Windows Won't Start, Stuck in System Recovery Options Loop, Safe Mode Issue, Direct & Temp Files
Dziulekk 9645 5
  • #1 16786593
    Dziulekk
    Welcome friends. For about two days I have been struggling with a very bad glitch on my PC.
    Every time I start the computer, the Windows system does not start, only the "System Recovery Options" window pops up, after scanning, the window pops up that everything is git and resets, after which the same thing happens again.
    It is like that every time. Windows can't be started even in safe mode, because it's the same.
    I don't know what the reason may be. The only thing I did before it stopped working was installing direct and removing "temp" files
    I need your help what to do to restore his fitness. - I don't want the format because I have important files on my computer.
  • #2 16786642
    kokapetyl
    Help: 1787
    Rate: 2101
    First, enter the full hardware configuration.
    Also enter SMART disk (because the system does not start) then using MHDD.
  • #4 16786671
    Dziulekk
    I don't remember exactly the specifications of my computer. Can it be checked somewhere in the bios or something?
    By MHDE you mean the second disk? If so, I have to worry you and myself, because I have only one disk. (I don't know much about IT, I can only format and fix some small bugs)
    Windows 7.
  • #5 16786702
    kokapetyl
    Help: 1787
    Rate: 2101
    I made the MHDD mistake it was meant to be. No second disk needed. You burn this program to a CD and create a boot disk from it, and start your computer from it.
    https://www.elektroda.pl/rtvforum/topic1550200.html
    After running, give only the command "F8" then we will get a SMART disk.
  • #6 16786877
    Dziulekk
    PS-Hitachi HDS721616PLAT80
    that's my hdd.
    So, rather without the use of third-party programs it is impossible to solve this problem? I don't have any free board to even go to a friend to rip these various programs ?
