Samsung Galaxy S6 Edge - Screen does not work after charging the battery
131XIII 8622 9
Why does a Samsung Galaxy S6 Edge show only the LED and no display after being left on the charger overnight, and how can it be fixed?
Try forcing a restart by holding the power button down for up to 30 seconds; in this case, the phone started working again when the power switch was held with a rubber band while it was connected to the charger, and after a few minutes it booted up [#16382815][#16403416] Another suggestion was a damaged battery, but the reported fix was the button/forced-start workaround rather than a screen replacement [#16382181][#16403416]
  • #1 16382148
    131XIII
    Rate: 48
    My friend has the S6 Edge, everything worked without a problem, he did not have any close encounters with the ground. And one day he connected the phone to the charger for the whole night, and in the morning the phone stopped responding to the screen, the LED is lit but there is no reaction from the display.
    Any idea?
    Thanks in advance for your answers
  • #2 16382181
    funak
    Help: 101
    Rate: 461
    Damaged battery, it's such a quick idea. That's how I got from Galaxy S2. The phone discharges the battery to a total zero. I bought a new battery. I put it on, it discharged to zero - the battery is not alive - it gives no tension. The phone is now lying and waiting for better times.
  • #3 16382278
    131XIII
    Rate: 48
    Well okay, but even hooked to the charger nothing displays; /
  • #4 16382815
    sylweksylwina
    Help: 1882
    Rate: 2355
    Hold the switch for up to 30 seconds. If it does not help, then the website will be more.
  • #5 16383191
    bogdan2491
    Help: 52
    Rate: 97
    The phone has a service history?
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    No guarantee ??
    I bet the plate does not heat up in the back?
    And so I ask colleagues from another barrel you also have that the customer leaves the phone for the night on the charger wakes up and there is a smashed LCD in the morning :) how many times I had such cases, imps on the heels are crazy at night
  • #7 16383428
    131XIII
    Rate: 48
    There is no service history
    There is no guarantee because there is no book
    Well, let me try to let you know later
  • #8 16383489
    sylweksylwina
    Help: 1882
    Rate: 2355
    The fact that the books do not have this is not a problem, often the same proof of purchase. If it was bought from an operator, it probably already has everything entered in the system.
  • #9 16393874
    131XIII
    Rate: 48
    There is no guarantee, it ended, I have to combine on my own ;)
    The computer can not see the phone at all
    The diode shines green every now and then
  • #10 16403416
    131XIII
    Rate: 48
    Ok, the problem solved, I wrapped the switch with the rubber band, I hooked it to the charger and after a few minutes he added
The Samsung Galaxy S6 Edge experienced a non-responsive screen after being charged overnight. Initial suggestions included a potentially damaged battery, as one user recounted a similar experience with a Galaxy S2. Other responses recommended holding the power button for 30 seconds to reset the device. Concerns were raised about the phone's service history and warranty status, with one user noting that the phone was not recognized by a computer and the LED indicator was intermittently green. Ultimately, the issue was resolved by applying pressure to the power button with a rubber band while charging, which restored functionality after a few minutes.
