  • Impact is a 105 g high-speed line-following robot that won the 2012 Robot Challenge in Vienna and several Polish competitions.
  • A lightweight two-module design uses 14 analog KTIR0711S reflective sensors, an STM32F103RBT6 Cortex-M3, TB6612 H-bridges, and an EDF tunnel fan for added cornering downforce.
  • Replacing the previous 19-sensor, comparator-equipped board with a 14-sensor 0.8 mm laminate board cut sensor-module mass from 8 g to 4 g.
  • Two 10:1 Pololu HP motors deliver a theoretical 3 m/s maximum speed, with typical route averages of 2.3–2.5 m/s.
  • The 220 mAh 25C 7.4 V Li-Po supports only about 30 seconds of optimal driving, so competition runs typically require battery replacement every two rides.
  • [Line Follower] Impact
    Introducing the Line Follower class robot named Impact. This is an improved version of previous design described in the largest forum of Polish amateur robotics. The robot was created in 2011, until now he was the winner of all competitions in which he participated. The biggest success is undoubtedly the first place in the international robot tournament in Vienna, called by many unofficial European championships. The robot consists of two modules: the main board and the sensor plates, connected to each other by means of light carbon strips. The weight of the whole with a battery is 105 g.
    Sensor module
    This is the element furthest from the center of rotation. The moment of inertia is large (mass multiplied by the square of the distance from the center of rotation), therefore, in order to be able to extend the sensors far, the mass of the plate should be as small as possible. In the previous version, we used 19 sensors, 16 of them in arc, 4 forward and back respectively. The plate also contained comparators and a potentiometer for setting the threshold value (Figure 1).
    Fig. 1 Sensor system in the previous design.
    In the new module, we used 14 sensors, placed at greater distances from each other. As a result, the span of extreme sensors remained unchanged. Sensors moved forward are eliminated. It turned out that at high speeds, taking into account the inertia of the drive, the robot was unable to react effectively to the signal from them. Due to the reduction of the number of sensors, there was the possibility of using the analog-to-digital converter built into the microcontroller (16 multiplexed inputs), which allowed to dispense with the comparators. Without these additional systems, the plate sizes have been reduced. We also changed the thickness of the 1.5 mm laminate by 0.8 mm. These treatments led to a two-fold reduction in the mass of the plate from 8 to 4g. The appearance of the module is shown in Figure 2.
    Fig.2 View of the sensor board in the current, new version of the robot.
    Reflecting transducers have been used to detect lines. KTIR0711S . Connected in groups: three sensors in series with a resistor. Pads for the digital distance sensor have been placed on the board Sharp 40cm < br />.
    Main module
    The board is both a printed circuit and a construction chassis. In addition to electronic circuits, we have included propulsion engines and a tunnel drive. We managed to significantly reduce the module in relation to the previous version of the robot. The dimensions are: 140 mm x 60mm.
    Electronics
    The heart of the robot is a microcontroller from the native STM32. The motors are controlled by H TB6612 bridges. The power feed consists of a 5V impulse converter and a 3.3V linear stabilizer.
    Microcontroller - 32-bit STM32F103RBT6 with the ARM Cortex-M3 core, including among others : 128kB Flash, 20kB RAM, USB, CAN, UART, I2C, SPI, ADC, DAC in the LQFP64 housing, fulfills the following tasks:
    readout of input port states,
    converting analog signal into digital form,
    generating PWM signal,
    control bridges H – generating appropriate signals,
    implementation of the control algorithm,
    communication with the LCD module,
    control of LED diodes. [/ list: u: b4e32f31d6]
    Motor controllers - two two-channel Toshiba H bridges TB6612 , enabling:
    speed control by means of PWM signal,
    changing the direction of rotation of the motor by changing the states of two pins,
    fast braking. [/ list: u: b4e32f31d6]
    To protect against system damage at maximum current consumption by motors (1600mA), bridges A and B were connected (current efficiency increased to 2A). The bridges have been connected as shown in Figure 3.
    Fig. 3 Motor controller connection diagram.
    Remote control
    Due to the high speeds achieved during the journey, it becomes more difficult to stop the robot manually. Starting and stopping is done wirelessly, using infrared. The ATtiny13 system used is responsible for decoding the signal from the remote control, which transmits the signal in the RC5 standard. The solution developed by Philips increases the resistance to interference from the environment and creates the possibility of using universal and publicly available remotes. Another advantage is the ease of using additional buttons on the remote control. An additional processor has been used due to the high requirements for the reliability of remote stopping operations, e.g. in emergency situations.
