Laguna II - Where can I find + 12V after ignition in the engine compartment (for
rabbit2 9348 6
  • #1 16312769
    rabbit2
    Help: 31
    Rate: 357
    Hello. As in the topic, where in the engine compartment I will find + 12V after ignition? So that you can use them to power the LED daytime running lights. Maybe someone has already installed in such a car and will give details where to look? I must admit that I would prefer to avoid unnecessary digging, so I ask. By the way, it would be nice to create such a topic, where you could share such information, e.g. where and what to connect when connecting daytime running lights in a specific car model? The topic of daytime running lights is becoming more and more popular, it would create a separate topic that could be helpful for many. Regards.
  • #2 16312785
    bubu1769
    Help: 1177
    Rate: 2374
    When I am at home I will see how I connected it because I don't remember. Associates with a relay in parallel and the shutdown normally for the parking line.
  • #3 16312814
    mirek-zuza
    Help: 5
    Rate: 12
    Usually there is a plus after the ignition switch on the reverse gear sensor.
    bubu1769
    Help: 1177
    Rate: 2374
    I took the power supply from fuse No. 2, ground from the battery clamp and signal from the parking line.
  • #5 16313596
    rabbit2
    Help: 31
    Rate: 357
    .... and thank you very much, briefly and to the point. The topic could be opened so far, maybe someone will be interested in the second part of the first post. Thank you again .
  • #6 17237287
    szansa
    Rate: 11
    Effective and almost universal way (because easy access to cables)
    Minus - with a clamp or a convenient screw on the body
    + ACC - "excitation" cable on the alternator (it works in every car)
    + from parking - in Lagoon 2 it is convenient on the plug near the battery. Plug attached to the battery base.
    Viewed from the front of the vehicle - the first column of cables on the right, the third wire from the top.
    Check with meter.
    What gives + ACC from an alternator?
    After inserting the card lightly you have the radio on etc.
    After inserting the card fully, you have all kinds of active functions, you do not harm the anglers with light
    After starting the car, + appears and lights up daily.
    And this "cable" usually has easy access.
    Good luck
  • Alternator excitation terminal questioned for ignition feed
    #7 21945659
    Pan.Kropa
    Help: 252
    Rate: 1178
    szansa wrote:
    + ACC – ‘excitation’ cable on the alternator (this works in every car)
    Sorry for bringing up an old topic. But are you sure the +ACC is suitable for this? One of the wires from the daytime running lights, which is supposed to be connected to the + that appears when the ignition is switched on, is used to power those lights. Are you absolutely sure the alternator’s +ACC terminal is suitable for this? Will there be sufficient current capacity there? Won’t this put too much strain on the diodes in the alternator? Etc.
The discussion focuses on locating a +12V power source after ignition in the engine compartment of a Laguna II for the installation of LED daytime running lights. Users suggest various methods, including connecting to the reverse gear sensor or using fuse No. 2 for power supply. One user mentions accessing the ACC cable on the alternator, which provides power when the ignition is engaged. Additionally, a specific wire near the battery is identified for the parking signal connection. The conversation highlights the need for a dedicated topic to share installation tips for daytime running lights across different car models.
