Renault Megane II 1.6 - Locate Plus Wire for Connecting Daytime Running Lights After Ignition
diablo113 6702 16
Where can I find an ignition-switched +12V wire under the hood of a Renault Megane II 1.6 for connecting daytime running lights?
The thick yellow wire going to the UPC module next to the battery is the ignition-switched plus [#16286525] You can connect the DRLs there, and there is no need to deactivate the factory lighting system [#16286525] If the switch is in the "auto" position, the dusk sensor will switch on the dipped beam after dark and the DRLs will turn off [#16286525] Another suggested source is the fuse box under the hood, where you can usually find a suitable ignition-fed circuit [#16284875] One reply also mentioned the stop-light fuse or taking power from a lamp, but the UPC yellow wire was the most specific location given [#16289741]
  • #1 16284850
    diablo113
    Rate: 13
    I need to find a place under the hood where there is a plus after ignition because I want to connect daytime running lights there, where can I find a wire?
  • #2 16284875
    szymitsu21
    Help: 342
    Rate: 1292
    look in the fuse box. You can easily find something there. Besides, most DRLs activate when the alternator is energized, yours aren't?
  • #4 16285042
    diablo113
    Rate: 13
    Only I have a built-in automatic for lights
  • #6 16285361
    diablo113
    Rate: 13
    It works on the principle that I have a dusk sensor on the windshield and during the day when I drive, the lights do not shine and when it gets dark, the dipped beam automatically turns on
  • #7 16285542
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3266
    szymitsu21 wrote:
    most DRLs are activated when the alternator is energized, yours aren't?
    The question is about automatic daytime running lights.
    How do yours work?
    Maybe the plus after ignition is unnecessary?
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #8 16285589
    andrzej20001
    Help: 1574
    Rate: 6647
    @ diablo113 it's probably a factory sensor ??
  • #9 16285653
    diablo113
    Rate: 13
    1. This is the factory sensor
    2. Today the lights have come and I'm planning installations tomorrow and I read on the internet that you need to ignite after the ignition, otherwise under the battery it would shine non-stop
  • #10 16285665
    andrzej20001
    Help: 1574
    Rate: 6647
    If I read correctly, you must deactivate the factory low beam with a dusk sensor. And then install those DRLs. You have ignition like a colleague above.
  • #11 16286427
    diablo113
    Rate: 13
    I read on megane forums that it is possible with the sensor
  • #12 16286507
    andrzej20001
    Help: 1574
    Rate: 6647
    Aaah, we will ask for a DIY tutorial.
  • #13 16286525
    milejow
    Help: 1559
    Rate: 5129
    The thick yellow flying to the UPC module next to the battery is ignition.
    andrzej20001 wrote:
    then you need to deactivate the factory low beam with a dusk sensor
    You do not need to deactivate anything, the lights in the "auto" position and after dark, the factory sensor will turn on the dipped beam and turn off the daylight (because they will get a signal from the position)
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #14 16286747
    diablo113
    Rate: 13
    Is it enough to connect to it?
  • #15 16288777
    milejow
    Help: 1559
    Rate: 5129
    Not only for power supply and plus items.
    Działalność własna
  • #16 16289627
    diablo113
    Rate: 13
    And can you give a photo or accurately determine the location of this wire in which you need to stick?
  • #17 16289741
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1705
    You can take the lamp but you have to remove the bumper.
    Or to the fuse from the stop under the hood.
    Only in the car they go out after opening the driver's door, not after turning off the engine.
✨ The discussion revolves around locating a wire under the hood of a Renault Megane II 1.6 to connect daytime running lights (DRLs) after ignition. Participants suggest checking the fuse box and specifically mention a thick yellow wire leading to the UPC module next to the battery as a suitable connection point. The conversation also touches on the vehicle's built-in automatic light system, which includes a dusk sensor that activates low beams in low light conditions. Users clarify that the factory sensor can remain active while installing DRLs, and some seek further details, including photos or precise locations for the wire connection.
