[Solved] OR-PRE-409 ORNO Electronic Timer (2015 Batch) - Display On, Program Not Starting, Manual Activation
Robcio1980 9045 8
  • #1 16292523
    Robcio1980
    Rate: 11
    I am the owner of 2 electronic programmers OR-PRE-409 ORNO (I bought them in 2015 from the same batch), for about two weeks both programmers have stopped working.
    Everything is displayed on them but the set program on them does not start, even the manual start from AUTO to ON does not activate the programmer.
    I reset the settings again and unfortunately no effect.
    Or maybe someone had a similar case what can be done to fix programmers.
  • #2 16294029
    Paweł Es.
    Help: 1236
    Rate: 693
    And what battery they hold the clock and the settings they don't have inside?
    Possibly, if they did not destroy any power surges in the network since they fell at the same time?
  • Check relay operation and contacts, possibly claim warranty
    #3 16294056
    Adam-T
    Help: 834
    Rate: 1096
    Robcio1980 wrote:
    I am the owner of 2 OR-PRE-409 ORNO electronic programmers (I bought them in 2015 from the same batch),
    I looked at the instructions and there the manufacturer declares a 24 month warranty. We have the beginning of 2017, maybe they are still under warranty.
    What do these programmers control? Most often the executive element is a relay. When the programmer is to turn on, listen to it clicking (quiet)? Burned contacts of this relay are also possible. Unfortunately, it's just a shag. You have to undress and measure.
  • Replaced Ni-MH battery did not restore timer operation
    #4 16294111
    Robcio1980
    Rate: 11
    There's a Ni-MH battery inside, but I've already replaced them and I thought it would start working but without effect. I was also wondering if there was a surge but probably not because 2 other older programmers work without a problem
    The warranty has already expired. Unfortunately, this click cannot be heard as it was with programmers working
    Added after 7 [minutes]:
    Both programmers control lighting
  • #5 16294167
    Adam-T
    Help: 834
    Rate: 1096
    Measure the voltage on the relay coil when it is to be switched on. See what is controlled. You can also upload clear pcb images from both sides.
  • #6 16380294
    Eidems
    Help: 83
    Rate: 253
    These programmers are useless, I bought a new piece and the programmer worked once, a failure (good that I have a receipt). Purchased GTV programmer for 22 PLN works better than the one for about 32 PLN. I do not recommend.
  • #7 16382669
    GTV_1
    Eidems wrote:
    Purchased GTV programmer for 22 PLN works better.
    Thanks ;)
  • #8 16382745
    Eidems
    Help: 83
    Rate: 253
    GTV_1 wrote:
    Thanks ;)
    Let's not make a GTV ad, it is Chinese, as everyone else depends on how it goes. The best solution is to buy aurotona 100 (3 years warranty), different from all other programmers, better build quality, longer warranty and does not look like a thousand other Chinese ;) . However, it's better to contribute and have something for years.
  • #9 20525751
    Robcio1980
    Rate: 11
    The programmer was sent out under warranty and sent back in working order
The discussion revolves around issues faced by the owner of two OR-PRE-409 ORNO electronic timers, which have stopped functioning despite displaying information. The user has attempted resetting and replacing the internal Ni-MH batteries without success. Responses suggest checking for power surges, verifying relay functionality, and measuring voltage on the relay coil. The warranty has expired, and some users express dissatisfaction with the ORNO brand, recommending alternatives like the GTV and Aurotona 100 for better reliability and longer warranties.
