Deante Chili BDS 026M Kitchen Mixer: Replacing Spout Seals & Potential Thread Issues
Shizo 41352 3
  • Removing spout retaining ring to replace O-rings
    #1 16282338
    Shizo
    Rate: 77
    I have a Deante Chili BDS 026M battery after a warranty in which water is collected under the spout. I managed to remove the head, unfortunately I can not get into the O-rings of the spout.
    In the image of another battery found on the Internet, it can be seen that there should be a thread on the ring above the spout
    Will there be a thread in my case? With my hand I can not move it and I would not like to destroy the battery. Do I have to remove it from the sink and put it hard in the vice?
    In general there is a chance to seal this screed without new original seals?
  • #2 16282457
    wzielonymgaju18
    Help: 32
    Rate: 110
    In most batteries there is a thread, try to unscrew, for example, a frog on the sink, just insert it between the battery and the key wipe so that it does not get scratched.
  • #3 16283910
    Shizo
    Rate: 77
    Unfortunately, it was not possible to start up, maybe try to buy a new battery - as out of sheer curiosity for posterity ...
  • #4 16286823
    Shizo
    Rate: 77
    In the Deante Chili battery the bottom ring is unscrewed (at the base) - you must use a strong Frenchman. Gaskets are generally not damaged, they only require cleaning and lubrication with Vaseline and the battery itself removes the stone under and around the gaskets. The topic can be closed.
