I'm worried about the ambiguous descriptions on the integrated circuit pins. Some functions are described on GPIOx outputs, and you are also interested in different ways. This may mean that the operation of the pins depends on the software loaded into the chip
  • #5 16378005
    matti0010
    Help: 8
    Rate: 25
    Yes, this is the second problem I forgot to mention. Catalog information ... has anyone seen, anyone knows? For 2 days searching the internet for datasheets but to no avail ... Maybe I'm unlucky, maybe not. The only meaningful information I found is on the page I gave in the first post. This layout is really interesting and cool, it is worth to be interested in it. However, access to it in Poland and the catalog note strongly deter ...
    I even wonder if he would write to the producer, maybe he has a catalog note ...
  • #6 16440844
    ukixx
    Help: 9
    Rate: 319
    PREV - not working
    MUTE - not working
    link
    So yes, I just got the same module and it's just as you write, with the difference that the buttons have double functions and as long as you hold the button then it works differently.
    VOL + - works briefly like NEXT, long as VOL-
    VOL- - works shortly like PREV, long as VOL +
    NEXT - works like PAUSE / PLAY briefly, long - disconnects BT
  • #7 16440913
    matti0010
    Help: 8
    Rate: 25
    PREV - not working
    MUTE - not working
    link
    In a while I should get another module from China, I will see if it has other functionalities ... because I slowly feel that everyone works as they want (with these buttons).
    Just out of curiosity, you bought because you read this topic or did you (or accidentally) have seen it before?
  • #8 16441260
    ukixx
    Help: 9
    Rate: 319
    Even if you quickly click NEXT twice, it calls back the last number, during the conversation NEXT ends the call and returns to playing music, the call is also answered.
    A friend bought these modules some time ago and I took about a month to start. I'm going to use this to connect the car radio to the phone. The supply voltage must be higher than 3.3V so that there is no low battery alarm. Maybe we will try with RS232 communication. The only thing that works is RESET, only LED0 (PIN 13) works.
  • #9 16441278
    matti0010
    Help: 8
    Rate: 25
    Interestingly, I didn't think about checking these modules. I see that they have much more potential than they wrote on the site. Do you have the opportunity to check if ATa commands are working?
  • #10 16441305
    ukixx
    Help: 9
    Rate: 319
    Since the pinout is a kaleidoscope, I wonder if Rx and Tx will be in places. For now my friend at home is also fighting this module, he has FTDI ready so maybe something will go well, although it is a hard matter because there is nowhere description for this version. Also, do not directly bridge RN and LN outputs to connect headphones, I bridged through 10? resistors and plays, even loudly :) The headphones have 32?.
  • #11 16441313
    matti0010
    Help: 8
    Rate: 25
    If you bridged without a resistor, it didn't play or bits something?
    Don't tell me your friend has another pinout :P I wrote to the "manufacturer" of the system regarding the catalog note, maybe she could explain something, but for a month silence ...
  • #12 16441682
    ukixx
    Help: 9
    Rate: 319
    It didn't move without resistors. You can see the outputs do not start in parallel and it was short-circuiting, now it plays nicely. Rather, it has the same pinout, the modules were in one package, but you can see several versions and the description only for BK8000L.
  • #13 16444111
    matti0010
    Help: 8
    Rate: 25
    Strange, it worked without a resistor. Only at the same time I connected only one amplifier (RN and LN I have a rigidly short tin droplet). PAM8403 burned me, but I do not know why, it is possible that through the speaker because then it turned out that it was damaged ...
  • #14 16459948
    ukixx
    Help: 9
    Rate: 319
    Not only this module pulls about 50mA during operation, and how the communication is 100mA and it does not matter whether it plays loud or quiet, and according to the description should pull 26mA.
  • #15 16459959
    matti0010
    Help: 8
    Rate: 25
    A miracle that works :P The very fact that such a module for 7 PLN does all the work for us with Bluetooth support for audio is already a lot.
  • #16 16543908
    uboot571
    Hello, I am going to use such a module as recognition of the owner (and playing music from the phone). The question is, after pairing with the phone and disconnecting the power supply (or loss of Bluetooth connection), the module broadcasts to other phones or holds the settings for reconnection only with the owner's phone?
  • #17 16543933
    reaven22
    Help: 106
    Rate: 1367
    The module broadcasts to other phones,
  • #18 16544019
    uboot571
    On this page I found a fairly detailed description of this module http://www.electrodragon.com/w/BK8000L " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.electrodragon.com/w/BK8000L
    Theoretically, you could send the following command to the module:
    AT + CC last paired device to connect
    which probably returns the MAC address of the paired device and compare it with the MAC address of the owner's phone saved in the microcontroller.
    Someone can check this command?
  • #19 16585237
    elektryk95
    Hey.
    I need help with this module. I connected it according to what is written in the catalog note. However, after switching on, only one LED1 (red) lights up and that is all. I'm trying to pair with the module by holding the CALL button - unfortunately it is invisible. Has anyone met something like that?
    Greetings,
    Piotr
The discussion revolves around issues with the BK8000L Bluetooth audio module, specifically incorrect button functions when using dedicated pins for volume and track control. Users report that the VOL+ and VOL- buttons are misconfigured, functioning as NEXT and PREV, respectively, while other buttons like PP/CALL and MUTE are non-functional. Suggestions include checking the pin connections against the chip catalog, as the module's pinout may vary. Some users note that button functions can change based on how long they are pressed, indicating potential software or hardware discrepancies. There is also mention of difficulties in finding datasheets and catalog notes for the module, leading to speculation about the need for manufacturer support. Additionally, users discuss power requirements and the module's behavior when disconnected from power or Bluetooth, raising questions about its reconnection capabilities.
