ESPACE 2.2dci - Injection Pump Wheel Rotation Post-Casing Dismantling Experiences
grzegorz22lowicz 8958 2
  • #1 16297378
    grzegorz22lowicz
    after dismantling the casing, all the characters agree, only the pump wheel is turned 180 degrees. normally everyone writes and shows
    ESPACE 2.2dci - Injection Pump Wheel Rotation Post-Casing Dismantling Experiences the car normally went only a small head gasket :D ESPACE 2.2dci - Injection Pump Wheel Rotation Post-Casing Dismantling Experiences
    And this is how it looks in my cape!
  • #2 16297397
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Make 1 revolution of the shaft it will set.
  • #3 17656985
    marek8038
    Rate: 14
    Write a friend how to play a pump wheel because I probably have the same after renovation
