Ford 1.8 TDCi Engine: Which Bearing Shell Goes Up and Down in Assembly? Proper Placement Guidance
15951 15
Which bearing shell should go on the upper side and which on the lower side during engine assembly?
If the set has a darker or marked shell, put that one on the more loaded side: in a connecting rod, the upper half on the shaft/piston side, and in the main bearings, the lower half in the cover [#16297285][#16304553] One reply also says these shells have no notch or tooth, so if both halves are identical, their position does not matter [#16296583] Another user noted the shells in question were ordinary rather than sputter type, but still placed the darker one up [#16301574]
  • #1 16296522
  • #2 16296574
    szymitsu21
    Help: 343
    Rate: 1300
    And what is the difference between them?
    And seriously, of course, it doesn't matter how you put it on.
  • #3 16296583
    domator
    Help: 5
    Rate: 20
    They don't have any notches or a tooth so it doesn't matter which half where they will be.
  • #4 16296614
  • #5 16296677
    jerrydzwonkow
    Rate: 18
    As the previous speaker wrote, I will add that often one is signed sputter and then it goes up either in the main bearings or cranks ... my oversight of course that in the main bearings they go down
  • #6 16296862
    sly_1978
    Help: 34
    Rate: 284
    jerrydzwonkow wrote:
    As the previous speaker wrote, I will add that often one is signed sputter and then it goes up either in main bearings or in cranks
    Think again what you advise.
  • #7 16297285
    toku74
    Help: 123
    Rate: 729
    On one of them on the outer surface should be the inscription sputter / it's probably the quieter /. And it is actually harder and from other material. It is put on a more loaded surface - in the connecting rod upwards, i.e. on the shaft, in main bearings downwards, i.e. on covers. Two types of half-shells are usually used in the one-hoof kit. One sputter, the other standard. Why is this done? I recommend the article about sputter shells.
  • #8 16297326
    sly_1978
    Help: 34
    Rate: 284
    That's exactly how it is. In short, "sputter" technology is simply more expensive to perform, therefore in set. there is one regular and one reinforced marked as "sputter".
  • #9 16297513
    toku74
    Help: 123
    Rate: 729
    Here, it is not about the cost, but about the fact that this micro-dirt could squeeze somewhere. It doesn't work in hard, and that's what the second soft one is in. Even in racing engines, two different and often not reinforced are used. The fact is that they are expensive. Recently, when I bought the Skoda 1.9TDI for one crank it cost about 75 zeta. Interestingly, I searched for K9K with Renault sputter and did not find. Maybe I was looking wrong. But the whole set of ordinary was cheaper than one for Skodzin.
  • #11 16302126
  • #13 16302400
    sly_1978
    Help: 34
    Rate: 284
    In my humble opinion on the manufacturer's website results from these numbers quite different. One base is aluminum and the other is copper.
  • #14 16303932
  • #15 16304553
    sly_1978
    Help: 34
    Rate: 284
    Darker on the piston side.
  • #16 17617084
    marcin-buli
    Hello. Do you have any number of these shells strengthened? Or who does them?
The discussion centers around the proper placement of bearing shells in the Ford 1.8 TDCi engine assembly. Participants clarify that the orientation of the shells does not significantly impact functionality, as there are no notches or specific markings to dictate placement. However, some contributors mention that the "sputter" shell, which is harder and made from different materials, should be placed on the more loaded surfaces, specifically on the connecting rod upwards and the main bearings downwards. The conversation also touches on the differences between various shell types, including their materials (aluminum vs. copper) and their intended use in medium-loaded engines. The author expresses concern about using non-original bearings and seeks confirmation on the correct assembly method.
