Bosch SPS53E02EU dishwasher - error E19. I am looking for transistors or substit
Stachu0204 11157 7
  • #1 17261614
    Stachu0204
    Help: 8
    Rate: 64
    Good day.
    I will complete the model as soon as I can :) It's probably the SMS series was (with the control module at the back bottom right) In any case, a solenoid valve burned in a water jacket and transistors (in SOT223 housings) went with it:
    STN83003
    STN9260
    Does any of your colleagues have such and even dismantling? Or though he is able to give the idea to a more available replacement. It can even be in a different housing.
  • #6 17261885
  • #7 17396787
    _prusak_
    Help: 19
    Rate: 211
    Colleagues are looking for a transistor STN83003 . Has anyone already found / ordered and can sell it? Is a replacement MJE13003 will it be right?
  • #8 17396852
    JacaP30
    Help: 16
    Rate: 55
    _prusak_ wrote:
    Will the MJE13003 replacement be right?
    As best as possible, put it in a bold way.
The discussion revolves around the Bosch SPS53E02EU dishwasher, specifically addressing the E19 error and the need for replacement transistors after a solenoid valve failure. The transistors in question are STN83003 and STN9260, which are housed in SOT223 packages. Users provided links to suppliers where these components can be found, noting availability issues and minimum order quantities. A potential replacement for the STN83003, the MJE13003, was also suggested. The conversation highlights the challenges in sourcing these specific components and the search for alternatives.
