[Solved] Immergas Victrix TT 20: Error E96, Chimney Clogging & Pressure Switch – Tips & Suggestions
Micek64 34641 8
  • Locating the pressure switch behind E96 error
    #1 17135408
    Micek64
    Help: 34
    Rate: 75
    I warmly welcome,
    Colleagues, I am asking for suggestions regarding error E96.
    It is not in the manual, so I guess it is not a bug, but only a signal. Somewhere here on the Electrode I found an entry that it is a chimney clogging error and the stove is aired (because indeed when displaying E96 at max, the blower is on). Nevertheless, it is happening more and more often and the chimney insert is not free. I dismantled the cover and I wonder where is the pressure switch that states that the pressure in the chimney is too high, signaling clogging?
  • #2 17135434
    mauri_b
    Heating systems specialist
    Help: 109
    Rate: 529
    Exactly that there is no pressure switch there. This boiler is a massacre. When and how was the exchanger cleaned?
  • #3 17135438
    bro2004
    Level 30  
    Help: 160
    Rate: 637
    This boiler does not have a pressure switch.
    When was the boiler inspection with flue gas analysis and regulation performed?
  • #4 17135822
    Micek64
    Help: 34
    Rate: 75
    A year ago.
    The boiler works on average 7 hours a day.
  • #5 17135859
    mauri_b
    Help: 109
    Rate: 529
    Well, the service bows, according to the warranty terms, once a year.
  • #6 17135865
    Micek64
    Help: 34
    Rate: 75
    I know that much, my friend :)
    I started a thread to find out more and if this E96 is what I wrote about.
    PS.
    Can you expand? I have it for 4 years and it's my first "flaw".
  • #7 17236142
    Micek64
    Help: 34
    Rate: 75
    The boiler after the service,
    Cleared and no longer shows up E96.
    However, I do not confirm the words of a colleague of heating systems specialist mauri_b that this boiler is a massacre. It works very well.
    Thank you, I'm closing.
  • #8 17237428
    W0jtek92
    Help: 469
    Rate: 1257
    Hello. The thing about the Victrix TT is that it is necessary to measure the chimney resistance. If the alu-silicon exchanger is clogged, this type of circus may occur. In addition, this model is successful in my opinion, and at least because of the auto-calibration which he makes when entering the service mode, minimal settings adjustments and it flashes nice. I have nothing to pick on this model there.
    Greetings.
  • #9 17237687
    Micek64
    Help: 34
    Rate: 75
    Thank you for confirming your opinion :)
The discussion revolves around the E96 error code encountered in the Immergas Victrix TT 20 boiler, which is believed to indicate chimney clogging. Users confirm that the Victrix TT model does not have a pressure switch to signal high chimney pressure. Regular maintenance, including flue gas analysis and cleaning of the heat exchanger, is emphasized as crucial to prevent this error. One user reported that after servicing, the E96 error ceased to appear, suggesting that proper maintenance resolves the issue. The model is generally regarded positively for its auto-calibration feature and performance.
