[Solved] Yamaha RX-E810 No Power Issue: Replaced C8 22nF, Damaged 4 2.2k Resistors & TC4013 Circuit
geco 18801 11
How do I reset or troubleshoot a Yamaha RX-E810 that has 10 V and 5 V rails but still will not start after replacing the TC4013 and damaged 2.2 kΩ resistors?
Yes — this model has a reset/protect startup procedure in service mode: hold PRESET/BAND and TUNING ^ (MIN) while pressing the power switch, and if it clicks and turns off, repeat the procedure with power held for at least 3 seconds [#16405819] If there is still no reaction, check the reset line on the standby supply, the relay, and whether the front-panel keyboard and all processor signals are present, because the unit can refuse to start even when 10 V and 5 V are already there [#16405665] A faulty reset circuit can also be caused by C3 in the standby power-supply module; replacing it with 4.7 µF restored normal start-up in one case [#17282158] Another report found D9 open in the TC4013/reset section, which left the reset voltage unstable around 4.5 V until the diode was replaced [#16405912]
  • #1 16404166
    geco
    Help: 69
    Rate: 175
    A typical malfunction of this set is no power. In my case, someone has already replaced C8 22nF. The capacitor is OK, however, 4 2.2k resistors and the TC4013 circuit have been damaged. After replacing the resistors and TC4013 circuit for CD4013 for PLN 2 instead of PLN 60, voltages appeared, but Yamaha still shows no signs of life. There are voltages on the processor, quarks also. I just have an oscilloscope with waveform checking.
    Can these symptoms lead to the processor falling down, or does this kit have a reset key on local keys?
  • #2 16404608
    dybas
    Help: 419
    Rate: 338
    What type did he replace? Capacity checked?
  • #3 16404892
    geco
    Help: 69
    Rate: 175
    On the same as it was, i.e. 22nF after I changed to another 22nF and after the advice I put two 47nF. If the capacity was not working, would the power supply not start? and I have 10V and 5V.
  • #4 16405649
    dybas
    Help: 419
    Rate: 338
    That's right, except that the capacitor type, apparently, plays an important role. I did not have this model on the autopsy table, according to previous records, there should be polypropylene. Since the equipment does not start, it unfortunately comes out that it is not a capacitor.
  • #5 16405665
    sylweksylwina
    Help: 1882
    Rate: 2355
    Reset protect by entering service mode. Well, unless there is no reaction ... Check the voltage at the switch. Relay trying to turn on?
  • #6 16405683
    geco
    Help: 69
    Rate: 175
    As if I have to reset protect, please explain it to me. The relay does not respond and after any short circuit no reaction.
    Maybe someone will explain what the magic of this video is.
    https://www.youtube.com/watch?v=NfdCM4HiMTw
    I guess dawn dude made a NE555 generator for reset and Yamaha came to life.
    Added after 5 [minutes]:
    Well, nothing can do without an oscilloscope.
    https://www.elektroda.pl/rtvforum/topic2980019.html
  • #7 16405819
    sylweksylwina
    Help: 1882
    Rate: 2355
    You hold preset / band and tuning ^ (MIN) and press the power switch.
    If it clicks and turns off then if you know what you are doing (there is a risk of damage to something) then you do the same procedure, only that you hold power for at least 3s. If the processor has all the signals that allow it to start (and is functional), and the front keyboard is also functional, there should be no problem with firing.
    In Annex SM, the above procedure is also described on page 10 SM in English.
    EDIT:
    If the attempt to start fails, write what voltages do you have on this connector: Yamaha RX-E810 No Power Issue: Replaced C8 22nF, Damaged 4 2.2k Resistors & TC4013 Circuit
    • yamaha_rx-e410_810.pdf (8.07 MB) You must be logged in to download this attachment.
  • #8 16405912
    geco
    Help: 69
    Rate: 175
    Now it surprised me. I started to measure the voltage on TC4013 once again and here 2.5V it turned out that the diode D9 was open. I put on a 10V zenerke 6.3V appeared to me but the same thing strangely floats with a 4.5V reset almost falling to zero and again So there is tension or I am trying to get a job.
    Does the motherboard need to be connected to the motherboard.
  • #9 16993129
    niedoza
    Rate: 11
    Good morning
    I have been a happy owner of E 810 for over 10 years. For some time, I do not want to turn on either the remote control or the button. For some time, removing the plug from the socket - now not anymore :( Could anyone from Warsaw or the surrounding area undertake repairs without ruining me?
    thank you in advance for your help
  • #10 17282158
    mirektv
    Help: 5
    Rate: 33
    I would like to include one more interesting topic in the subject. The power supply problem in this model is not the only problem in the topic "does not start", because there is also a problem with reset. This can be checked simply by unplugging the plug from the stand-by power supply pin the reset should turn on. In my case, the symptom was that at 240V the equipment switched on, but not at 230V. Replacing the C3 capacitor in the reset circuit on the stand-by power supply module helped, I installed 4.7uF for certainty. After this maneuver, it turns on easily at 160V from the network
  • #11 17282273
    sylweksylwina
    Help: 1882
    Rate: 2355
    So it was also a problem with the power supply :)
  • #12 19024927
    geco
    Help: 69
    Rate: 175
    However, without the original TC4013 there was . I can only close the topic .
The discussion revolves around a Yamaha RX-E810 experiencing a no power issue. The user has replaced the C8 22nF capacitor, which was confirmed to be functional, along with four damaged 2.2k resistors and the TC4013 circuit, substituting it with a CD4013. Despite these replacements, the device remains unresponsive, although voltages are present on the processor. Participants suggest checking the capacitor type, as polypropylene may be required, and recommend entering service mode to reset the device. A user mentions a potential issue with the reset circuit, indicating that replacing the C3 capacitor in the standby power supply resolved similar power issues. The conversation highlights the importance of proper component specifications and troubleshooting steps for restoring functionality to the RX-E810.
