Laboratory Power Supply: KORAD KA3005D vs KD3005D - Owners' Insights, Flaws, and Recommendations
krakarak 18258 13
What are the main drawbacks of the Korad KA3005D/KD3005D bench power supplies after some time of use, and would owners buy the same model again?
The main complaint is a brief output-voltage spike at power-up on older units, reported as rising to about 30 V, along with transformer noise; one owner said this was enough reason not to buy it again because you must remember to power it on with the output disconnected [#16339923][#16347096] However, other users measuring KD3005D units reported no voltage jump when switching on, and said the 2017 production units no longer show many of the earlier problems [#16465402][#16467660] Those later units were also said to have improved parts, including the heatsink and fan, and to be structurally different from older versions [#16467660] Overall, the advice is to check which production revision you are buying, because the newer ones seem better than the older KORADs [#16467660]
  • #1 16296814
    krakarak
    Help: 681
    Rate: 1846
    I ask the owners of one of these power supplies - do you see flaws in it after the purchase has elapsed and if you had to choose again now, what would you buy and why?
    I am thinking about buying one of these power supplies and would like to know their disadvantages.
  • Owner shares initial power supply impressions and photos
    #3 16313944
    vidmo
    Rate: 18
    I have. And come walking around youtube a video scolding this power supply
    I am so pleased by the big M but rate it yourself.
    Laboratory Power Supply: KORAD KA3005D vs KD3005D - Owners' Insights, Flaws, and Recommendations Laboratory Power Supply: KORAD KA3005D vs KD3005D - Owners' Insights, Flaws, and Recommendations Laboratory Power Supply: KORAD KA3005D vs KD3005D - Owners' Insights, Flaws, and Recommendations
    Of course, this is not enough to evaluate the power supply, but initially give some insight.
    Best regards.
  • #4 16330284
    rubens
    Help: 209
    Rate: 301
    vidmo- I see you have an oscilloscope in stock
    How can you connect it to this power supply and see if the power supply turns on for a split second when turning on the power supply
  • #5 16337005
  • #6 16339923
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    Appears, and about 30V.
    Not counting this and the noise from the transformer, I am very happy after about 4 years of use.
  • #7 16340631
    rubens
    Help: 209
    Rate: 301
    Thanks.
  • #8 16340672
    rosak
    Help: 142
    Rate: 559
    Here you have the inclusion:
    And here off:
    Talking about the physical on / off button.
  • #9 16347096
    krakarak
    Help: 681
    Rate: 1846
    Thank you to colleagues for substantive posts, especially for full output voltage when the power supply is turned on.
    There is also a negative opinion about output voltage spikes in response to load in one of the topics at Elektroda.
    I will not buy such a linden, where I must always remember to turn on the power supply with disconnected wires at its output, because I can free the powered system.
    I will look for another power supply.
  • #10 16465402
    maz9
    Level 19  
    Help: 16
    Rate: 67
    I made measurements on kd3005d power supplies a few pieces the same measurements. There is no voltage jump when switching on. The decrease in the graph is turning off the increase is turning on the power supply
  • #11 16465430
    rosak
    Help: 142
    Rate: 559
    But this is set to 30V so it won't jump anymore. Set the output to 5V and the time to 100us because you have 1s / div.
    Added after 6 [minutes]:
    Oh, and you're testing the On / Off button and we're talking about the physical Power button.
  • #12 16467660
    maz9
    Level 19  
    Help: 16
    Rate: 67
    Sorry, I add some movies with settings as colleagues have mentioned. Nothing like that, there is no production in 2017, I don't have from previous years, maybe something like that occurred. The power supplies were connected without load. Many inconveniences from previous years do not occur. Many components have been improved, even the unfortunate heat sink or fan.
    They are structurally different from those a few years ago back.
  • #13 16476030
    ekrzychoooo
    Help: 24
    Rate: 73
    maz9 Regarding the first film. Yes, you cannot measure interference at the power supply terminals (this ground loop in the probe).
    Please watch the video
    link from 14:25.
    or
    https://www.youtube.com/watch?v=pKXPqApOYfk full video or moment 1:11
  • #14 16542211
    krakarak
    Help: 681
    Rate: 1846
    I think that this much information will help you make the right decision about buying a power supply for your own needs. Thank you for the activity.
The discussion revolves around the KORAD KA3005D and KD3005D laboratory power supplies, focusing on user experiences, flaws, and recommendations. Users report satisfaction with the KD3005D after several years of use, noting improvements in design and components over previous models. Concerns were raised about output voltage spikes when powering on, with some users suggesting that these issues may not be present in newer units. The presence of noise from the transformer was also mentioned, but overall, users expressed contentment with the performance of their devices. Recommendations include careful consideration of the power supply's specifications and potential issues before purchase.
