Renault scenic II - Replacing the radio and the multifunction steering wheel
rafal2shae 7347 8
  • #1 16294025
    rafal2shae
    Rate: 46
    Do you know if you can replace the original Scenica II radio with another so that it can be controlled with the multifunction steering wheel?
    Thank you
  • #2 16294072
    sanfran
    Help: 966
    Rate: 3008
    And since when do you control the radio in Scenic from the steering wheel?
    In this car, only the cruise control is from the steering wheel.
    And when it comes to the multifunctional remote control, there are adapters.
    Share on Google: renault radio controls adapter interface
  • #3 16294559
    rafal2shae
    Rate: 46
    Since 2005, they have always had a multifunctional steering wheel, of course, not everyone controls the volume with which I change the waves, searches for radio waves. I do not have a cruise control.
  • #4 16295004
    sanfran
    Help: 966
    Rate: 3008
    Can you share a photo of this steering wheel?
  • #5 16295099
    rafal2shae
    Rate: 46
    I'll send you this afternoon.
  • #6 16296647
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    No way.
    Radio control is under the steering wheel, not on the steering wheel.
    I bet you weren't even in that car.
    We are waiting for this photo.
  • #7 16308056
    rafal2shae
    Rate: 46
    Yes, the steering is under the steering wheel in the column, but in all papiras it is classified as a multifunction steering wheel, but the topic is not about it. The topic is how to set up a different radio so that the buttons under the steering wheel fulfill their function.
  • #8 16308595
    sanfran
    Help: 966
    Rate: 3008
    rafal2shae wrote:
    Yes, the control is under the steering wheel in the column, but in all papiras it is classified as a multifunction steering wheel
    There is no such qualification and never has been.
    rafal2shae wrote:
    but the topic is not about that. The topic is how to set up a different radio so that the buttons under the steering wheel fulfill their function.
    Your question was answered in the second part of post # 2.
  • #9 16315303
    wiesiek_rog
    Rate: 17
    Most likely, your dash display won't work anyway. So let it go. Too bad for the west.
The discussion revolves around the possibility of replacing the original radio in a Renault Scenic II while maintaining functionality with the multifunction steering wheel. Initial responses questioned the steering wheel's control capabilities, clarifying that the radio controls are located under the steering wheel rather than on it. The author confirmed that the Scenic II has a multifunction steering wheel, which can control volume and radio stations, despite lacking cruise control. However, concerns were raised about compatibility issues with aftermarket radios and the potential for the dashboard display to malfunction if a different radio is installed. Adapters for radio control were suggested, but the feasibility of full functionality remains uncertain.
