Low Hot Water Pressure in Shower: Junkers Not Igniting vs Flawless Sink Flow & Normal Cold Water
weronik 9282 3
  • #1 16284927
    weronik
    The hot water pressure in the shower is so low that the junkers don't catch fire. By contrast, at the sink, hot water flows flawlessly and the junkers light up. What may be the problem? I would add that the cold water pressure in the shower is at a normal level.
  • #3 16285097
    weronik
    I will check it, thank you for the hint.
  • #4 16293736
    wiesiekmisiek
    Help: 259
    Rate: 524
    The hose or shower head may also be clogged, so if the strainer is clean, unscrew the hose from the faucet and let the water run, although I would do it first before I decided to unscrew the faucet to check the strainers.
