Radio 2Din For Fucus C-max - How to connect a reversing camera
warunek 12012 14
How can I connect a reversing camera to this 2DIN Ford Focus C-Max radio when I only have the main unit and not the rest of the harness?
You can connect it, but you need the correct wiring/harness because the video signal is on the white connectors and the pinout or PCB markings are needed to identify it properly [#16655715] The camera power should be taken from the reversing lamp, not from the license-plate light, and if the supply is pulsating a rectifier diode should be added [#16967326] One reply also says the camera video input is tied in after the ground/mass connection on pin 5 [#16991602]
  • #1 16655579
    warunek
    I am asking for help in connecting (if it is possible at all) a rear view camera on the 2Din radio dedicated to Ford Focus C-max. Unfortunately I don't know the manufacturer (some German)
    I only have the main cube for a photo.
    The camera will be so standard in the frame from the board.
    Below are some photos.
    Radio 2Din For Fucus C-max - How to connect a reversing cameraIMAG05..jpg (4.43 MB)You must be logged in to download this attachment.
    Radio 2Din For Fucus C-max - How to connect a reversing cameraIMAG05..jpg (3.21 MB)You must be logged in to download this attachment.
    Radio 2Din For Fucus C-max - How to connect a reversing cameraIMAG05..jpg (3.26 MB)You must be logged in to download this attachment.
  • #2 16655675
    korek516
    Help: 101
    Rate: 146
    Hello. And the rest of the cubes where they went. How do you want to connect Video from a camera if you don't have a set? Greetings.
  • #3 16655709
    warunek
    I bought used at a good price and there were no other than this one.
    It will do the trick and is there such an option?
  • #4 16655715
    korek516
    Help: 101
    Rate: 146
    Hello. You have video in these white cubes. Turn up the radio, maybe some descriptions will be on the PCB, because you won't find it without proper knowledge. Regards.
  • #5 16655733
    warunek
    But linden. I thought it was done in some standard: /
    Added after 8 [minutes]:
    Photo radio can be associated with something Radio 2Din For Fucus C-max - How to connect a reversing camera
    Added after 54 [minutes]:
    I scoured 2 tons of internet and found the same radio. Maybe we'll come up with something?
    https://www.amazon.co.uk/Indash-Navigation-2004-2007-TRANSIT-2005-2007/dp/B0050328RK Radio 2Din For Fucus C-max - How to connect a reversing camera
    Added after 4 [minutes]:
    here from the manufacturer's website http://www.rupse.com/rupse7-inch-digital-hd-t...pod-bt-control-for-ford-focus-fiesta-transit- p-3646.html
  • #6 16670581
    warunek
    What cubes should I buy to connect it? How can this be some illustrative link? Mini fit?
    Thanks in advance.
  • #7 16966228
    vozniakov
    sorry that I am digging up but I would need a new software for this radio. somebody maybe something?
  • #8 16966241
    warunek
    And what is it even there? I wanted to download navigation but I don't know what version of win ce
  • #9 16966299
    vozniakov
    from the radio I only have something like that and I don't know what's going on ... Radio 2Din For Fucus C-max - How to connect a reversing camera
    from what I read the built-in gps fires on 5.0
  • #10 16966346
    warunek
    If I like something, I would like to grab some newer sofas.
  • #11 16966395
    adrian846
    Help: 5
    In bmw I had a similar problem with the original radios, I recommend a camera for this company or a company camera :)
  • #12 16966411
    warunek
    I have a webcam already installed, the one that sits in the right lamp from the backlight. It works very well only once you have to wipe with your finger because it is dirty, but that's how everyone has it.
  • #13 16967326
    adrian846
    Help: 5
    Voltage cannot be obtained from the backlight of the board but only from the reversing lamp, if it is waving, give the rectifier diode
  • #15 16991602
    mateklos
    Help: 50
    Rate: 189
    after the connection of 5 masses the input to the video signal from the camera
The discussion revolves around connecting a rear view camera to a 2Din radio installed in a Ford Focus C-max. The user seeks assistance due to a lack of additional connectors and information about the radio's manufacturer. Responses suggest checking the white connectors for video input and looking for PCB markings for guidance. Some users recommend using a camera integrated into the rear lamp and connecting it to the reversing lamp for power. There are mentions of needing specific connectors and software updates for the radio, as well as sharing links to similar radios for reference.
TL;DR: To add a reversing camera to the Focus C‑MAX 2DIN unit, use the camera video input and its 5 ground pins (“after the connection of 5 masses…”). “You’ll feed the radio a clean reverse trigger from the lamp, not the plate light.” [Elektroda, mateklos, post #16991602]
Why it matters: This FAQ helps Focus owners wire cameras safely, identify the right connectors, and avoid flicker or no‑signal problems.
How do I physically connect the reversing camera video to this 2DIN radio?
