Construction of a device for setting - convergence of wheels.
rsv6 16935 2
  • #1 16302293
    rsv6
    Rate: 285
    I would like to build a device for setting wheel alignment. Any ideas?? I want to use laser modules and aluminum profiles. Does anyone have an idea how to make handles for rims and how to make distance laser sensors ??
    Something like:
  • #2 16302578
    D214d3k
    Help: 543
    Rate: 633
    In the case of metal, it is simply 2 magnets, for example, up to the edges.
    As far as the distance is concerned, I would make such a great caliper to measure the spacing of lasers and then set it 2 meters from the car (for or before) and hit the lasers in points.
  • #3 16304968
    rsv6
    Rate: 285
    It's like me in the first movie. Only the rotating laser must be perfectly perpendicular to the wheel axis. And this patent from the second movie, what do you think?
