Renault Scenic II 2004: Display Out, Red LED, Radio & A/C Function, Turn Signal Sound
rafal2353 7005 9
Why does the Renault Scenic II display stay dead, with the red LED and turn-signal sound not working, even after swapping in another display of the same model?
The likely fix is to transfer or convert the 93c56 EEPROM in the display; simply swapping the unit may not be enough. One user first found the replacement display was also faulty, then got a working one and reported that converting the 93c56 made it work [#16296495][#16296871][#16297533]
  • #1 16293840
    rafal2353
    Good morning,
    I have a problem with the display in Renault Scenic II 2004, namely the display has gone out, and the red blinking LED on the display does not work. The radio and air conditioning work, only the sound is not heard when turning on the turn signals. I replaced the display with another one of the same model and it also doesn't work. Thanks in advance for the tips.
  • #2 16294085
    zvwoms
    Rate: 8
    Also broken
  • #3 16294443
    bodzio012
    Help: 161
    Rate: 782
    Have you checked the fuses?
  • #4 16295303
    zvwoms
    Rate: 8
    Hehehe
    From the counter. Then maybe write where to look for them, what a ...
    Moderated By CameR:
    Reg. 3.1.9. Do not be ironic and do not be mean with the other side of the discussion. Please respect dissenting opinion and other opinions in the forum.
  • #5 16295363
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6439
    This is how such a fault is checked when checking the power supply.
  • #6 16295844
    zvwoms
    Rate: 8
    You don't do with the counters in SII, what are you talking about? And it's also a moderator!
  • #7 16296495
    rafal2353
    It turned out that the second display is also damaged (allegro). Today I found another one on the road and it works. Only the mileage from 182 thousand to 33 thousand, does anyone know how to change it?
  • #9 16296899
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    Also check if the radio works.
  • #10 16297533
    rafal2353
    Converting 93c56 helped. Subject to be closed
The discussion revolves around a malfunction in the display of a Renault Scenic II 2004, where the display is non-functional, the red LED is blinking, and there is no sound from the turn signal. The user replaced the display with another unit of the same model, but it also failed to work. Suggestions from other users included checking the fuses and ensuring the radio functions properly. The user later discovered that the second display was also defective but found a working display. They inquired about changing the mileage on the new display, which was resolved by soldering the 93C56 chip.
