Unicable - Replacement of a traditional installation with unicable II
Devion 6651 6
  • #1 16296668
    Devion
    Rate: 40
    Due to the fact that all my tuners (Ultimo4k, duo2, solo2 and TV samsung 65KS9000) support Unicable II, and Ultimo is equipped with one double FBC head I decided to switch to the Unicable II system.
    The installation is on two HB and astra satels, therefore I purchased such a system:
    - http://www.ariasat.de/shop.php/sid/34aff98b79...18/cl/details/anid/63156e8381a9e2cc0.66013415
    Unfortunately, the seller informed me after buying that with more tuners you may need additional power supply for this Multischalter, which it does not have and the only one I found in this store:
    http://www.antennenland.net/Inverto-Unicable-Power-Inserter
    And here the problem, because they do not send to Pl for the end user.
    Have any of your colleagues already met this Power Insert?
    And what can it replace (I will find the power supply already)?
    • 5294_SP-IDLU-UWT110-CUO1O-32P(DeV020516).pdf (1.05 MB) You must be logged in to download this attachment.
    • 5380_SP_IDLU-PINS02-OOOOO-OPP(EnV130716).pdf (138.21 KB) You must be logged in to download this attachment.
  • #2 16323549
    STUDIOP
    Nice set :) , but the power supply should be from tuners, with a small number of tuners probably not a big problem, it may depend on the installation and splitters you use. in another company, power is supplied by VL VH:
    https://satsklep.pl/pl/p/Multiswitch-Unicable-II-52-%2C-9734PL-Johansson/31450
    Let me know when you run, I would like to know how switching on these wideband converters in unicable2 works.
  • #3 16323599
    Devion
    Rate: 40
    The power problem solved itself.
    There was a power supply in the package.
    Strange, by the way, that the seller did not know what the set contains?
    Now I am waiting for the weather and a day off to do the installation again.
    I wonder if my Satlink WS-6933 HD Compact meter will measure these Wideband converters?
    I know this Johanssen, a friend assumed it, he had a problem with the configuration of the Unikable channels.
  • #4 16323607
    Fotodetektor
    Level 30  
    Help: 101
    Rate: 335
    Where did you order it ultimately? They sent to PL?
    OMNI-SAT
    WP 11, Wołów, 56-100 | Company Website: www.omnisat.pl
  • #5 16341106
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Wideband technology is new on the market, no amateur meter supports such converters.
  • #6 16345379
    Devion
    Rate: 40
    In the first post I gave a link to the store in DE. Yes they send, after two days I had the package.
    Added after 8 [minutes]:
    That's how I sp [clad, but somehow I need to set the converters in squint.
    Yes, I think that since they are Wideband converters (the whole H band + the whole V band), it may be possible to set the converter (with the help of my meter) by setting on the H output of the converter to HB some known transponder from pol.H and check the same some transponder from pol.V at the output of the V converter?
    And similarly set the converter to Astra.
    Did it work like that?
  • #7 16345944
The discussion revolves around the transition from a traditional satellite installation to a Unicable II system, specifically for tuners including Ultimo4k, duo2, solo2, and a Samsung TV model 65KS9000. The user purchased a Unicable II multiswitch but faced concerns regarding the need for an additional power supply due to the number of tuners. Initially, the seller did not provide clarity on the included components, but the user later discovered that a power supply was included in the package. There were inquiries about the compatibility of the Satlink WS-6933 HD Compact meter with wideband converters, and the user sought advice on configuring the converters for optimal performance. The conversation highlights the challenges and solutions encountered during the installation process.
