[Solved] Error E43 Immergas Victrix 20 xTT: Post-Cleaning Burner Issues, Stove Blocking & Reset Tips
Falkon48 38535 1
  • Burner cleaning may have caused E43 lockout and cycling fault
    #1 18212388
    Falkon48
    Rate: 202
    Applies to victrix 20 xTT after cleaning (rinsing the burner) by the service technician, error E43 turns on and blocks the stove. I have to reset it, recently replaced the motherboard and still no improvement. Today I wanted to turn on the central heating and it doesn't work, I mean it starts to heat up a bit, reaches 45 degrees and turns off. After a few such cycles, E43 turns on, but on this setting, resetting does nothing.
    What should I tell the service technician because he is going to break down. Before cleaning it was not, it has 4 years with extended warranty.
  • #2 18218655
    Falkon48
    Rate: 202
    Replacing the gas valve.
