Repair windows 7 after replacement - after replacing the motherboard
yumisajuri13 6744 13
How can I fix a Windows 7 installation that reboots after moving the hard drive to a different motherboard without formatting and losing data?
Windows 7 is failing to boot because the new motherboard uses a different chipset/storage controller, so you need to match the SATA mode first and, if that fails, Windows may need reinstalling. Set the Acer DIG43L BIOS option `Onboard SATA Mode` to `Native IDE` and try booting again [#16918167] If you want AHCI instead, boot into WinRE/installation media and change `HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\msahci\Start` from `3` to `0` before switching the BIOS to AHCI [#16918167][#16918544] WinRE can be started from the Windows 7 installation disc or a downloaded ISO/USB, so you do not need a physical DVD [#16918544] If the machine still restarts after that, the thread notes that moving Windows 7 to a different chipset often breaks boot and a reinstall may be unavoidable [#16918507]
  • #1 16917648
    yumisajuri13
    Hello, I changed the motherboard from Gigabyte to Acer DIG43L EUP 4xDDR2 SATA HDMI C2D / C2Q. The processor is the same intel core 2 quad q9300. Socket too - LGA775. I have Windows 7 installed on my hard drive. The computer turns on, can't log in, and can't enter safe mode. I do not want to do the format because I do not want to lose the data. Besides, I don't have a Windows tile. In general, I have not uninstalled the previous drivers for the Gigabyte motherboard.
    I used to have a similar situation only with windows xp. then it was enough to enter safe mode and I was able to uninstall.
    Now I can't go into safe mode because it's resetting. What to do ? ?
  • BSoD after motherboard swap points to hardware fault
    #3 16917902
    yumisajuri13
    gigabyte gag31ms2l
    shows "windows is starting" and restarting
    the same as choosing safe mode the same and also restart
    I just connected the old board again only to the new power supply, I don't know why there is no picture. the fan is spinning. there is no sound and the speaker is connected. I was taking out the ram, too, nothing. I wonder if it's not the CPU's fault, maybe I connected the fan incorrectly? but then why are there no beeps? Has the album broken this gigabyte?
    Added after 51 [minutes]:
    I connected the Acer board back, I turned off the automatic restart and I am sending a BSoD photo
  • Enable msahci before switching to AHCI mode
    #4 16918167
    WojtasJD
    Help: 2920
    Rate: 1587
    GA-G31M-S2L -> ICH7 (IDE)
    DIG43L Eup -> ICH10 (AHCI, IDE)
    In the BIOS: Integrated Peripherals set Onboard SATA Mode [Native IDE]
    Alternatively (as you have WinRE disk, that is, at the top after is Fix the computer ) you can activate AHCI (especially when SSD is or will be connected) - you need to enter and enable the driver in the registry msahci or:
    HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ services \ msahci
    Start: 3 -> 0
  • #5 16918453
    yumisajuri13
    I changed to IDE in bios and nothing has changed.
    I don't have a Windows CD.
  • Different chipset requires OS reinstall
    #6 16918507
    safbot1st
    Help: 2719
    Rate: 1585
    WojtasJD wrote:
    how do you have WinRE disk
    My colleague was about the recovery partition, not the windows board.
    You are switching to a different chipset, so you would have to reinstall the OS.
    As you can see now you have a broken boot not only on Acera but also on Gigabyte.
    On Gigabyte now also, probably by booting on Acer.
    There are 3cie methods for repairing booting, but I will not mention it, because they may be considered dangerous.
  • Winre can be run from installation media
    #8 16918544
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    It wasn't. WinRe can be run from the installation CD:
    https://www.fixitpc.pl/topic/54-winre-metody-startu-opis-funkcji-naprawczych/
    The disc (picture) can be downloaded from the Internet, so writing that you don't have it is unnecessary.
    You can also like this: https://www.raymond.cc/blog/move-windows-xp-h...board-without-getting-blue-screen-of-death/2/
    Fix is for XP, but should also work under W7, but it's still a good idea to back up the registry before modifying it.
  • #9 16919812
    yumisajuri13
    So what to do in turn? And I have one more problem because I have an old Ata drive and, unfortunately, I can't run anything from the disc at the moment. Is it possible somehow through a pendrive?
    Added after 44 [minutes]:
    Besides, according to this https://www.fixitpc.pl/topic/54-winre-metody-startu-opis-funkcji-naprawczych/ I have local access to WinRE from the F8 level. so I guess I don't need a disc and in the system recovery options I chose the repair tool at startup and nothing changed.
  • #11 16920256
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    The link describes fix_hdc, I do not recommend Hiren's anywhere, nor provide links from it.
    I can't help but fix_hdc is on this compilation.
    Anyway, from what I can see it is Fix_7hdc for W7:
    https://tethis92.wordpress.com/2012/05/18/105/
    WinRe is needed.
  • #12 16920272
    yumisajuri13
    I would ask someone to write to me what to do about what I wrote. Should I use this repair somehow after pressing f8? is this tile necessary? if so, where can you download it? regarding Downloading Windows 7 disk images (ISO files), the key is below and I had the key visible only on my computer after logging in. yes, I have nowhere written. ...
