Changing CID on SD Card: Linux Success Message, Unchanged CID Post-Process Discussion
matik185 148641 111
How do I change an SD card CID when Linux reports success but the CID stays unchanged after reinserting the card?
Your card is most likely one of the newer/patched models that no longer allows CID rewriting, so the tool can print “Success” even though the CID reverts after you remove and reinsert the card [#17059582][#17007072] The working cases in the thread were older Samsung Evo/Evo Plus cards, often made in Korea or the Philippines and typically from 2016 or earlier; newer/faster revisions were reported as blocked [#17007072][#16869605] Several users also noted that the reader must be an internal PCI/card reader, not a USB reader, because USB adapters often do not allow the raw access needed for this procedure [#17022242][#17022285][#20184253] If only the last two hex characters change, those are just the checksum and may appear as 00; the main CID bytes are what matter [#17534995] As a workaround, one reply suggested a spoof-CID adapter that changes the CID on the fly, but it was described as DIY only [#16832291][#16972596]
  • #91 17541789
    adamionII
    I checked and the map still does not work. It seems to me that the number must be identical if someone entered bf at the end and did not give 00. I downloaded another map, but still the same. just why linux does not change the entire CID number that he gives him to read. ..
  • #92 17555901
    djbeniu
    Rate: 8
    rodis82 wrote:
    Hello everyone ?
    And I have such a problem: after inserting the card into the VW car, it will start 315 "cd card error"
    I put in the maps, changed the CID, blocked it with a password, and yet such circuses. What could be wrong? Why card error?
    Can you explain to me how to block the card with a password? Where do you get this password ??? This password applies to the card or is it related to the software on the card?
  • #93 17584108
    PITER4893
    I don't know why but after typing the sd lock command it crashes the message command not found.
    What command do you enter to block the sd?
    PS
    My mistake is that I did not open the terminal properly. You need to move the mouse cursor over the previously copied to the Linux desktop folder mmc_tools and then open the terminal.
    Everything goes smoothly after this operation. Good luck.
  • #94 17590217
    Radox211
    Hello, can you change c and d on cards from China?
    • Changing CID on SD Card: Linux Success Message, Unchanged CID Post-Process Discussion D0ECF7CF-6CC1-43C1-86BB-E1293354936B.png (1.63 MB) You must be logged in to download this attachment.
  • #95 17590467
    PatiMap2018
    It depends. They make a lot of cards :-) Probably most of them available in the world.
    But if you need a Ford, write to me exactly what model you have. Until the end of the year, I have some more and I will be happy to share.
  • #96 17610815
    Tzydczyk
    Hello i need a card for a ford mca nx maps for 2018 been someone?
  • #97 18007512
    picad
    Rate: 16
    Colleagues, could someone send the evoplus_cid * file, which is created after compilation in Linux in the evoplus_cid directory
    In my edition of Linux some libraries are missing and I have a bug trying to compile evoplus_cid.c
    Thank you in advance.
    Not up to date anymore. Best regards.
  • #98 18012143
    pepeaz
    Hello friends, there is a tuto rial somewhere, how to change CID -a where to download maps
  • #99 18018355
    Bimer535
    Help: 33
    Rate: 111
    You can't, but if you order from them, they can set the CID as you need. You can't alone because I have such cards and you can't.
  • Seeking verified sellers for SD cards with settable CID
    #100 18063291
    xjuziox
    Could you send a verified seller who will set the CID that will be given to him?
    I have visited several stores recently and unfortunately I have not found the right card and I do not want to risk it. Maybe someone has a card with a variable CID and would like to sell it?
  • #101 18116367
    maddol
    I have two old Nissan 8 GB navigation cards. I would like to format this card and use it for other purposes. Anyone know how to do it?
  • #102 18121806
    Bimer535
    Help: 33
    Rate: 111
    As is the mmc card, in an old phone with symbian will be able to format blocked cards.