    Drive
    The drive consists of two engines Pololu HP   with transmission 10: 1 with the following technical parameters:
    Idle speed at 6V: 3000rpm,
    Idle speed (6V): 120mA,
    Peak current: 1600mA,
    Torque: 0.3 kg * cm (29 mNm),
    Dimensions: 24 x 10 x 12 mm,
    Weight: 10g. [/ List: u: b4e32f31d6]
    The wheels consist of rims made of plastic polyamide and specially selected tires. The rim fits tightly on the motor shaft and protected with cyanoacrylate adhesive (Figure 4)
    Fig. 4 Wheels made of polyamide with Mini-Z tires.
    Different types of tires have been tested. The best choice turned out to be the tires used in the Mini-Z car models. These are 12mm wide and 3mm thick tires. The next parameter is the hardness, which is 20 ° (on a scale of 10 ° -60 °). Tires with lower hardness are characterized by greater adhesion, but they wear out more quickly. The diameter of the rim with the tire is 27mm. The cleanliness of the tires is also very important. Before each passing, they are cleaned to remove dust particles that cause loss of adhesion and have a negative effect on performance.
    Theoretical maximum linear speed of the robot in the limit of 3m / s. Depending on the route, the average speed achieved is 2.3-2.5 m / s.
    Tunnel drive
    An important element is the EDF tunnel drive. It is a turbine, as it is used in flying models, but mounted inversely. The element is to create an additional pressure force, which helps the robot to stay on the route in curves at high speeds (above 2m / s). The turbine is equipped with a brushless motor (11,000 rpm, power consumption about 4A), which is controlled by the company's controller Dualsky .
    Fig. 5 Tunnel drive EDF27 with engine control.
    Power supply
    To power the robot the package was used Lithium-Polymer Dualsky 220mAh 25C 7.4V (Figure 6). The continuous current that the package is able to provide is 5.5A, while the peak current is 11A, it is sufficient for proper power supply. The battery allows for approx. 30 seconds of optimal driving, after which the supply voltage drops which negatively affects the dynamics and maximum speed of the robot. During the competition, battery replacement is usually performed every 2 rides, which allows the use of full engine power. The mass, which is about 16 grams, had a big impact on the use of such a small package.
    Fig. 6 Dualsky battery 220mAh used.
    Directly from the battery are powered by motors and a tunnel drive. Electronic components that require 5V voltage are supplied with stabilized voltage using an adjustable converter. ST1S10PHR with current efficiency up to 3A. The processor's power, or 3.3V, comes from a linear LDO (low-dropout) system. LF33CT , whose input voltage is derived from the 5V converter. The power scheme is shown in Figure 7.
    Fig. 7 Block diagram of the power path.
    User interface
    Setting up the regulator requires frequent changes of parameters such as maximum speed of driving motors, turbine rotor speed or PID controller gain. Connecting the robot to the computer after each pass, especially at competitions where the service stations are located at certain distances from the route was very troublesome. A module was created with an LCD display for viewing the settings and buttons for adjusting them. As mentioned earlier, mass is a key parameter, therefore the system is a separate module that connects to the robot via the UART interface.
    The main functions of the module are:
    choice of regulator's settings,
    choosing the maximum speed,
    selection of rotational speed of the tunnel rotor turbine rotor,
    checking the correct operation of the sensors,
    viewing the output data of the PID controller,
    setting the threshold voltage value for the reflective sensors. [/ list: u: b4e32f31d6]
    Fig. 8. Module with LCD display.
    Software
    The software was written in C language using the libraries provided by STM: STM32F10x_StdPeriph_Lib_V3.5.0. The control algorithm is PID with some modifications.
    Achievements so far:
    1st place T-BOT – Wałbrzych - 2012
    1st place Robomaticon – Warsaw - 2012
    1. the place of the Robot Challenge – Vienna - 2012
    1st place of the Tri-City Robot Tournament - Gdańsk - 2012
    1st place CybAirBot - Poznań - 2012
    Photos konstrukcji
    [Line Follower] Impact [Line Follower] Impact [Line Follower] Impact [Line Follower] Impact [Line Follower] Impact
    Filmy z zawodów
    Autorzy konstrukcji:
    Bartosz Derkacz
    Szymon Mońka
    sailo
    sailo wrote 6 posts with rating 52. Live in city Wrocław. Been with us since 2012 year.
