Opel Meriva A 1.6 Z16XEP (2009) - Rear Brake Pad & Disc Replacement: Pressed & Screwed Pistons?
Bartek* 7572 1
  • #1 16692869
    Bartek*
    Rate: 27
    Hello colleagues
    I have the subject Meriva A 1.6 Z16XEP. Man. Year 2009. Shields with 5 screws.
    I plan to replace the pads and discs at the back. My question is ,
    are the pistons pressed in and screwed in or only pressed in?
    Thank you in advance for your answer
    grzeskk
    Help: 320
    Rate: 731
    They are screwed into the discs at the back.