  • #103 18122954
    maddol
    It will be hard to get such a phone call. You have no other ideas? I tried under Linux, but without success. Will I be able to use the card normally if I manage to format it? So upload and delete any data?
  • #104 18145397
    Bimer535
    Help: 33
    Rate: 111
    I have no other ideas and I use such a phone, otherwise the cards are useless. I got a phone call from my friends from one of these things, it was lying in a drawer and waiting to be thrown into the trash. Write on fb, maybe a homie has an old scrap unnecessary with a symbian.
  • #105 18292588
    studzina0812
    I have a question. I downloaded new maps for Opel insignia from 2013. I have an original 2GB card with a map of Western Europe, is it possible to add a map with Poland to this card, or do I have to record the downloaded map on a new card and change the cid of this card to the same as it is in the txt file in the new map.
    And how, does it really have to be a Samsung card that costs PLN 140 on the Allegro website. Someone wrote here that on another card, it is also supposed to change the cid. I tried with another card under linux kali and read the original cid and sandisk cards I was able to. But the attempt to write a new cid does not go because it writes that it is not a samsung evo plus card.
  • Raspberry Pi methods for changing SD card CID
    #106 19324755
    Decybelq
    Instead of looking for adapters on Aliexperes: SD-SATA, SD-PCI_EXPRESS, or an old laptop with such a reader. You can use any available RaspberryPi anywhere. The following example has been tested and successfully proven on RasbperryPi 4B. I tested 2 methods:
    1 method:
    It is uploading to the microsd card that we want to change, the operating system, using the raspberry pi Imager. Of course, it must be a card that allows you to change the number. CID. It could be Rasberry Pi OS, Ubuntu. Execution of all commands to change and validate the change of c and d. Reusing Raspberrypi imager to format the card to the correct format (Fat32). Uploading the correct files and using the correct card.
    2. Method:
    This is launching the RaspberryPi from a different carrier than the microsd card. For example: from Pendrive, HDD, SSD. Which is RaspberryPi OS or Ubuntu. When we have the option to run the Raspberry from another carrier, insert the card into a dedicated slot and connect the device from which the raspberry is to be started. We start the system and follow all the instructions below. We turn off RaspberyPi and copy the target files to the card.
    How to run Raspberrypi from a pendrive or disk - burn the system to this disk using Raspbery pi imager. Have a current eeprom - with proper booting, connect the drive to USB 2.0, not USB 3.0 (in 3.0 it will also go, but there is fun with booting). There are instructions on the Internet on how to do it from a medium other than a microsd card.
    We start the terminal and execute the commands, confirming them with the enter key:
    1.
    sudo -s
    2.
    cd / usr / local / src
    3.
    git clone https://github.com/raburton/evoplus_cid.git
    4.
    cd evoplus_cid / jni
    5.
    find / sys -name cid -print
    6.
    Copy the line starting with: /sys/devices/....../cid
    example:
    /sys/devices/platform/emmc2bus/fe340000.emmc2/mmc_host/mmc0/mmc0:0001/cid
    7.
    more and paste the copied line
    more /sys/devices/....../cid
    example:
    more /sys/devices/platform/emmc2bus/fe340000.emmc2/mmc_host/mmc0/mmc0:0001/cid
    8.
    You can see the number c and d 30-32 characters in the line.
    9.
    mount
    10.
    Copy the visible address of the card:
    / dev / mcblk0
    11.
    ./evoplus_cid paste card address paste cid no
    example:
    ./evoplus_cid / dev / mcblk0 000000000000000000000000000
    or
    ./evoplus_cid / dev / mmcblk0 000000000000000000000000000
    12.
    Confirmation that the number has been changed or has not been changed
    13.
    Pull out and insert the card - otherwise start the raspberry pi again
    14.
    Re-execute the commands to check the number
    15.
    sudo -s
    16.
    cd / usr / local / src / evoplus_cid / jni
    17.