  • #2 11046167
    dondu
    Help: 1292
    Rate: 809
    So this year belongs to you - Congratulations! :)
    1. How did you choose the distance between the sensors and the wheel axis (center of rotation)?
    Experimentally, or specific calculations?
    2. What is the element connecting the sensors with the motherboard?
    Carbon fiber?
  • #3 11046219
    gbd.reg
    Rate: 45
    Hello, great design, congratulations on achievements ;) I would like to note that the first two drawings were inversely placed (those with the sensor module).
    I have a question about the infrared sensor, where and how it was placed to catch from as many remote control positions as possible?
  • #4 11046339
    Juffre
    Help: 9
    Congratulations, fantastic robot. Can you know how much it costs to make such a gem?
  • Experimental sensor spacing, carbon mount, IR placement, and cost
    #5 11046624
    sailo
    Rate: 52
    We selected experimentally. This distance is especially important if straight angles are on the route. The faster they are detected, the robot will more accurately overcome this problem and will lose less speed.
    Carbon fiber?
    Carbon strip.
    Right, corrected. Thanks to :)
    gbd.reg wrote:
    I have a question about the infrared sensor, in which place and how it was placed to catch from as many positions of the pilot as possible? br >
    The sensor is located on the right side of the main PCB in front of the engine. The remote control works from virtually any angle.
    Juffre wrote:
    You can know how much it costs to make such a gem?
    The total cost is about PLN 500. I do not count the money put in prototypes and testing of individual elements. ;)
  • #6 11046974
    arti4-92
    making the collars on the "main" module, which look a bit like those in hovercraft, would cause the robot to suck up to the track, of course it would result in a significant increase in grip.
  • #7 11047053
    sailo
    Rate: 52
    arti4-92 wrote:
    making the flanges at the "main" module, which look a bit like those in hovercraft, would cause the robot to suck up to the track, of course it would a significant increase in adhesion.
    The flanges are made of window seals. However, there is a problem: on uneven tracks and plate connections, the robot may hang, so they can not be too long.
  • Questioning sensor distance choice for different routes
    #8 11047501
    dondu
    Help: 1292
    Rate: 809
    sailo wrote:
    We've chosen experimentally. This distance is especially important if straight angles are on the route. The sooner it is detected, this robot will more accurately overcome this problem and will lose less speed.
    This is only half of the restrictions, because the opposite (I think) overcoming narrow routes with too long "nose" + moment of inertia, which you paid particular attention to.
    Will you change this distance depending on the route, or did you choose the average option looking at your own experience from previous competitions?
    I ask because I see additional holes in the slats.
  • #9 11048031
    sailo
    Rate: 52
    You're right, for a narrow and winding route, a shorter nose is a better solution. We have several sets of slats of different lengths and we change before the competition. The holes are leftovers after the tests.
  • #10 11048043
    dondu
    Help: 1292
    Rate: 809
    And a question related to this but more about the practice of participation in such events:
    Do you do this selection before the start, seeing the route, or after passing a specific route in the test run?
    In other words, what is the practice of selecting the length of the slats to for a specific route ?
  • Long sensor slats suit straights; short slats suit winding tracks
    #11 11048284
    sailo
    Rate: 52
    We choose the length before the start of the competition, although it was also possible to make a correction during testing.
    As a rule, routes in Poland are similar (gentle arches, long straights and curves at 90 degrees), which is why we usually use a variant with long slats. The exception is the T-Bot competition, which is very winding. The lines are close to each other, so the use of far-extended sensors can cause you to get out of the route (picture below).
  • #12 11052584
    konel83
    Rate: 8
    I think so, because the discussion here shows that in the competitions you can make a trial run, did not the authors think about "remembering the route" and in the second pass use this information for optimization?
    Or even better, take a picture of the route and on a PC a program that would detect the lines and calculate the optimal speed for the engines ...
  • #13 11054657
    szymon122
    Help: 302
    Rate: 763
    I have a question: what is the name of this ribbon connecting the main PCB with the sensors. Where can you buy something like that? What are the prices? I have one with the pins removed.
  • #14 11054787
    sailo
    Rate: 52
    We plan to remember the route in the next construction.
    The tape is a ffc / fpc connector, 0.5 mm pitch, available in e.g. TME
  • #15 11054843
    szymon122
    Help: 302
    Rate: 763
    I found, you can buy it for less than PLN 5? I did not know that it is so expensive; /
  • #16 11089029
    Martin_250
    I warmly welcome.