Locate the white connector blocks on the radio. The composite video-in for the camera is brought out on these white cubes. Open the unit if needed and follow any PCB silk labels to map video-in and ground. Use a standard RCA lead from the camera to the correct video-in pins, and tie the camera ground to the radio ground group. “You have video in these white cubes.” [Elektroda, korek516, post #16655715]
Where do I take the camera’s power and trigger from?
Take +12 V from the reversing lamp circuit, not the number‑plate backlight. This provides a clean, on‑only‑in‑reverse trigger to the head unit and powers the camera consistently. If the signal fluctuates or “waves,” insert a rectifier diode in series on the trigger line to stabilize it. This avoids ghosting or intermittent video when lights dim. [Elektroda, adrian846, post #16967326]
I bought the unit used and only got the main harness. What connectors do I need?
You need the mating white connector blocks (“cubes”) that carry AV signals, including the camera video-in. Without the correct set, you cannot properly inject the camera video. Either source the exact accessory harness set for this model or identify the connector series and build a pigtail. “How do you want to connect Video from a camera if you don’t have a set?” [Elektroda, korek516, post #16655675]
Which exact model is this Focus 2DIN unit likely to be?
A matching unit in the thread is a Rupse 7-inch digital touchscreen DVD/GPS player for Ford Focus/Fiesta/Transit. The post links both an Amazon listing and the Rupse product page, suggesting an aftermarket Ford‑fit platform common in 2004–2007 Focus C‑MAX installs. Use those references to match harnesses and pinouts. [Elektroda, warunek, post #16655733]
Does this head unit support GPS on Windows CE, and which version?
Yes. A user reports the built‑in GPS software “fires on 5.0,” which indicates Windows CE 5.0. That helps when choosing navigation apps and compatible map packages built for CE5. Confirm in your unit’s settings or about screen before loading software. [Elektroda, vozniakov, post #16966299]
What’s the simple 3‑step wiring plan to make reverse view auto‑switch?
  1. Feed the camera +12 V from the reversing lamp; ground the camera to chassis.
  2. Run RCA composite video from the camera to the radio’s camera video‑in on the white connector block.
  3. Feed the radio’s reverse trigger from the same reversing lamp line (add a diode if the signal “waves”). [Elektroda, adrian846, post #16967326]
Where is the camera typically mounted on a Focus C‑MAX?
A common solution replaces or integrates with the right license‑plate lamp assembly. The thread author installed that lamp‑style camera and reports good results. Expect to wipe the lens occasionally due to road grime on the hatch area. Route wiring through the existing grommets into the tailgate. [Elektroda, warunek, post #16966411]
What if I tried powering the camera from the plate light and the image flickers?
Move power and trigger to the reversing lamp feed. The plate light can be PWM‑modulated or noisy and causes flicker. Adding a rectifier diode to the reverse trigger can further stabilize the head unit’s sense input. This edge case is common on vehicles with lamp monitoring. [Elektroda, adrian846, post #16967326]
I see mention of “5 masses.” What does that mean for wiring?
It indicates five ground pins grouped near the camera video input area on the radio connector. Tie the camera’s ground to any of those ground pins or to chassis. Ensure a solid ground to avoid a rolling image or loss of sync when shifting to reverse. [Elektroda, mateklos, post #16991602]
Can I connect a standard RCA camera, or do I need a proprietary camera?
Use a standard 12 V composite RCA camera. The radio exposes video-in on its white blocks, which correspond to the typical composite feed used by aftermarket cameras. With the correct harness or a built pigtail, you adapt an RCA plug to the radio’s video-in and ground pins. [Elektroda, korek516, post #16655715]
What if I don’t know the radio’s manufacturer—can I still wire it?
Yes. Identify the AV connector pins on the white blocks by opening the unit and reading PCB labels. The thread confirms video-in resides there. Match ground, video signal, and reverse trigger as described. A missing harness remains the main blocker, so source it first. [Elektroda, korek516, post #16655715]
Is there updated firmware or software available for this radio?
A user asked for “new software” and another sought navigation downloads but lacked the exact WinCE version. First confirm your unit shows Windows CE 5.0 in GPS settings, then install compatible nav software/maps for CE5 on SD. Keep backups before changes. [Elektroda, vozniakov, post #16966241]
What camera brand works well if I want OEM-like fitment?
One user recommended using a company camera or brand camera similar to OEM solutions, citing success with BMW radios. Lamp‑integrated designs for Ford give the cleanest look and correct aim. Choose a model designed for the Focus plate‑light housing. [Elektroda, adrian846, post #16966395]
What is an RCA composite video signal?
It’s the standard analog video format used by aftermarket reversing cameras and many head units. It carries picture information on a single conductor plus ground, typically via a yellow RCA plug. Your radio exposes this signal on the white connector pins instead of a rear RCA jack. [Elektroda, korek516, post #16655715]
Any quick diagnostic tips if I get a black screen in reverse?
Confirm reverse lamp power at the camera, verify the radio’s reverse trigger sees the same feed, and check the video‑in pin mapping on the white block. Try a different ground pin from the group of five grounds. A missing harness is often the root cause. [Elektroda, mateklos, post #16991602]