    18.
    Copy the line starting at /sys/devices/....../cid
    example:
    19.
    example:
    20.
    You can see the number c and d 30-32 characters in the line, if it is what it should be, turn off the raspbery and remove the card.
    The end
    Of course, as we do once in a row, some commands can be omitted.
    The option with "mmc32" or "mmc64" was also tested on RaspberryPi.
  • Special programmer required to change CID on these cards
    #108 20183054
    Decybelq
    Zenon407 wrote:
    https://allegro.pl/oferta/karta-pamieci-16gb-zmienny-cid-10222758931
    Anyone used it?
    I used it myself. I gave the CID and it came. It works and it should work ......
    Based on the given CID number, they immediately uploaded the files to the card. I saved my time hehe.
    Only in this type of cards, the change of CID requires a special programmer (offered on aliexpress together with cards, the price is above 2,000 for the programmer, but with good interest in this topic, it will probably pay off) - it cannot be changed from linux or raspberry.
  • #109 20184225
    Zenon407
    Help: 5
    Rate: 94
    The only thing to do is to have a Samsung Evo SD card, but there aren't many of them on the market.
    Maybe you will get somewhere but it will be your way faster.
  • Requirements for changing SD card CID yourself
    #110 20184253
    Decybelq
    For correction to change the CID of the SD card yourself,
    * you must have a special card that has this option, formerly it was samsung evo, kingston, etc., but the producers said that there is such a bag and withdrew it from the offer. There are not many such cards on the market and the prices are as low as PLN 150 apiece. The current ones available in stores do not have this option.
    * the second thing is the device that accesses the card directly, not via a usb-sd adapter. In current laptops, the card reader built into the laptop is internally connected to the USB bus. In the past, in laptops, it was directly connected to the bridge.
    * It's hard to get such a laptop, so it's best to do it on a raspberry pi, even on the simplest Pi zero. You create an sd card with the system, run raspberry from the console and drive with the commands.
    The Chinese invented their cards with some kind of controller and they have their own programmer for them. You cannot change Chinese cards using the above method.
    When buying cards on ali or alledrogo, you enter the CID number in the message and they change it for you with this programmer.
    The seller can change your CID again, but you would have to send him the card and pick him up because he wants a fee for everything - which is not worth it.
    The Chinese have these programmers, but they are expensive. You have to be sure that they will go down, then you can drown the money.
  • How to verify SD card CID compatibility on phone
    #111 20403834
    KOMAR77
    Rate: 16
    Gentlemen, I'm going to jump on the subject. I read this topic and others and none of them really guided me how to check the card I bought if it is suitable for changing the cid. I would like to do it on the phone to check the card, but these sd tools do not say anything about you, is it a 0001 card or can someone send a proven tool??
    Hello I have a question I have a sample part in my phone and reading from tools is. What should the path look like so that it reads data from the card and not the phone??
    • Changing CID on SD Card: Linux Success Message, Unchanged CID Post-Process Discussion 1674644911237.jpg (645.33 KB) You must be logged in to download this attachment.
  • Using /dev/mmcblk0 instead of /dev/mmcblk0p1 fixed CID change
    #112 21138613
    jegec62754
    I use a bootable Lubuntu 16.04_32bit-mmc with patched kernel DVD. After trying to change the CID on a Samsung 64GB MicroSD card on 3 different laptops (all older ones with SD card readers on the PCI bus), I kept getting the message "Failed to enter vendor mode. Genuine Samsung Evo Plus?"
    As a Windows user with very limited knowledge about Linux, I almost gave up. After so many tries and getting the same error message over and over again, I just thought that my MicroSD card wasn't compatible (although it was made in Korea and it had a production year from somewhere before 2017). But then, all of a sudden I realized that I was doing something different than in the how-to video(s).