    So out of pure curiosity, I would like to ask how the rules of such professions usually apply to, for example, the use of a turbine which increases the pressure and the general method of increasing pressure and what has been mentioned above, namely memorizing the route and optimizing the passage based on such data.
    This is interesting because knowing the parameters of the vehicle, ie its mass, tires or even aerodynamic characteristics, and finally the parameters of the route itself and the surface ..
    You can actually use the computer with the appropriate software to perform on-site optimization, leading to the fact that we squeeze the maximum from the vehicle.
  • #17 14550407
    arkady_pl
    Help: 59
    Rate: 24
    Martin_250 wrote:
    using the computer with the appropriate software, perform on-site optimization, leading to the fact that we will squeeze the maximum from the vehicle.
    The meaning of these professions will lose. The point of this competition is to build a robot that will negotiate a route it does not know and will do it well and quickly.
    Currently, these competitions are a software race. The structures of these best players are very similar. The winner will be the one that has better grip, greater dynamics and a better algorithm to deal with obstacles, and lately at high speeds, the speed of microcontrollers and the speed of A / D converters is becoming more and more important.
    Personally, I should say that they should introduce an additional factor to these professions: the number of transistors in the control system. For example, for each transistor the player would receive 0.01s to the overall score. Then the one who will optimize the layout will win. Because it's no art to implement mega software on fast microcontrollers.
    In a moment, there will be a robot with Full HD camera on the nose, a fast image analysis system and in flight will optimize each route. Only then will I ask: are these professions still needed? Where's the fun of building? In a moment, someone will sell blocks and software as KIT and everyone will buy one. That's probably not the point, right?
    I would introduce restrictions (exemplary) to this competition:
    - up to 500 transistors
    - up to 6 light sensors
    - maximum external dimension of the vehicle (150mm x 100mm)
    - each transistor adds 0.01s to the result
    - without clamping pressure systems (only natural gravitational pressure)
    Cool is the version of Line Follower where there are obstacles. If there were hardware limitations, then finally the players had to actually work on the tools instead of just implementing the next algorithms. Then it would be construction races and not software.
    Imagine for example that it is 1970 and you have to build a robot for the Line Follower competition. This is a challenge. Now it is very easy.
  • #18 14550706
    treker
    Help: 31
    Rate: 250
    arkady_pl wrote:
    Personally, I should say that they should introduce an additional factor to these occupations: number of transistors in the control system.
    An interesting proposition, I met her for the first time. However, I do not know if this would help in the development of competition. It must be remembered that such robotic professions are intended to encourage students and students to build something practical. Should it be limited from the very beginning?
    I even saw small children at competitions, who with their parents made a robot for Arduino. They probably would not even realize how it is with these transistors and abandoned the topic. Anyway, the electronics are moving forward, which is bad in using vision systems or fast systems? After all, everyone has the same access to them, if the key to building a better robot is to refine the algorithm, then it should be refined and that's it.
  • #19 14550746
    arkady_pl
    Help: 59
    Rate: 24
    treker wrote:
    arkady_pl wrote:
    Personally, I should say that they should introduce an additional factor for these occupations: number of transistors in the control system.
    An interesting proposition, I met her for the first time. However, I do not know if this would help in the development of competition. It must be remembered that such robotic professions are intended to encourage students and students to build something practical. Should it be limited from the outset?
    Of course, you should not limit it. I'm talking about it to make competition more ... ... exciting.
    treker wrote:
    I even saw small children at competitions, who with their parents have put together a robot for Arduino. They probably would not even realize how it is with these transistors and abandoned the topic.
    Of course, you are right. I encourage my kids by showing an easy way to build. And then I raise the bar. Because, as I wrote, building a robot from "cooked" is simple.
    treker wrote:
    Besides, the electronics are moving forward, which is wrong with the use of vision systems or high-speed circuits? After all, everyone has the same access to them, if the key to building a better robot is to refine the algorithm, then it should be refined and that's all.
    Personally, in such competitions, I see the fun of competition in the other direction, or make a simple robot that will overcome this more advanced one.
    My message is that I dream that young people optimize devices instead of complicating them more and more. He dreams and thinks in terms of what to do to do it without a computer. Of course, not always and not everything is possible or there is no point in trying to optimize because it quickly turns out that the computer is the most optimal solution, but in the case of line followers, especially those in the basic version of the track, it can be done without a computer.
    Maybe I will pass my message in a different way: until recently it was a race of constructors and electronic engineers. Currently, they have nothing to say because now Line Follower is a race of programmers. And that's what I mean the most about. This is a competition for IT professionals, not people from robotics.
