Scenic II 1.5dci - How to Determine Piston Direction in Specific Car and Clamp?
nanab 21288 14
How do I tell which way to screw in the rear brake caliper piston on a Renault Scenic II 1.5 dCi before changing the brake pads?
On the Scenic II 1.5 dCi, both rear caliper pistons screw in normally to the right/clockwise on both sides [#16307506][#16827256] If the piston does not wind back easily, the caliper may need cleaning or overhaul because sticking/corrosion can damage the seal [#16306609]
  • #1 16306136
    nanab
    Help: 90
    Rate: 239
    I am trying to find an answer in Google, but I can not.
    How to guess in which direction to screw the piston in a particular car and in a particular clamp? I'm taking on the replacement of the blocks in scenic II 1.5dci and I would like to prepare myself substantively.
  • #2 16306152
    robokop
    Help: 1763
    Rate: 6372
    I think all of which I've seen screw right. Anyway, it seems that after shooting - does the piston hide or crawl? Of course, the appropriate tool for this you have?
  • Rear piston retracts but stops one centimeter short
    #3 16306243
    nanab
    Help: 90
    Rate: 239
    I have a market kit for screwing the pistons. Just that the set has two types of threads - left and right, prompted me to set in which direction to screw.
    Well, I turned on the left side, I took out the leftovers and started with the plunger. Actually you can see that it turns right and turns to the left, without any resistance I did not even have to push the tool against the other side of the clamp, just by turning and pressing with your hand it hid to a certain point. But it still does not go. It is still missing about a centimeter so that the pads and the shield can fit. Denying the tool for a place under the outer brick, it does not turn, it stands asleep. What could I do wrong with such a simple operation?
  • #4 16306256
    domex32
    Help: 585
    Rate: 2451
    Manual electric or traditional?
  • #5 16306277
    nanab
    Help: 90
    Rate: 239
    Mechanical, for cable.
  • #6 16306283
    domex32
    Help: 585
    Rate: 2451
    Insert the picture of the clamp, the plunger after screwing.
  • Questioning whether a wet, extended plunger affects pressing difficulty
    #7 16306302
    nanab
    Help: 90
    Rate: 239
    Picture in the attachment.
    Wet plunger - I'm not sure if it is a leak or water (it is a plush and still a car was driving today), the plunger was strongly extended before screwing in ("woman rides", read does not mention anything while it works), but it seems to me that it did not fall out, the pedal was not soft with the rest after being put in the air for sure. However, could it affect the difficulty with pressing the plunger?
    • Scenic II 1.5dci - How to Determine Piston Direction in Specific Car and Clamp? 20170225_161400[1].jpg (203.96 KB) You must be logged in to download this attachment.
  • #8 16306365
    domex32
    Help: 585
    Rate: 2451
    Watch the plunger under the rubber band, look into the liquid container, if it is not full.
  • #9 16306596
    jenusz11
    Help: 33
    Rate: 196
    from what I remember for sure there were plungers which springs to the left, probably with some fordas but I do not remember exactly
  • #10 16306609
    milejow
    Help: 1563
    Rate: 5149
    Clamp to repair and probably a piston to replace because it is corroded. When the piston is extended, the dust cover does not guarantee good adhesion and protection, corrosion of the piston occurs and when attempted to screw it in the clamp and damage to the gasket-standard in the rear clamps operated for a long time with the worn-out blocks.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #11 16306616
    szymitsu21
    Help: 343
    Rate: 1300
    Exactly. There are such inventions in Fordes.
  • #12 16306675
    ociz
    Help: 1379
    Rate: 3486
    Affirmative. In the Ford in the right clamp, turn left, left turn right. But if it does not go so lightly that you need to deny the device, I immediately put it on the table for cleaning and new erasers.
  • #13 16306723
    nanab
    Help: 90
    Rate: 239
    There is no corrosion or crumb under the rubber band. The problem solved - I used the extension, after one turn it went on until the end without any major resistance, the other side went without any problems.
    Does this apply to the entire brand or several models?
  • #14 16307506
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    I've been doing the Avensis 2012 recently and the left side is backwards ;-)
    In your Scenic two pages normally :-)
  • #15 16827256
    nanab
    Help: 90
    Rate: 239
    Above. the direction in this car is both sides to the right.
    I close the subject.
The discussion revolves around the process of determining the correct direction to screw in the piston during brake pad replacement on a Renault Scenic II 1.5 dCi. Users share experiences and advice on using the appropriate tools, noting that most pistons screw in a right-hand direction. One user encountered difficulty with the piston not retracting fully, which was resolved by using an extension tool. Concerns about corrosion and the condition of the piston and clamp were also raised, with suggestions to check for leaks and ensure proper maintenance. The conversation highlights variations in piston threading direction across different car models, specifically mentioning that in some Ford models, the direction may differ.