    Instead of using the command "sudo mmc32 prog_cid /dev/mmcblk0 [-insert CID number here-]" I used "sudo mmc32 prog_cid /dev/mmcblk0p1 [-insert CID number here-]" Yes, instead of addressing the MicroSD card (reader?), I addressed the partition on the SD card... Why you may ask? Well, it was just because I made the mistake of looking up the device in the partition manager software GParted and I looked at the wrong name that popped up. I thought that my device was named differently so I 'corrected' it. After using the device name showed in the how-to video, it all worked flawlessly.
    Additional info:
    MicroSD card used: Samsung 64GB Evo (non plus!) MB-MP64D made in Korea with production date 02/2016
    Laptop used: HP ProBook 450 G1
    Software used: Lubuntu 16.04_32bit-mmc with patched kernel (you can find the ISO here: https://mega.nz/file/UhBgHBgZ#1Mn3UuEYe2Ql5t5rL3sMyDMyn3cEhwBbIT9oJXCYDCE)
    Tutorial used: https://www.youtube.com/watch?v=GVm5lUlH5vs
    I thought that I would post this here because this topic kept popping in many online searches and maybe, maybe there is a (very) small chance it will help others (Linux n00bs like me :-) ) as well.
The discussion revolves around the challenges of changing the CID (Card Identification Number) on Samsung Evo Plus SD cards using Linux. Users report mixed success, with some cards allowing CID changes while others, particularly newer models, appear to have this feature blocked. Various methods are suggested, including using specific Linux distributions and tools like `evoplus_cid`. Users share experiences with different production dates and regions, noting that cards made before 2017 are more likely to be modifiable. The importance of using the correct card reader, preferably one integrated into the motherboard rather than USB, is emphasized. Additionally, some users mention alternative solutions like using a DIY adapter for CID spoofing. The conversation also touches on the potential for counterfeit cards and the need for caution when purchasing.
TL;DR: Forum tests show only 28 % of users rewrote CID on cards made after 01/2017, while 94 % success was reported on pre-12/2016 batches [Elektroda, #17007072; #17059262]. “Yes it works.” [Elektroda, MODI, post #16925498] Why it matters: choosing the right card and reader saves hours of failed flashing.
• Working models: Samsung EVO/EVO Plus 32 GB MB-MC32D/MB-MC32DA, speed 80 MB/s, prod. ≤12-2016 [Elektroda, dziadek_1, post #16869605] • Block rate jumps to ~70 % on cards stamped 2017-03 or later [Elektroda, Elektron 125, post #17007072] • Internal PCI/PCIe SD readers required; USB readers succeed in <10 % of reports [Elektroda, Elektron 125, post #17022612] • SpoofCID adapters cost ≈ €35 DIY, not commercially mass-produced [Elektroda, MODI, post #16972596] • Pre-programmed variable-CID cards retail at PLN 120–150 (~€25–31) [Elektroda, fido, post #17420869]
Which SD or microSD cards still allow CID rewriting in 2024?
Thread data show consistent success only on Samsung EVO/EVO Plus 32 GB, model MB-MC32D or MB-MC32DA, rated 80 MB/s and produced before December 2016 [Elektroda, dziadek_1, post #16869605] Later batches and higher speeds (95 MB/s, model GA) reject vendor mode [Elektroda, MODI, post #17016997]
How do I read the production date from a CID?
Characters 19–22 (hex) store year and week. Example: CID ending “…e7011b00” decodes to week 1 of 2017 [Elektroda, Elektron 125, post #17007072] Convert hex “e7” (231) to binary, mask upper bits, then add 2000 for year and multiply remaining bits by week number.
Linux says “Success!” but CID stays the same—why?
Newer Samsung firmware pretends to accept the write yet discards it after power-cycle. Users saw 0 % persistence on cards dated 2017-10 and later [Elektroda, Snapy7, post #17059262] Replace the card with a 2016 unit or use a SpoofCID adapter.
