HDMI to SCART (RGB) Converter for Philips 28PT5025/58 TV & Evobox Decoder: Affordable Options
SF01 11307 12
How can I connect an HDMI-only Evobox decoder to a Philips TV that has only SCART, preferably with RGB and at an affordable price?
You need an active HDMI-to-SCART converter, not a passive adapter, because HDMI is digital and SCART is analog [#16505121] The thread says direct converters do exist, with one mentioned at about 99 PLN, but another reply notes that 150 PLN is not cheap [#16505463][#16505183] A cheaper workaround is HDMI -> VGA -> SCART: use an HDMI-to-VGA converter and then any SCART adapter/cable, but the picture quality will be different [#16504991] If you use that route, some HDMI-to-VGA converters also provide analogue two-channel audio output, because sound has to be handled separately [#16505063]
  • Need an HDMI-to-SCART RGB converter
    #1 16504535
    SF01
    Good day.
    My generous television provider has decided to add a new decoder for the new contract for 1pln, of course I have to return the old one. The problem is that the new one has no SCART output, only HDMI.
    Apparently there are converters from HDMI to SCART (the opposite is the whole mass), but my question is, are there such at a reasonable price with an RGB signal?
    Because 3xRCA with composite is a laugh in the room.
    Comments encouraging the purchase of a TV with HDMI can be forgiven, this is not the purpose of my search.
    SF
    TV: Philips 28PT5025 / 58
    Decoder: Evobox
  • #2 16504991
  • #3 16505018
    sosarek
    Help: 9321
    Rate: 15545
    @ Kraniec_Internetów What about the sound?
    About the type of prosthesis
    Kraniec_Internetów wrote:
    HDMI> VGA-> SCART
    I will not even speak anymore.
    Z
    Pka, Poznań, 60-850
  • HDMI to SCART converters with analog stereo audio
    #4 16505063
  • #5 16505112
    sosarek
    Help: 9321
    Rate: 15545
    Since there are no cheap adapters that the author needs
    There are enough to enter the "HDMI-SCART adapter" ...
    And with the VGA to the eurozłącza short road.
    Well, not exactly.
    Z
    Pka, Poznań, 60-850
  • #6 16505121
  • #7 16505170
    sosarek
    Help: 9321
    Rate: 15545
    HDMI is digital, and analog SCART.
    VGA is also analog.
    https://www.elektroda.pl/rtvforum/topic3170851.html
    The first from the shore
    https://www.dmtrade.pl/p7307,konwerter-hdmi-na-scart-spacetronik-snh2avs03.html
    Not an adapter only converter.
    Fact, I thought about one and I wrote about the other ;)
    Z
    Pka, Poznań, 60-850
  • #8 16505183
  • #9 16505463
    SF01
    I saw the direct converter for 99, you can risk it from China, but it will be two months.
    I do not hide it, the sound would come in handy, although the decoder theoretically has a mini-jack and coax, but how to connect it to the VGA SCART switch ...
  • #10 16505480
  • #11 16505513
    nici
    Help: 266
    Rate: 983
    PLN 150 is not cheap.
    Of course not cheap ... I would say it very well.
    SF01 wrote:
    I have seen a direct converter for 99, you can risk it from China,
    At these prices, I would change the TV set.
    I'm not right, gentlemen?
  • #12 16505514
  • #13 16506215
    SF01
    TV has only two SCARTs.
    The alternatives are:
    1. Converter for the tip.
    2. Replace TV.
    3. Leave the old decoder and calm.
    Yes or no, thank you for the information.
The discussion revolves around finding an affordable HDMI to SCART (RGB) converter for the Philips 28PT5025/58 TV and Evobox decoder. Users express concerns about the lack of cheap options that provide RGB signal, as most available converters only offer composite output. Suggestions include using an HDMI to VGA converter followed by a VGA to SCART adapter, although this may affect picture quality. The need for an active signal converter is emphasized due to the digital-to-analog signal conversion required. Some users mention the possibility of sourcing converters from online platforms, albeit with potential delays. The conversation also touches on the limitations of the TV's audio inputs and the practicality of keeping the old decoder.
