WIFI from phone to router - network from phone through router to computer no wif
m5r 13146 2
  • #1 16301547
    m5r
    Rate: 17
    I would like to do this configuration - internet from the phone via wifi to the TP-Link WA500 router and then from the router via the cable to another device. How to do it, does anyone know? The router has one antenna to serve as a receiver for the wifi signal from the phone. Thanks for any comments. I have already made such a connection between the two routers, but how to do it with a smartphone? best regards
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Just like between two routers, the WA500G only does not connect to a phone-only router. You set the WA500G to some static address, eg 192.168.1.250, disable DHCP and configure the radio connection with the phone. When it connects, the device connected to the WA500G with a cable should get the address from the phone because the WA500G is a transparent device in this configuration.
  • #3 16301671
    m5r
    Rate: 17
    It worked, thanks for the tips, best regards