  • #20 14550760
    treker
    Help: 31
    Rate: 250
    arkady_pl wrote:
    They currently have nothing to say because now Line Follower is a race of programmers. And that's what I mean the most about. This is a competition for IT specialists, not people from robotics.
    I have traveled around 10 times a year for such competitions and so far (at least in LFs) I have not met with typical computer science. They are always people interested in electronics. Everyone is trying to improve something in the robot also from the technical side.
    I am more concerned about the temporary stagnation in this competition. It used to develop faster, now there are accurate descriptions on the Internet, and some have big problems with the construction of a bearable robot.
  • #21 14550802
    arkady_pl
    Help: 59
    Rate: 24
    treker wrote:
    I am more puzzled by the temporary stagnation in this competition. It used to develop faster, now there are exact descriptions on the Internet, and some people have big problems with the construction of a lucid robot.
    Everyone should copy the SAILO user structure and then it would be people races from the PID controller configuration ;)
    You put it in a good TREKER, I write about it, that the constructions are, you can build them and many resemble or copy them. And what can be changed in such a construction? Weight, downforce, number of sensors, engine dynamics? And only the algorithm remains. The standstill will end when there is a lighter and stiffer laminate, lighter motors, lighter batteries, lighter rims and tires, lighter electronics, a stronger turbine, faster electronics.
    That is why we are stagnant. Hence my suggestions to make competition more difficult - add a new category in which the points get also for the construction. This is partly done in more advanced competition with obstacles but this only affects the software (and several sensors) and not the overall structure.
    My tots as they learned about competition with obstacles, they said: easy. Do you know what the idea of overcoming obstacles was?
    Because the obstacles are limited in size, they wanted to build a robot that would take them "astride" :D Can you imagine these "rolling" machines bypassing obstacles? :D
    Yesterday with my puppies we came up with a new Line Follower - if you could call it that. They came up with the idea to convert the helicopter so that it flew 5cm above the board and flew over the line. Oh ... and he understands, this is a fresh approach to the subject ;)
  • #22 14550822
    treker
    Help: 31
    Rate: 250
    arkady_pl wrote:
    add a new category
    There is already a division into LFy Standard and Turbo (with turbine). Amazingly, new competitions have ceased to appear in LF Turbo and the competition with turbines is dying a bit. I do not know if new competition would be accepted at the moment.
    LF games with obstacles could be more interesting if the obstacles were invented wisely. Those that are now are not overcome in a sophisticated way.
  • #23 14550841
    arkady_pl
    Help: 59
    Rate: 24
    treker wrote:
    LF games with obstacles could have been more interesting if the obstacles were invented wisely. Those that are now are not overcome in a sophisticated way.
    Oh, I strongly support your opinion.
    And if the obstacles are sophisticated, then I will not insist on millions of transistors because it will be a cybernetic task and not just the PID chasing the line with a bit of chasing the wall. Then I will be delighted when someone builds even a robot "transformer", which with the use of vision systems will overcome the obstacle course. And if we add to this, that the board will contain small water reservoirs and mud as well as bridges from two beams and false roads "ala maze" then this competition will become a structural and cybernetic challenge. Such a "biathlon" in the issue of robots. But there would be competitions!
The discussion revolves around the Line Follower robot named Impact, which has achieved significant success in competitions since its creation in 2011. Participants inquire about the design choices, such as the distance between sensors and the wheel axis, the materials used for connections, and the placement of infrared sensors. The author explains that the distance was determined experimentally to optimize performance on straight angles and that carbon strips connect the sensors to the motherboard. The total cost of the robot is approximately PLN 500, excluding prototype expenses. The conversation also touches on strategies for adapting the robot for different track types, the potential for route memorization in future designs, and the evolution of competition rules to encourage innovation and technical challenges in robotics.
TL;DR: 105 g line-follower “Impact” hits 3 m/s and “wins every event it entered” [Elektroda, sailo, post #11046095] Designed with carbon-fiber slats and 14 KTIR0711S sensors. Build cost ≈ PLN 500 [Elektroda, sailo, post #11046624]
Why it matters: The build shows how lightweight design, smart sensor placement and on-board tuning push DIY robots into championship speeds.
• Mass (with battery): 105 g [Elektroda, sailo, post #11046095] • Peak straight-line speed: 3 m s⁻¹; race average 2.4 m s⁻¹ [Elektroda, sailo, post #11046095] • Sensors: 14 × KTIR0711S reflective, ADC-read [Elektroda, sailo, post #11046095] • Battery: 2-cell 7.4 V / 220 mAh / 25 C Li-Po, 5.5 A continuous [Elektroda, sailo, post #11046095] • Parts cost: approx. PLN 500 (≈ €110) [Elektroda, sailo, post #11046624]
What are the core hardware features of Impact?
