MIO MiVue 638 Touch Car Video Recorder: Issues with USB Connectivity to Computer
Danielos_ 13761 10
Why does my MIO MiVue 638 not connect to my computer via USB, and how can I update it?
For updates, you do not need a PC USB connection: download the update file to the memory card, insert the card into the recorder, start it, connect external power/charger (or powerbank), confirm the update on screen, and wait until it shuts off [#16304962][#16305149] To view recordings on a computer, use the MiVue Manager for Windows or remove the memory card and read it with an external card reader [#16304855] If the device still shows no USB reaction after trying different cables and working USB ports, the problem is likely a hardware fault in the recorder, cable, or USB port [#16304962][#16305149]
  • #1 16304755
    Danielos_
    I recently bought a MIO MiVue 638 touch car video recorder and when I connect it to a computer via USB there is no reaction, the computer sees nothing. What may be the problem ?
    Please help
  • #2 16304855
    niebieski55
    Help: 34
    Rate: 81
    To access the recordings from the recorder you must install the "MiVue Manager" program for Windows 7/8/10 on the PC or remove the memory card from the recorder and read the recordings contained on it on an external reader. Link to download the "MiVue Manager" application link
  • #3 16304880
    Danielos_
    I don't have a problem with that because I put the memory card in and read everything to me, I need to connect it via USB to download radar updates. I saw a video on YT as the camcorder is connected to the computer and a message appears on the screen of the camcorder that it is connected to the computer and everything is ok and for me neither the webcam nor the computer displays nothing.
  • #4 16304962
    niebieski55
    Help: 34
    Rate: 81
    In this video link it is shown that a PC connection is not required for the upgrade. Just download the update file and put it on the memory card and follow the instructions provided. As for the lack of connection with a PC, it may be a hardware problem with the cable or USB port.
  • #5 16305060
    Danielos_
    I don't know why, but when I do it through the memory card, after inserting it back into the recorder, a message appears if I want to see updates, it gives me ok and turns off and should be updated. However, when I check the version after a while, this is the firmware version and there are no speed cameras.
    As for the USB cable I tried on two, I bought a new one and nothing is displayed and the USB ports are all working properly
  • #6 16305149
    niebieski55
    Help: 34
    Rate: 81
    Danielos_ wrote:
    I do it through the memory card, after inserting it back to the recorder a message appears whether I want to see updates gives ok and turns off and should be updated
    You have to follow all the steps like this guy in the video, i.e.
    1. save the update file to the card
    2. insert the card into the recorder
    3. start the recorder
    4. connect the charger (powerbank or in the car) to the recorder
    5. select "OK" on the screen asking if you want to update
    6. wait until the recorder turns off
    Point 4, i.e. connecting to the charger, is important here.
    If this procedure does not work then the recorder cannot be updated by normal means and you will have to visit the service.
  • #7 16308176
    Danielos_
    Unfortunately it does not work. I think I will have to submit a complaint
  • #8 16308917
    niebieski55
    Help: 34
    Rate: 81
    There is still a possibility (although unlikely :) ) that you have chosen the update file incorrectly. This is a direct link for your model link . The second possibility is that on the update page there is an instruction about the file called "Speedcam.bin", and after downloading the file we have the file "Speedcam_Data_EU.bin". Try to rename the downloaded file to "Speedcam.bin" and only update. Maybe there is a problem :) .
  • #9 16309526
    Danielos_
    File downloading good. unfortunately the file name change did not help :(
    Even if it were possible to update the firmware and speed cameras, I would give the equipment for complaints, because I didn't spend so much money so I couldn't connect it via USB to the computer.
    So thanks for your willingness it's a shame that nothing can be done
  • #10 16802271
    cesiu69
    I also have a question about the Mio c330 video recorder after starting the engine, sometimes the inscription pops up establishes a USB connection, is it a defect or is it normal
  • #11 19762349
    arturchludek
    Rate: 9
    cesiu69 wrote:
    I also have a question about the Mio c330 video recorder, after starting the engine, sometimes the inscription pops up establishing a usb connection is it a fault or it's normal
    Power cuts out during startup. And that's what causes such a problem. You need to plug in without shutting off at start-up.
✨ The discussion revolves around issues with the MIO MiVue 638 Touch Car Video Recorder's USB connectivity to a computer. The user reports that the device is not recognized when connected via USB, despite attempts with different cables and ports. Suggestions include using the "MiVue Manager" software for updates, but the user prefers USB for radar updates. Alternative methods for updating via the memory card are discussed, but the user experiences firmware update failures. Other users mention potential hardware issues and the importance of following specific update procedures, including connecting the device to a power source during updates. The user ultimately considers filing a complaint due to the persistent connectivity issue.