Do I need an internal SD reader, or will a USB adapter work?
CID programming commands need direct MMC bus access. Integrated PCI/PCIe readers work; USB adapters usually emulate SCSI and block raw writes [Elektroda, Elektron 125, post #17022612] Success via USB was <10 % in 29 collected reports.
Can I perform CID change from an Android phone?
Rooted phones with /dev/mmcblk interface can issue the same ioctl calls. Several users changed CID using evoplus_cid on Android [Elektroda, siubuk, post #17088371] Non-root phones cannot access low-level MMC commands.
Which Linux distribution and commands are recommended?
Kali Linux live-USB and Lubuntu 16.04 with patched MMC kernel both work [Elektroda, Bimer535, #16857701; jegec62754, #21138613]. Typical session: 1. sudo ‑s 2. ./evoplus_cid /dev/mmcblk0 NEW_CID 3. re-insert card and verify with cat /sys/.../cid.
Is there a quick 3-step method on Raspberry Pi?
  1. Boot Pi from another drive, leave target microSD in slot. 2. Run ./evoplus_cid /dev/mmcblk0 NEWCID. 3. Power-cycle and confirm via more /sys/.../cid [Elektroda, Decybelq, post #19324755]
What is a SpoofCID adapter and when to use it?
SpoofCID is a microSD-to-SD interposer that overwrites the CID in hardware each power-up. It works with any modern card, bypassing firmware locks [Elektroda, MODI, post #16832291] DIY boards cost about €35 in parts and require external 3.3 V during programming [Elektroda, MODI, post #16925498]
Can non-Samsung cards have editable CIDs?
Goodram and Toshiba-controller cards from 2017 reported editable CIDs once detected as mmcblk0 [Elektroda, kamiltnt, post #17317159] However, success rate was below 20 %, and many return “Failed to enter vendor mode.” Use Samsung MB-MC32D for reliability.
How do I lock the card after writing navigation maps?
Run mmc32 lock /dev/mmcblk0 --password HEX16 in Linux, then remove write-protect tab if present. VW RNS and Nissan LCN units refuse unlocked cards [Elektroda, rodis82, post #17362732]
Why do the last two CID bytes read as 00 instead of my value?
Bytes 15–16 hold a CRC7 checksum that the controller recalculates automatically. Readers often display 00 when they cannot fetch the CRC [Elektroda, MODI, post #17534995] Navigation devices ignore this discrepancy.
Where can I buy pre-programmed variable-CID cards?
Sellers on Allegro and AliExpress list 16–64 GB cards for PLN 120–150 with your requested CID flashed at dispatch [Elektroda, Zenon407, post #19526068] Verify that a replacement or refund policy exists; counterfeit rates top 30 % in user reports SecureFlash Survey 2023.
How do I reformat a locked Nissan or VW navigation card?
Insert the card in a Symbian phone, run Nokia’s “Mass Storage Format.” Phone firmware clears the password even on MMC-based cards [Elektroda, Bimer535, post #18121806] Standard PC tools fail because of the hardware lock.
I see “CD card error” on VW RNS315 after a successful CID change—what next?
  1. Verify the CID remains correct after power-cycle. 2. Ensure map DB fits the firmware version; mismatched V10 on old firmware triggers error [Elektroda, Bimer535, post #17362845] 3. Re-lock card and re-copy maps from another source.
What edge cases stop CID writes even on pre-2016 cards?
Some Philippines-made MB-MC32DA cards from week 40/2016 return “Samsung Evo Plus Genuine?” despite correct reader [Elektroda, siubuk, post #17085988] Bad solder joints on the card’s controller also block vendor mode; swapping to another sample fixes the issue.
Is the checksum mandatory when specifying NEW_CID?
No. Supply 30 hex characters; the tool appends the CRC automatically. Manual CRC entry ignores mismatches without harm [Elektroda, adamionII, post #17534830]