Main MCU: 32-bit STM32F103RBT6, 128 kB Flash, 20 kB RAM. Drive: two Pololu HP 10:1 gear-motors, 3000 rpm@6 V. Motor bridges: dual TB6612, channels paralleled for 2 A peak. Sensors: 14 KTIR0711S plus optional Sharp GP2Y0D340. EDF27 turbine supplies extra downforce at >2 m s⁻¹. Total footprint: 140 × 60 mm [Elektroda, sailo, post #11046095]
Why were 19 sensors cut down to 14 in the new version?
Fewer sensors halved board mass (8 g → 4 g) and let the built-in 16-channel ADC replace comparators. Forward-facing detectors were ineffective at high speed due to inertia, so removing them saved weight without hurting tracking accuracy [Elektroda, sailo, post #11046095]
How far in front of the wheels should the sensor arc sit?
Distance is chosen experimentally. Long noses detect 90° bends earlier but increase inertia and overhang risk on tight, narrow tracks. Teams keep multiple carbon-fiber slats of varying length and swap them before a race after viewing the course layout [Elektroda, sailo, post #11048031]
What material links the sensor board to the chassis?
Ultra-light carbon-fiber strips act as both structural arm and vibration damper, minimising inertia while keeping sensors far ahead [Elektroda, sailo, post #11046624]
Where is the infrared start/stop receiver mounted?
The TSOP-style IR sensor sits on the right edge of the main PCB just ahead of the motor. This side-facing position gives nearly 360° reception for standard RC5 remotes [Elektroda, sailo, post #11046624]
How much does building Impact cost?
Parts only total about PLN 500 (≈ €110). Prototyping iterations and spare slats add extra but are not counted in that figure [Elektroda, sailo, post #11046624]
How do teams pick the best slat length on race day?
  1. Inspect the course on arrival.
  2. Fit long slats for open Polish-style tracks; fit short ones for winding layouts like T-BOT.
  3. Optional: adjust again after a test run if rules allow [Elektroda, sailo, post #11048284]
Can the robot learn the track and run faster the second time?
Current firmware does not store track maps, but the builders plan route-memorising logic for the next iteration [Elektroda, sailo, post #11054787] Many European contests still forbid pre-programmed path playback, so always check rules [RobotChallenge Rules, 2023].
What ribbon connects the boards and what does it cost?
A 0.5 mm-pitch FFC/FPC cable links the sensor PCB to the STM32 board. 20-way, 100 mm variants cost PLN 3-5 per piece in Polish distribution [Elektroda, sailo, post #11054787]
How long does the 220 mAh Li-Po power the robot?
It delivers optimum voltage for roughly 30 s of racing. After that, sag lowers top speed, so teams swap packs every two heats [Elektroda, sailo, post #11046095]
What benefit and risk comes with the EDF tunnel drive?
The EDF27 adds downward pressure, boosting grip in curves above 2 m s⁻¹, but its brushless motor draws 4 A: over 70 % of battery continuous rating, shortening runtime [Elektroda, sailo, post #11046095]
Edge case – what can make Impact stall during a run?
Over-long window-seal flanges may catch on joint gaps of uneven tracks, causing the chassis to hang despite increased suction [Elektroda, sailo, post #11047053]
How can you retune PID gains track-side without a PC?
  1. Plug the 5 g LCD/button module into the UART.
  2. Scroll menus to edit max motor RPM, turbine PWM and PID terms.
  3. Unplug to drop weight before racing. “On-board tweaks cut pit-time to seconds.” [Elektroda, sailo, post #11046095]
Are turbines or route memory legal in most competitions?
Turbo (turbine) classes exist, but many events run separate ‘Standard’ categories without downforce aids. Track-memory is often disallowed because the spirit is ‘unknown-track autonomy’ [LineFollower Rules, 2022]. Always read the host’s rulebook.
What upgrades are planned for the next version?
The team targets track-memory, faster ADC sampling and lighter composites to beat the 105 g mark while keeping 2 A drive headroom [Elektroda, sailo, post #11054787]
Which titles has Impact won so far?
It claimed first place at five events in 2012, including RobotChallenge Vienna—often dubbed the unofficial European championship [Elektroda, sailo, post #11046095]
