Brera 2006 - "yellow steering wheel with a key" indicator,
Aleksander_01 8685 3
  • #1 16299092
    Aleksander_01
    Help: 1170
    Rate: 3447
    Patient - Alfa Romeo Brera, 2006.
    The first problem is the frequent blocking of the ignition, you have to insert the key several times.
    For those who do not know how it works - after inserting the key into the reader (because it is a modern key that does not have a tip and ignition switch), the indicator (pictogram) lights up on the display, the yellow steering wheel with the key and then the car does not start. By removing and inserting the key again, you can start the car. The states when the car does not want to start appear more and more often.
    The second problem - the mirrors do not fold after turning off the car, i.e. it is such a super modern car that after turning off the car and locking it with the remote control (yes, this car has a remote control for waves, wow) the exterior mirrors should fold, i.e. position themselves parallel to side windows of the same car.
  • #2 16299340
    piotrekwoj1
    Help: 947
    Rate: 3439
    As for the first fault, it is either the key or the reader, as for the second, I understand that the folding worked earlier and was damaged, was the damaged car bought? You did the diagnostics, are there any errors?
  • #3 16299354
    Pawel wawa
    Help: 1262
    Rate: 4434
    Such a nice car, it is great to diagnose, it even has a special socket for that, wow! The first problem, probably related to the steering lock, but the diagnostics will say more. You need to read in the manual whether it is possible to fold the mirrors or not. Since I do not know this car, I will not tell you more.
  • Seeking Alfa 159/Brera steering lock repair kit compatibility
    #4 16299440
    Aleksander_01
    Help: 1170
    Rate: 3447
    Pawel wawa wrote:
    Such a nice car, it is great to diagnose, it even has a special socket for that, wow! The first problem, probably related to the steering lock.
    Well, I meant this blockade, which is similar to the B6 trade wind. And now the next problem - is it possible to buy a repair kit for such a blockade (something a la passat B6), or the alfa 159 is built on identical elements (up to 159 are these modules available on aledrogo). I didn't take it on my computer because the guy came in like a fire. As for the second fault, these mirrors used to be composed (this is what the customer assures), but this is a minor matter. He is supposed to come during the week and leave the car.
    Or maybe someone has already done such a blockade in brerze or 159?