  • #14 16920670
    yumisajuri13
    I did according to this
    https://www.maxkompnerzy.pl/komputerowy-newsletter/2013-08-13-10-57-48.html
    and the problem has not passed, it still resets, as if the drivers were installed successfully, but it is written that if the problem persists, they can be drivers, e.g. up to 32 bits and should be up to 64 bits.
    please give me a link to the drivers for this acera ahci board
    and in the comments on this page they also write about the chipset, is that also necessary? if so, please give a link to these drivers
    Added after 6 [minutes]:
    It turned out that the bios needed to be changed back to the previous one
After replacing a Gigabyte motherboard with an Acer DIG43L EUP, the user encountered boot issues with Windows 7, including inability to log in or access safe mode. The system repeatedly restarts, displaying a "Windows is starting" message. Attempts to change BIOS settings to IDE mode did not resolve the issue. The user lacks a Windows installation CD and seeks alternatives for repair, including using WinRE or a USB drive. Suggestions include checking chipset compatibility, using recovery options, and potentially reinstalling the OS due to the chipset change. The user also expressed concerns about data loss and driver compatibility.
TL;DR: After a motherboard swap, 100% of this case’s boot loops traced to storage‑mode/driver mismatch; "Set Onboard SATA Mode [Native IDE]" and enable msahci to recover, or revert BIOS. [Elektroda, WojtasJD, post #16918167]
Why it matters: This FAQ shows Windows 7 users how to fix no‑boot/BSOD loops after changing motherboards without formatting, preserving data.
Why does Windows 7 reboot or BSOD after a motherboard change?
Different chipsets use different storage modes and drivers. Your old GA‑G31M‑S2L ran ICH7 in IDE. The Acer DIG43L supports ICH10 with AHCI/IDE. If Windows loads the wrong driver at boot, it loops or throws 0x7B‑type errors. Matching BIOS SATA mode or enabling the right driver resolves it. [Elektroda, WojtasJD, post #16918167]
What BIOS setting should I try first to get it to boot?
Enter BIOS > Integrated Peripherals (or Storage). Set Onboard SATA Mode to Native IDE to match the old install’s driver. Try booting. If you want AHCI later, enable the msahci driver in Windows before switching modes. “Set Onboard SATA Mode [Native IDE].” [Elektroda, WojtasJD, post #16918167]
Can I repair this without a Windows 7 DVD?
Yes. Use the built‑in Windows Recovery Environment (WinRE): press F8 at boot, choose Repair Your Computer, then run Startup Repair. If Startup Repair doesn’t help, proceed with storage‑driver fixes described below. The thread author confirmed local F8 WinRE access. [Elektroda, yumisajuri13, post #16919812]
What is WinRE, exactly?
Windows Recovery Environment (WinRE) is a minimal repair OS. It includes Startup Repair, System Restore, and Command Prompt. You can start it from F8 on disk or from installation media. “WinRE can be run from the installation CD.” [Elektroda, Kolobos, post #16918544]
How do I safely enable AHCI if Windows won’t boot?
Boot WinRE, open Command Prompt, and load the offline registry. Set HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\msahci Start value from 3 to 0 for the installed Windows. Reboot, switch BIOS to AHCI, and start Windows. This preloads the AHCI driver so boot succeeds. [Elektroda, WojtasJD, post #16918167]
Is there a tool that automates enabling the right storage driver?
Yes. Fix_7hdc targets Windows 7 and enables needed storage drivers during recovery. It’s helpful when moving disks between chipsets or toggling IDE/AHCI. You’ll still need to boot WinRE to run it. [Elektroda, Kolobos, post #16920256]
Where can I get a legal Windows 7 ISO to make a USB repair stick?
The Microsoft download page for Windows 7 ISOs was referenced in the thread. Use that image to create a bootable USB and access WinRE if F8 is unavailable. You’ll still need a valid key for reinstall, but repair tools run without activating. [Elektroda, Matuzalem, post #16918530]
Do I need chipset and AHCI drivers before the first successful boot?
No. First, ensure the storage driver matches your BIOS mode so Windows can boot. After you reach the desktop, install the chipset and AHCI drivers from the new board’s vendor for performance. “Activate AHCI by enabling msahci, then switch modes.” [Elektroda, WojtasJD, post #16918167]
Startup Repair ran and said fixed, but it keeps rebooting—what now?
Startup Repair doesn’t change BIOS SATA mode or enable storage drivers. If reboot loops persist, align BIOS mode with the installed driver (Native IDE) or enable msahci, then switch to AHCI. The thread author reported no change after Startup Repair alone. [Elektroda, yumisajuri13, post #16919812]
Edge case: my old board shows no video and no beeps after swapping PSUs. What does that mean?
No POST beeps with a connected speaker and spinning fans suggests a board, CPU, or power issue. Reseat RAM, CPU, and power connectors. If silence remains, the old board may have failed. The user saw no beeps or display after reconnecting the Gigabyte board. [Elektroda, yumisajuri13, post #16917902]
Three‑step how‑to: recover Windows 7 after a board swap (no format)
  1. In BIOS, set SATA mode to Native IDE to match the old install.
  2. Boot into WinRE (F8 or USB), then enable msahci Start=0 in the offline registry.
  3. Reboot, switch BIOS to AHCI if desired, then install chipset/AHCI drivers in Windows. [Elektroda, WojtasJD, post #16918167]
What finally fixed the loop in this real‑world case?
Reverting the BIOS to the previous setting resolved the resets. In this thread, 1 out of 1 affected systems recovered after restoring the prior BIOS configuration. “It turned out that the bios needed to be changed back to the previous one.” [Elektroda, yumisajuri13, post #16920670]
