Connecting UPC Mediabox Decoder to Older Philips LCD TV: Using DVI & Audio Cables - No HDMI
biohazardmce 6927 8
  • #1 16744654
    biohazardmce
    Hello. I have a question how to connect a UPC mediabox decoder to an LCD TV without HDMI. The TV is an old but spring LCD phillips that has no HDMI but DVI. I currently have a euro> euro cable connection. The quality is not bad but I would like to have it digitally. How to connect it to make it sound, because DVI is just a picture ??????
  • #3 16744694
    biohazardmce
    Dekoder Cisco8485DVB . Tv Phillips 37pf9986/12
  • #5 16744801
    biohazardmce
    the decoder has audio and tv output also has audio output on the cable also there will be no sound. Out> out
  • #6 16744817
    sosarek
    Help: 9320
    Rate: 15542
    This manual contains information about audio connectors for the DVI socket.
    Where we use a multimedia computer
    Please connect with an audio cable
    2
    exit from
    computer sound card and input
    AUDIO R
    (right) and
    L
    (left) on the LCD monitor.
    Z
    Pka, Poznań, 60-850
  • #7 16744822
    biohazardmce
    but I don't want to connect a computer, only a decoder
  • #9 16744836
    biohazardmce
    ok, thx works
    Added after 41 [seconds]:
    I put it in the wrong hole, because the tv hangs on the wall and that's why ... (bad hole) :) :) :) :)
The discussion revolves around connecting a UPC Mediabox decoder (Cisco 8485DVB) to an older Philips LCD TV (37PF9986/12) that lacks HDMI inputs but has a DVI connection. The user seeks a digital connection for better quality and inquires about audio output since DVI only transmits video. Responses suggest using an audio cable to connect the decoder's audio output to the TV's audio inputs, as the DVI connection will handle the video. The user successfully resolves the issue after adjusting the connections.
