2007 Astra H Twin Top: Boot Lid Won't Open - Possible Motor Voltage or B130F-5A Error Issue
Frost160 21798 4
  • #1 16298593
    Frost160
    Help: 9
    Rate: 182
    As in the 2007 astra H Twin Top theme, an error occurred at the beginning of the attempt to assemble the roof. And everything came to an end with only an inclined bolt, the lower one to which the lock in the flap engages.
    I opened the boot lid accidentally. After pressing, whether from the remote control or the button on the flap, it does not release (there is no voltage on the motor which it does) lock.
    Of course, I checked the fuse F8 under the hood is working (sprinklers that are also under it work).
    The switch in the tailgate itself is also connected to the meter, so the meter clicks on it so it looks ok.
    The motor itself for "short + 12v" also approx.
    The beam from the ankle to the motor itself also looks smooth, not worn. The voltage is not shown also on the cube plug.
    The errors in the roof of the opcom roof show only one:
    B130F-5A mismatch of the boot lid switches.
    However, can this have an effect on the trunk lid which does not work at all?
    Slowly, I have no ideas what else would it be?
    Greetings and thank you in advance for any help.
    How to connect to the opcom with the central lock of the central lock? Select the body and then the central electrics?
  • #2 16299416
    tomek4
    Help: 57
    Rate: 100
    Hi, check carefully the cubes in the astra h liked to often pin them in them so I had
  • #3 16300467
    Frost160
    Help: 9
    Rate: 182
    Thanks, I checked. This is the measure I measured from the rear on the pins of this piece of ankle that comes from the installation of the car also the lack of voltage.
    So I think that this is because the part that holds the bolt to the body is as if it is unlocked and for that the sergeant does not give current to the lock?
  • #4 17268699
    Remi89
    Hello, I have exactly the same problem. Did you manage to solve yours?
  • #5 17870547
    damian84vip
    Rate: 35
    Hello, I have the same problem but I can not get to the trunk. Can you tell me how to get to him? I read that there is some link to pull somewhere, but I do not know where to look ...
