Crack TravelPilot FX Blaupunkt Safety: Ford C Max 2007-2010 User Experiences & Advice
maj michał 12255 10
Is the cracked TravelPilot FX Blaupunkt update safe to use on a Ford C-Max 2007-2010?
Yes, the thread suggests it works well and is generally safe to use, with no indication that it wipes the whole radio memory [#16296384] [#16299181] The only data it is said to affect are some settings and navigation route history; the maps themselves stay on the CD or SD card, and only part of the navigation software is updated from the carrier [#16299181] You should have the radio code ready, because after the update you may need to enter it again as if the battery had been disconnected [#16299181] One user also reports a slight delay before the “no disc” message appears after switching with the CD/AUX key [#16296384] Another confirms the Polish menu works, and if Polish is not visible you may need to switch from the Polish language to another English option and then back to English/Polish as described [#17062709] If you have a BT/VC/USB module, updating its firmware is recommended for better compatibility with newer phones [#16296384]
  • #1 16296050
    maj michał
    Is the Crack TravelPilot FX Blaupunkt on the forum for Ford C Max 2007-2010 safe?
    Does anyone have any experience in this topic? I am asking for advice.
  • #2 16296384
    _siekier
    Help: 77
    Rate: 118
    I have the mk2 fl focus, but it's basically the same as your c-max. In my opinion, the crack works very well. One minus I have noticed is a slightly long time displaying the message about the lack of a disc in the drive after switching with the cd / aux key. It is also worth updating the bt / vc / usb module firmware if you have one - the cooperation with newer phones will be improved, i.e. the function of the hands-free set and music transfer via bluetooth.
  • #3 16296672
    maj michał
    Is this crack really mean? Did you use this file yourself? I'm scared not to delete everything from the radio's memory https://pliki.elektroda.pl/733137,travelpilot+fx+pl+menu.html
  • #4 16299181
    _siekier
    Help: 77
    Rate: 118
    Do you know the code for the radio?
    Yes, this file.
    What do you have in your memory of the radio? A bit of settings, route history from navi and that's all, you have maps on cd (but it's very old maps) or sd card, these radios don't copy maps to internal memory, they copy (update) only part of the navigation software from the carrier. I have a map card, so I just finished playing at 9.
    Then enter the code into the radio as when disconnecting the battery, or change the language in the settings as given in the description, and that's all.
  • #5 17062709
    michmarmik
    Rate: 12
    I confirm it works, there is a menu in Polish, and after changing the language from PL to another (e.g. German) the menu no longer shows Polish, only English and you need to change to this English, and then the menu and the teacher are in Polish.
  • #6 17219914
    dekster21
    Rate: 23
    Gentlemen, this comes with deleting the radio from all routes entered. Arrangement installation does not start either manually or from the machine
  • #7 17219925
    michmarmik
    Rate: 12
    That you don't have the active route set. I have lost it at all. There is an option that you have older soft and probably need a map from 2008 to make the radio start with the update from the disc. I recommend searching for Ford forums, you have the whole topic dedicated to this radio there.
  • #8 17219929
    dekster21
    Rate: 23
    So how do you know what this soft is like?
  • #9 17223812
    dekster21
    Rate: 23
    Installation has been successful but Polish language is not
    There was so no help gentlemen
  • #10 17224649
    _siekier
    Help: 77
    Rate: 118
    Do you choose one of two English languages?
  • #11 17385142
    ojciec81
    Rate: 24
    After inserting the update disc, I get the message that NO AUDIO CD OR MP3 CD INSERTED after pressing SET + NAVI I enter the service menu. The problem is because I don't see the option to manually start the update.
    I am asking for any suggestions.
    THANKS
The discussion revolves around the safety and functionality of the Crack TravelPilot FX Blaupunkt for the Ford C Max (2007-2010). Users report that the crack works effectively, although some experience delays in displaying messages when switching between audio sources. Concerns about data loss during the installation process are raised, particularly regarding the deletion of route history and settings. Users suggest updating the firmware for better compatibility with newer devices and provide insights on navigating the radio's settings and language options. Issues with installation and updates are also discussed, with recommendations to consult dedicated Ford forums for further assistance.
